Sponsored Ad
Go Back   TTORA Forum > General Tech > Suspension
Thread Tools Display Modes
Old 06-08-2009, 08:31 PM   #1
razr
razr's Avatar
Default Stock length Total Chaos lower a-arms for 05+
http://chaosfab.com/96505.html
http://chaosfab.com/what.html
razr is offline   Reply With Quote
Old 06-08-2009, 09:19 PM   #2
BLACKHAWK250
BLACKHAWK250's Avatar
Send a message via AIM to BLACKHAWK250
Default
holy shit!!! Thats sick i didnt know about that, they dont make it for the old tacos do they?
BLACKHAWK250 is offline   Reply With Quote
Old 06-08-2009, 10:52 PM   #3
razr
razr's Avatar
Default
Not sure I see the purpose of it. Other than it looks cool.
Old 06-08-2009, 11:01 PM   #4
BLACKHAWK250
Default
Mabey more travel like the UCA's? Its uniball so it sounds like the uper control arm. I wonder if it will be as beneficial tho.
Old 06-09-2009, 12:32 AM   #5
brock
brock's Avatar
Send a message via AIM to brock
Default
uniball on the lca wont give u more travel... in fact i think that balljoints have a better range of motion, might be mistaken though. uniball is stronger though.
| 2005 Tacoma | Total Chaos LT | Richer Racing 62s | BBR Bumpers |
brock is offline   Reply With Quote
Old 06-09-2009, 01:21 AM   #6
SinCityTaco
Default
Well I know that when you only replace the UCA it moves the tire way far back into the wheel well, enough so that a 285 will rub badly under compression on the rear of the fender flare and it also looks weird with the tire not being centered in the wheel well. They have to do this though to get the proper amount of caster.
I wonder if these compensate for that by moving the tire back forward more, then thought here would be like 8 degrees of caster which would be ridiculous.
What the hell is the point of them other than looking badass. I would rather have an all pro mid travel kit than a stock length TC control arm kit.
SinCityTaco is offline   Reply With Quote
Old 06-09-2009, 02:01 AM   #7
elenex50
elenex50's Avatar
Default
Doesnt seem to serve a purpose other then converting to a uniball and urethane bushings. Stock length arms? Why not just save a little more money and go full LT. Maybe just a new component to the upper arm and bolt in C/O to fake like you got something crazy. Maybe this will work with class 7 trucks.
01 tacoma.
08 prius.
elenex50 is offline   Reply With Quote
Old 06-09-2009, 10:14 AM   #8
razr
razr's Avatar
Default
If this is the case,woundn't they have to redesign the upper arms? Because the uca already compensates the caster.
Exactly, for the price ( you know it aint going to be cheap) why not go 2'' or 3.5'' long travel?
Old 06-09-2009, 10:48 AM   #9
devinsixtyseven
devinsixtyseven's Avatar
Default
SinCityTaco, check your alignment...I bet it's wrong. The hub is closer to the LBJ than the UBJ, and caster is adjusted with the lower arm, so #1 I suspect your alignment is screwed up and #2 I also suspect that once it's fixed, you'll have plenty of clearance.
There's a longer, better explanation, but if you happen to have the alignment sheet from the alignment after you installed the new parts & can post the "current" numbers, any number of people here can say whether it's correct or whether you need to find a different shop to adjust the alignment.
Kinda curious about the market for these arms. If you're gonna buy one of these arms, why not just buy an arm 3"+ longer, with a new upper arm to match, tabs and plates for bypass & bumps, and a set of longer coilovers?
-Sean
'00 Project, constant state of (d)evolution
Originally Posted by Atilla the Tundra
That will sound like godzilla throwing schoolbuses full of screaming children into a wood chipper. Have fun with your fix it tickets!
"Tonight, you are going to hear...music you've never heard before. Tonight...you are going to hear...the most cantankerous, poisonous, roughneck dubplates ya ever HEARD!"
devinsixtyseven is offline   Reply With Quote
Old 06-11-2009, 12:40 PM   #10
razr
razr's Avatar
Default
It's expensive too. The "blue roomers" are all hyped up about it.
