Idler pulley rebuild - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 07-08-2009, 02:13 PM   #1
fast frank
fast frank's Avatar
My Rig: 2001 Tacoma 4X4 Dcab
Default Idler pulley rebuild
You guys know about the idler pulley.
It's down there on the bottom, and it'll die if you get in the mud. It will also give up after about a zillion miles or so of street driving, and that's why I'm messing with this one.
So if you go to the dealer he wants like 40 bucks or so, and Vato zone is less but still too much.
That's horse shit. There's nothing wrong with the pulley. It's the bearing that goes bad.
So here's how you fix that.
Take the pully off of the motor, and drop it on your work bench.
Grab your snap ring pliers and pull that clip out.
Use a drift of some sort and a hammer, and drive the bearing out.
After washing the gunk off, you will be able to see a number on the bearing.
In this case, that number is 6301.
Here's the tricky part. The little girl selling parts at Vatozone won't know how to find a ball bearing. That's WAY too complicated for her.
But at the motorcycle shop, there's a good chance there's somebody that can find you a bearing because it's a normal thing for them.
I got mine out of stock.
Compare the new bearing with the old. If it's the same (And it will be if it's the same number) you're good to go.
This one sells for $8.25. That's the right price for a repair, huh?
Drive the bearing in, using a socket or something. Be careful that you don't crush the seal (The plastic part).
Pop that snap ring back in there and you're good to go.
Put that extra $20 or $30 in your pocket, and go wheeling.
Have fun!
2001 Double Cab V6 Auto Tranny 4WD TRD Offroad.
Bone Stock and Loving Every Minute Of It.
fast frank is offline   Reply With Quote
Old 07-08-2009, 05:55 PM   #2
terryj5
15 Year Member Club
terryj5's Avatar
Default
Good to see a nice fresh write up on this subject. All I can add is, get the highest grade bearing you can find. There are 5 grades readily available. Grade 5 or "electric motor" grade is the best. I have found grade 1 (made in China), for $5.95 and grade 5 by SKF (France) for $16, both from the same industrial supply store. The difference in tolerances and quality was obvious. I would guess the OEM is a grade 2 or 3.
I Have Never Been Lost, Only Temporarily Without Orientation
Wheeling Toyotas Since 1980, Latest A 99 V6 TRD EXCAB and the wife's 08 4R
terryj5 is offline   Reply With Quote
Old 07-08-2009, 06:53 PM   #3
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
Default
Very nice find! Cheap tricks section!
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is offline   Reply With Quote
Old 07-08-2009, 07:14 PM   #4
Red2003
Red2003's Avatar
Default
I had a similar problem years ago with my 92 22RE. They wanted to sell me the entire assembly for something like $200 when this guy came out of the shadows and said hold on I can get the bearing you need for less than $10. He comes out with this part (90099-10091) and says this part # is for such & such(don't remember what it was for)but is the same bearing. It worked perfect.
Edit: Yes that is a original Toyota part # for a bearing that will work on an idler pulley for a 22RE engine.
2015 Tacoma Double cab 4x4 TRD Off-Road
Red2003 is offline   Reply With Quote
Old 07-08-2009, 08:21 PM   #5
yota fan!
yota fan!'s Avatar
Default
This is a nice write up, Is this what creates the squeekish like sound on the 3.4 while idleing? it is also variable depending on motor speed? My 3.4 squeeks and if it is just gonna be about $10 to fix it I will Thanks!
1997 Tacoma, Standard Cab, v6, 5spd, 4x4.
PIAA 520 fogs up front
Scan GaugeII mounted in my dash
Shell, it helps to cover stuff.
2.5" DR coil spacer up front and a home brew 5 leaf in the rear.
yota fan! is offline   Reply With Quote
Old 07-08-2009, 09:33 PM   #6
TaWComA26
TaWComA26's Avatar
My Rig: 2002 Double Cab
Default
Seriously great write up. And this has to go in the cheap trick section. I gotta take a look at mine... See what kind of shits there.
02 2.7 D Cab aka "Stuck Machine"
32's, lifted
00 R6 "Blue Devil" for sale
Faster than your R1
TaWComA26 is offline   Reply With Quote
Old 07-09-2009, 08:42 AM   #7
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
You can diagnose it to see if this is the issue by removing the idler pully, squirting some oil on it, and reinstalling.
It'll eventually come back, so it's no permanent fix!
W6FTW
Old 02-15-2010, 06:38 PM   #8
SAR_Squid79
THAT guy.
SAR_Squid79's Avatar
Send a message via Yahoo to SAR_Squid79
Default
Well - since my idler pulley got mud in it, and shit the bed and snapped my A/C belt this weekend, i figured I'd bump this back up, since I'll be trying to get this knocked out this weekend.
Maybe this would be a good time to do my URD Crank Shaft Pulley too.
