Go Back   TTORA Forum > General Tech > Interior/Electrical/Electronics
Thread Tools Display Modes
Old 07-13-2005, 03:06 PM   #1
hawaiianbro
River Rat
hawaiianbro's Avatar
Send a message via AIM to hawaiianbro
Default 6 x 9's In Rear of Taco?
Just wondering if anybody has tried fitting 6x9's in the stock rear speaker location. I have some nice Infinity Reference speakers just sitting here from my old civic.
Thanks,
Kaleo
05 Taco - SAC'd HPD44 - F.O.A. Coilovers - Armored and Locked.
99 Cummins - Workin towards 1,000lbs Torque
05 GSXR 750 - 20th Anniversary - My Coffin
I'm Brown And I will Rule The World One Day.
hawaiianbro is offline   Reply With Quote
Old 07-14-2005, 01:53 PM   #2
zosimov21
Crime and Punishment
zosimov21's Avatar
Default
If it's an extended cab they are already 6x9.(at least on my 04) You'd have to remount the factory clips to new speaker.
04 Taco
Locked and loaded front and rear
Budbuilts / Chevy 63" springs / 285/75/16 AT
1980 1st Gen
Detroit Front / Welded rear
NC TTORA
http://www.ncttora.com/
Originally Posted by Dick Foster
No! If you can't understand that much I think you need to reenter the 1st grade and draw it up for yourself in crayon.
zosimov21 is offline   Reply With Quote
Old 07-14-2005, 01:59 PM   #3
absolut taco
absolut taco's Avatar
Default
I haven't looked at mine but I thought they were 6.5"...I have a sweet pair of old Boston Acoustic 6x9 that I want to use...
2004 Tacoma Extended Cab 4x4 TRD | 3.4 Liter V6 | 5-speed manual
absolut taco is offline   Reply With Quote
Old 07-14-2005, 03:05 PM   #4
hawaiianbro
River Rat
Default
I'm pretty sure my 98 has 6.5"'s in the rear. I was just wondering if anyone has put 6 x 9's back there.
Old 07-14-2005, 04:34 PM   #5
Toyotajoe
Toyotajoe's Avatar
Default
My '98 ECab has the 6.5" rears...
Toyotajoe is offline   Reply With Quote
Old 07-14-2005, 04:47 PM   #6
nilson
nilson's Avatar
Send a message via AIM to nilson Send a message via Yahoo to nilson
Default
Later model Tacos come stock with 6x8s (I believe 01-04?) but I hear that with minor plastic trimming that 6x9s will go.
1996 4Runner Limited / 3.4L V6 / 4x4 / E-Locker / 204,000mi and counting
2005 Honda CRF250R
nilson is offline   Reply With Quote
Old 07-14-2005, 11:22 PM   #7
KempoStyle
KempoStyle's Avatar
Default
I have a 98 x-cab and put eclipse 6x9's in the back. I basically took the factory speaker guard and traced it onto a 3/8" piece of wood. Then cut it to fit where the factory speaker guard use to be and cut out the middle for the speaker mounting. This gave me enough backspacing to mount the speaker from the front. I then screwed the wood directly into the pannel and mounted the speaker on the wood. You can run a router around the edge to smooth it out.
Looks nice and no screws are visible.
KempoStyle is offline   Reply With Quote
Old 07-15-2005, 12:48 AM   #8
hawaiianbro
River Rat
Default
Sounds great! Do you have any pics of the install or what it looks like now?
Much appreciated!
Kaleo
Old 07-15-2005, 01:41 PM   #9
KempoStyle
KempoStyle's Avatar
Default
Hawaiianbro, These are the picts I have of the install. Sorry bout the quality, but that's what I get with a camera phone.
I did the install about 3 years ago with some scrap wood from a shelving project. I know it doesn't match, but the idea is there. Been meaning to redo it and make it match.
I took some rough measurements and it looks like the dimensions are 9 1/2" x 9 1/2" for the total size. I used 3" screws to attach to the inside of the panel and attach the speaker to the wood. I recommend flat head.
There are 2 screws that hold the wood to the panel. I placed them top and bottom with a countersink so the speaker would hide the heads and mount flush.
I then attached the 6x9.
I have a slight overhang of the 6x9 on the sides. Nothing that affects the seal/performance of the speaker.