http://www.fjcruiserforums.com/forum...ml#post1417054
http://www.fjcruiserforums.com/forum...ntrol-arm.html
Old 06-11-2009, 01:06 PM   #11
NwiTACO
My Rig: 2005 TACOMA DCSB
Default
Waste of money. Let the jellybeans have them, most of them are douchebags anyway
Blue Ribbon Coalition #4847
'05 Tacoma DCSB, 35/12.5/17 MTR's, Rear Disc Brakes, ARB's F/R, Fox C/O's & Airbumps up front w/ All-Pro LT, 14" 7100 resi's/63" Chevies in back, full tube bed, Hella 500 w/ HID conversion, XRC 8000# winch, Dual MV50 On-board air
'02 Tacoma DCSB, OME 881's, Dakars, and Nitrochargers
Former InTTORA President - 2009-11
NwiTACO is offline   Reply With Quote
Old 06-11-2009, 01:18 PM   #12
Ebruddah
Ebruddah's Avatar
Send a message via AIM to Ebruddah
Default
True that they're just a bunch pretensious bastards who always want the biggest, baddest, latest and greatest shiny new thing that appears on the market! Do they actually wheel their well modded and equipped rigs... God forbid they get dirt on their rigs or much less some rocks on an acutal trail.
2005 Tacoma V6 SR5 - 4WD AC TRD Off Road - 6 Speed M/T: ARB Bull Bar, SuperWinch 9.0 EPI, Total Chaos UCAs, IVD Coilovers, OME rear shocks & Dakars, Optima YT, Yaesu FT-2800, Cobra 29, BudBuilt IFS Skids, 285/75/16 Goodyear MT/R Kevlar on MB Wheels 72s, All-Pro Sliders & rear bumper, 10 lb. PowerTank with HPX Regulator
Ebruddah is offline   Reply With Quote
Old 06-12-2009, 12:56 AM   #13
SinCityTaco
Default
-Sean
My toe was set to: 0 degrees
my camber was set to: 0 degrees
my caster was set to 3 degrees
I ended up taking them off and selling them because I could not stand how far back my wheel was in the wheel well. It rubbed terribly even though I cut off half the damn fender and fender flare. Under compression the tire would rub half way up the fender flare. I put my stock arms back on and all is good now, I just have a tad bit of positive camber, but better than losing 1/2 inch of wheel base.
Old 06-12-2009, 01:06 PM   #14
razr
razr's Avatar
Default
You had TC arms? What size tires?
Old 06-12-2009, 08:02 PM   #15
06silverback
Default
the uniball would be stronger than the stock ball joint. looked at replacing them and from toyota they come as a unit WITH the LCA....checked at O'Reilley's and they said they could get the MOOG's that can be pressed in for about $55/ea. guess this just gives everyone one more (expensive) option.
2006 DC Tacoma: LC-60 Hybrid front, 3 linked with 18" ORI's, LC 9.5" 3rd in RuffStuff housing, double triangulated 4-link, 16" Ballistic Fab CO's, Summit 20 Ga Cell, removable tube bed with LED's
06silverback is offline   Reply With Quote
Old 06-12-2009, 11:08 PM   #16
dtrujillo63
dtrujillo63's Avatar
Default
I dont care what any says, these look BADASS!!! Think about how much stronger these are...
08 Tacoma Long Travel (Expo Rig)
94 F250 7.3 Turbo Diesel (Tow Rig)
84 4runner (Rock Crawler)
dtrujillo63 is offline   Reply With Quote
Old 06-13-2009, 01:39 AM   #17
SinCityTaco
Default
Yes I did have TC UCAs. I was running 285/70/17 BFG ATs
Old 06-13-2009, 02:09 AM   #18
brock
brock's Avatar
Default
i have yet to see a broken stock lca.
Old 06-13-2009, 12:11 PM   #19
06HAOLE
06HAOLE's Avatar
Default
These make sense for a more DD friendly offroad market. For the money I would never go this route.
But with this you dont need fiberglass/paint or axles and you get to play for at least $1500 less than a full blown LT kit w/o having to worry about shock hoops/fabrication blah blah etc etc.
Besides now people can choose between All-Pro and Total Chaos. I wonder which one people will buy more of or have less problems with?????
2006 Tacoma 4x4
BFG / King / Total Chaos / Walker Evans / Soltek / DMZ / Currie / Wilwood / BMS / Defined Engineering (SOLD March 2011)
2012 Tacoma 4x4
Nice DD w/BFG ATs
06HAOLE is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Total Chaos Front Lower Control arm stock replacement E-ROCKER Wheels/Tires/Suspension 23 02-22-2011 01:57 PM
New Total Chaos Trailing arms BLOWNYOTA Long-Travel Suspension Tech 8 07-18-2007 08:06 AM
Donahoe Racing Coilover and Total Chaos upper arms 02TacoRunner Wanted 1 02-01-2006 10:19 PM
Total Chaos Upper Arms str8xedge Parts/Electronics/Wheels & Tires For Sale 12 03-14-2005 11:55 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
