Sponsored Ad
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 07-09-2005, 11:18 PM   #1
wjfawb0
Default gears, lockers, limited slip, etc...???
My truck is an 02 regular cab 4x4 2.7L 5 speed (daily driver). I bought it used a few days ago with 22,313 miles on it. I got my wife in her '00 Celica to give me speed readings over cell phones going down the highway to figure out that when my speedo reads 70mph I'm doing approximately 75mph. The wheels and tires on the truck are P265/70-16 115S on aluminum. The tires are worn considerably further than I would think they should be for the mileage so I am starting to think the previous owner put on the 16s after buying the truck. The incorrect speedometer readings also seem to support this theory(and the truck seems weak compared to other Taco 2.7s with stock wheel/tire combos). I want to keep running ~31" tires, so I suppose I need to drop my gear ratio to 4.10 or 4.56. My door jam says B06A or 8" 3.91 open diff. If I am going to change out my gears I want to look at lockers and limited slip diffs while I'm at it. So, here comes the questions...
From what I have read in the last few days, with my 02 model and its live hub front drivetrain I need to run an electronic locker up front and not an autolocker. I don't want to do a manual hub swab up front mainly because this is a daily driver. For the rear would a limited slip diff. suffice for daily driver duty, or should I go ahead and put a locker in there too so that I can lock both or one of them up when appropriate?
I don't plan on rock crawling or anything, but I would like to have the ability to get out of sticky situations easier by being able to spin all my wheels.
I have been searching for gear and diff. information to see what path I should take, and so far I have had no luck trying to find precisely what I am looking for information-wise. Any thought or direction to tech articles or threads that might be helpful would be appreciated. Thanks,
-Jason
'10 4x4 TRD Offroad doublecab Tacoma
wjfawb0 is offline   Reply With Quote
Old 07-10-2005, 02:11 AM   #2
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
-Jason
with tires that are well worn the speedo will be off since the actual tire diameter is quite a bit less than when new
3.91s on an '02/5sp, very interesting. You are the first one I've seen post with a newer than '00 that didn't have 4.30s with that combo. It seems that the reg cabs got the short stick on this one. more trivia to add to my collection...
for what you describe I would go with the rear ARB (RD-89) and a Truetrac up front (LSD, pt #911A342). I ran this combo for about 2yrs and it was great for everything but the wilder rock crawling (why I swapped out to the front ARB).
Handling in snow, mud, etc was just as good as me current ARB.
If you don't plan on going larger than 31s or 32s then stick with 4.30 gears. The problem, however, is that this ratio is a dealer only item; no aftermarket mfgs have them. 4.56s will be fine with 32" tires however but you'll need a 2" lift.
So, for a DD that occasionally wheels I'd recommend the OME complete suspension kit with 881 coils (just under $1k + install) for 100% better ride/handling and they will settle out to around 2" of lift on your truck. Then add the gears/locker/LSD and some 32s and rock sliders and you'll be ready to tackle most trails with relative ease.
this won't be cheap but you'll be very pleased with it.
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 07-10-2005, 06:20 AM   #3
wjfawb0
Default
Thanks for the reply. With the worn tires, wouldn't my speedo read higher than my actual speed? Each revolution of the tire with a smaller diameter tire would net me a slower forward speed than what the truck is calibrated for.
I appreciate the info. I read this forum a good bit before I bought the truck and I really expected it to have 4.10s or 4.30s instead of 3.91s. I guess if I really wanted to go with 4.30s, my first option would be to buy them used off some crazy wheeler here who moved on to bigger torqueier gears. I really don't want to lift the truck anymore than it is stock. It will honestly see dry pavement 97% of the time I drive it.
I think I am going to start off by eliminating the clutch fan and installing the flex-a-lite dual electric fans #210. If anybody else has any ideas about what diff's and gears I might run, please chime in. Since buying the truck, I don't believe my wife going to let me spend much money on it for several months. She said "Merry Christmas" to me when I brought it home.