I've haven't had any problems with this install. Hope this helps
Name:	6x9 instal without speaker.jpg
ID:	1146   Click image for larger version
Name:	6x9 install.jpg
ID:	1147   Click image for larger version
Name:	6X9 Finish.jpg
Old 07-15-2005, 01:51 PM   #10
TRD SyRuP
Send a message via AIM to TRD SyRuP Send a message via MSN to TRD SyRuP
Default
you know youre a redneck when...
TRD SyRuP is offline   Reply With Quote
Old 09-05-2005, 07:55 AM   #11
sploosh
sploosh's Avatar
My Rig: 2001 Tacoma
Default
It's got that nice wood grain accent.
2001 Tacoma, slightly modified
sploosh is offline   Reply With Quote
Old 09-06-2005, 11:05 AM   #12
TacoRat
TacoRat's Avatar
Default
Git'er dun!
TacoRat is offline   Reply With Quote
Old 09-06-2005, 11:38 AM   #13
J*C*M
J*C*M's Avatar
Default
Most stereo shops are going to do the same thing, except they'll wrap the wood in carpet first then over charge you for a "custom" job... If you cut the wood down so Just about a 1" oval, so it doesn't stick out past the speaker on the sides, then just wrap a strip of carpet all the way around it looks ok, on the cheap
2005 4X4 Access Cab 2.7 Locked and Lifted on 285/75's
J*C*M is offline   Reply With Quote
Old 09-06-2005, 05:18 PM   #14
AngryAndy
AngryAndy's Avatar
Send a message via AIM to AngryAndy Send a message via Yahoo to AngryAndy
Default
Thanks,
Kaleo
Hey Kaleo....
I put 6x9's in the back of my xcab...it was the first mod I think I did. If your in the area this week, or are going to Barney RIley, I will be glad to pop off the grill and show you my ghetto hack job....I seem to recall using a dremel, and cutting out the existing plastic piece....and turning the speaker so it sits at a 45 degree angle. It fit in there, and with the stock grill back on you cant even tell its in there.
"Soupbowl Challenge Winner 2006"
1997 Xtracab SAS Tacoma
1989 SAS 4runner "Project Angry"
2007 FJ Cruiser
AngryAndy is offline   Reply With Quote
Old 09-06-2005, 05:21 PM   #15
hawaiianbro
River Rat
Default
lol mine are also ghetto rigged....but they are in a box sitting on the back seat.
I'll check em out at barney.
kaleo
Old 09-07-2005, 12:22 PM   #16
george.arnold
george.arnold's Avatar
Send a message via AIM to george.arnold
Default
if you go to crutchfield.com and go to the section "What fits my car?" you can enter in your year and model and it will tell you everything that fits in what location. hope that helps
george.arnold is offline   Reply With Quote
Old 09-08-2005, 04:06 PM   #17
audiofreak97
audiofreak97's Avatar
Send a message via Yahoo to audiofreak97
Default
I think the size is 6.75 for all 4 speakers. I have 5x7s in the rear, and they fit using only two screws to hold them in without any modifications to the grill or mounting hole. If I remember exactly, but I think the mounting hole for the speaker will unscrew without taking the whole back end apart (if that makes sense). Good luck with it!
audiofreak97 is offline   Reply With Quote
Old 09-08-2005, 04:11 PM   #18
hawaiianbro
River Rat
Default
thank you captain obvious
just messin with ya, but i had these 6 x 9's sitting in my room after i had totaled my rice rocket. they are really good speakers so i decided to throw them in the taco. they sure sound great! but take up a little more space than i wanted them to.
You may not post new threads
You may not post replies
Forum Jump
Stock Rear Leaf Springs for '98 Taco drewcruikshank Wanted 9 08-01-2005 12:21 PM
need ABS taco rear axle shaft Mace Wanted 10 07-14-2005 01:26 PM
4" lift taco rear springs and rs9000x shocks FS: oztaco Parts/Electronics/Wheels & Tires For Sale 9 04-24-2005 06:46 AM
Rear end clunk (not axle wrap?) BajaTaco Early Tacoma Tech 28 04-07-2005 05:30 PM
Taco rear end kyle Wanted 4 03-27-2005 08:08 AM
Privacy Policy
Links monetized by VigLink