Old 07-10-2005, 10:29 AM   #4
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
duhh, oops right...it sounds like your speedo is just off from the factory...or they put the wrong speedo gear in there. either way, it almost sounds like your truck got gearing and a speedo gear for 235 size tires rather than the 265s...very interesting.
doing the math, you can get your speedo more accurate by dropping to the 235s (BFG AT 235/70/16s are 29.1"). this will also bump your performance up to where it should be. ...really screwy on Toyota's part, sheesh. you'll lose 1/2" of ground clearance too but gas mileage will improve a tad.
If you don't want more lift then just upgrade your OE shocks to Bilsteins aftermarket line or OE replacements...waaaaay better shocks. Contact Demello or Wheelers for these. Also, keep an eye out here for a set of non-trd v6 front coils for cheep. they will give you a little bit if lift but no more than an inch and give a firmer ride and less body roll especially with the new Bilsteins
you can find 4.10s here for next to nothing but IMO it would not be worth the expense of regearing (labor and install kits) only to replace 3.91s with 4.10s.
since you can't spend much $, forget my last post, LOL, that will be major bucks modding
Old 07-10-2005, 06:46 PM   #5
pburruel
pburruel's Avatar
Default
I have a 2004 reg cab 4x4 and the stock gears are 3.91 and my tires are 265 70 16.
pburruel is offline   Reply With Quote
Old 07-11-2005, 04:59 AM   #6
wjfawb0
Default
My door jamb sticker says that my truck came with 15" wheels and 225 0r 235 tires. I'll have to take a picture...
Old 07-11-2005, 05:13 AM   #7
wjfawb0
Default
Wheels that are on it now:
Door jam sticker:
Old 07-12-2005, 12:10 AM   #8
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Once again Toyota dumps on the reg cab...dorks. I just can't figure out their convoluted reasoning on this.
Old 07-12-2005, 06:13 AM   #9
88toy4x4
88toy4x4's Avatar
Thumbs down
They didn't just dump on the regular cab. I think they dumped on most of all the 2.7 4cyl's. I mean who in their right mind would put 225/75/15's and 3.58 gears on a 4wd truck. I guess some people just "need" the 4wd to get over the speedbumps at the mall. Hang on, this is a big one!
Mine - 98 Taco ExtCab 2.7 5sp
Hers - 00 4Runner SR5 3.4 Auto 2wd
88toy4x4 is offline   Reply With Quote
Old 07-12-2005, 08:05 AM   #10
wjfawb0
Default
So, if I wanted to make the truck better equipped for driving in snow and some mud, but not really offroading over obstacles and such, what would be your alls suggestions for differential work? Limited slip rear, locker in rear? I am just afraid that I could get stuck in 8" of snow or something with my BFG Trail ATs and open differentials. Now that would suck.
I really need to understand the differences between 4L, 4H and 2H. Somebody correct me if I'm wrong:
2H = driving rear drive shaft
4H = driving rear and front driveshafts
4L = driving rear and front driveshafts at lower speed
Is the only advantage of 4L over 4H in low traction situations the lower gearing? How likely is it that I could get stuck in a snowy ditch this winter due to having open diffs?
Old 07-12-2005, 08:46 AM   #11
zosimov21
Crime and Punishment
zosimov21's Avatar
Default
wjfawb0 I've got some 04 front coils non TRD if your needing some. I just pulled them off to replace with OME's
04 Taco
Locked and loaded front and rear
Budbuilts / Chevy 63" springs / 285/75/16 AT
1980 1st Gen
Detroit Front / Welded rear
NC TTORA
http://www.ncttora.com/
Originally Posted by Dick Foster
No! If you can't understand that much I think you need to reenter the 1st grade and draw it up for yourself in crayon.
zosimov21 is offline   Reply With Quote
Old 07-12-2005, 08:49 AM   #12
zosimov21
zosimov21's Avatar
Default
The 4L will give you much better engine torque. Go in the grass and put it in 4L and Slowly accelerate you will feel it pull with more power vs 4H. If your truck still has the manual it's all in there
04 Taco
1980 1st Gen
NC TTORA
Old 07-12-2005, 10:54 AM   #13
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
Yes and Most likely... unless of course you stay outta the ditch!!! But even with a locker or LSD you could just bury yourself deeper if you don't know what your doing... But you won't know unless you try!!! You gotta test the abilities of your truck and learn more about what it can and cannot do... Just have a buddy standing buy with a recovery strap and you'll be fine...
I would recommend some good "extreme weather" rated tires for the snow though...
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is online now   Reply With Quote
Old 07-12-2005, 12:40 PM   #14
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Door jam sticker:
yep, and I bet the window sticker showed that they added a 'wheel/tire' pkg of the 265s as an option for several hundred bucks. What a stupid thing to do on Toyota's part, sheesh.
Old 07-12-2005, 12:41 PM   #15
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
does the door jam plate show 235s?
did the window sticker show your 265 tires as being a pricy option?
just currious.
Old 07-12-2005, 12:45 PM   #16
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
it's starting to look like they just added the optional tires and forgot about the fact that the truck was geared for the smaller meats as well as having a speedo gear that was for that same smaller tire size. I wonder how many have noticed just how far their speedo is off and complained to the dealer. ...and then, what the dealer did to "fix" the problem, hmmm.
Old 07-12-2005, 07:21 PM   #17
wjfawb0
Default
My wife rode beside me on the interstate the other day and her car indicated 75mph when mine was indicating 70mph. About a 7% difference. That means my truck probably has about 1400 more miles on it than the odometer indicates (~22,500). It'll of course screw my gas mileage calculations based on the odometer too. Fudge.
I think I'll go with what hytenor recommended when money permits:
"for what you describe I would go with the rear ARB (RD-89) and a Truetrac up front (LSD, pt #911A342). I ran this combo for about 2yrs and it was great for everything but the wilder rock crawling (why I swapped out to the front ARB).
Handling in snow, mud, etc was just as good as me current ARB."
Thanks for all the info everybody.
-Jason
Old 07-12-2005, 09:45 PM   #18
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
-Jason
find out what gear you have now. If it's more than a 30t you can swap gears for around $20 and at least get your speedo/odo back to normal.
http://www.norcalttora.com/~chris/mi...0drive%20gear/
takes about 5 minutes to figure out. the tooth count is stamped on the plastic gear. If you have a 28, however, you're screwed since that's the lowest count they have and you'll need one with 2 fewer teeth.
Old 07-13-2005, 07:17 AM   #19
wjfawb0
Default
Thanks again hytenor. I'll see if I can't look at it this weekend. Where should I look to buy a new gear if I have more than than 28 teeth? Toyota?
Also, where would you recommend picking up an ARB locker for the rear and Truetrac for the front?
Old 07-13-2005, 10:40 AM   #20
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
trdparts4u.com for the gear, pm me for the part #s
PORC for the lockers/gears, install kits, etc. check the sponsor's section.
be prepared for sticker shock on the ARB
Old 07-13-2005, 01:59 PM   #21
wjfawb0
Default
Thanks again. I am going to consult with my friend who builds 1000HP diesel pulling trucks and turbo setups for diesels tonight and pick his brain. He uses ARB lockers and said he had experience with LSD and locker installs that might help me make my decision. He's a heck of a tig welder and says he can fab rock sliders too. I'll update this thread once I do something to the truck.
Old 07-13-2005, 05:17 PM   #22
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
some slider sketches:
My and Dick Foster's designs.
http://www.norcalttora.com/~chris/mi...er%20sketches/
he has bling-bling stainless and mine are the cheapie sch-40 pipe type
tube is better than pipe for sliders though.
You may not post new threads
You may not post replies
Forum Jump
Traction Aiding Devices - Lockers, LSD, etc.... grillmasterp Early Tacoma Tech 9 09-20-2006 09:10 AM
gears & limited slip irish1 PreRunner Tech 3 06-16-2005 07:15 AM
TRD limited slip or Power Trax no-slip HeloDude Early Tacoma Tech 2 03-17-2005 09:48 AM
TRD Limited Slip BLOWOUT! TRDParts4U.com Sponsors Promotions 33 02-09-2005 05:59 AM
lockers and gears mattstaco Suspension 13 01-02-2005 12:24 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