~Jamie
2000 Tacoma TRD 4WD PreRunner
Supercharged. Locked. Armored.
Mountain: She can crawl it.
Ass: She can haul it.
"Roads? Where we're going we don't need . . . roads."
~Dr. Emmett L. Brown
My Rig My Trailer 4xInnovations
SAR_Squid79 is offline   Reply With Quote
Old 02-15-2010, 08:40 PM   #9
wslytoy
I just got laid... off.
wslytoy's Avatar
Default
This is good shit! This needs to be stickied.
New(to me):
2006 Sport Edition 4WD 4Runner
2.5" Bilstein 5100 in front
1.5" spacer out back
265/75R17 Mickey Thompson ATZ's
Eagle Series 140 in 17x8
OLD:
05' TRD 4x4
96' Tacoma 2.7 Ext Cab 5spd w/ a mod or 2
85' 4Runner Build Up Thread
wslytoy is offline   Reply With Quote
Old 02-15-2010, 10:11 PM   #10
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
Note for anyone having problems finding this bearing, you can get it at any online supplier that gets from Tucker Rocky Distributing.
The PN from TR is 41-6301
It's also available through Parts Unlimited, Same PN, 41-6301
An example is Thumpertalk. Much cheaper than the OP's price.
http://shop.thumpertalk.com/ProductD...Code=TR_416301
$4.23
A lot of dirtbike shops use PU or TR to get parts...
W6FTW
Old 02-16-2010, 10:53 AM   #11
SAR_Squid79
THAT guy.
Default
Stoopid noob question...
You have to pull all the other belts to replace the AC one, right?
~Jamie
Old 02-16-2010, 11:06 AM   #12
wslytoy
wslytoy's Avatar
Default
Yep ... The good thing about multiple belts, if your AC belt breaks, your alternator still works, your power steering still works. The bad thing... you gotta pull all those belts to get to the AC.
New(to me):
OLD:
05' TRD 4x4
Old 02-17-2010, 07:19 AM   #13
DocMcCoy
Canada Toyota 4 Wheel Drive
DocMcCoy's Avatar
My Rig: '98 Tacoma
Default
Pretty sure AC is the second of three. Just pull the power steering belt and the AC. Leave the alternator belt. At least that's how I remember it on my truck after replacing that pulley with one from NAPA three times last year. I'm gonna go get some bearings today.
White '98 TRD Extended Cab
Custom YotaFab Bumper, 10,000lb Superwinch, Lightforce Striker 170s, 35" BFG KM2s
Icon Coilovers, Total Chaos UCAs and Spindle Gussets, Alcan Springs, Bilstein 5150s
Manual Hub Conversion, Tundra Calliper Upgrade, Brembo Drums, SS Brake Lines
Fenders Cut, Bed Bobbed and Painted White
CT4WD Team - "See you on the trails!"
DocMcCoy is offline   Reply With Quote
Old 02-17-2010, 11:15 PM   #14
HB Taco
Default
Great Info!
HB Taco is offline   Reply With Quote
Old 02-18-2010, 04:50 PM   #15
Rob.hall
Default
I replaced a pulley about two years ago, and I swear I only paid like $17 for the whole damn thing...
'99 TRD 2.7l 4x4- pacesetter header, donahoes, camburg UCAs, deaver 8s with bils 5100s, pro comp 8069s wrapped with 32" STTs, custom prerunner bumper, and some other random shit
Rob.hall is offline   Reply With Quote
Old 03-14-2010, 06:50 PM   #16
SAR_Squid79
THAT guy.
Default
Fast Frank:
I hope you realize how fortunate you are to have a parts place where you can walk in, and browse the shelves of parts your self!
I went to 2 different SoCal Motorcyle / "Power Sports" shops today, and go nowhere!
At both places the guy behind the counter couldn't help me because I didn't know what kind of bike this bearing was for - and they couldn't type it into the computer. They were both puzzled by the fact that I didn't actually need the bearing for a bike. Neither shop would just take my bearing, go into the back, and visually look to see if they had a matching replacement.
Apparently - basic knowlege about auto parts is not required to work the parts counter of a parts store...
I had to order the bearing online:
Bearing - $3.99
S&H ---- $4.48
~Jamie
Old 03-14-2010, 10:27 PM   #17
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
You should have been able to give them the number for the Parts unlimited catalog, and the should have been able to pull it up. It's how I order parts 90% of the time anyways!
W6FTW
Old 03-16-2010, 10:46 AM   #18
hossmaster
MASTICATOR
hossmaster's Avatar
Default
Fast Frank:
Bearing - $3.99
S&H ---- $4.48
same thing for me down where I live.
02 dbl cab 2.5 dirt logics Just another wanna be
"we had us some fun"
"Blue Water Inn, We Got Pyramids!!!"
hossmaster is offline   Reply With Quote
Old 03-16-2010, 12:00 PM   #19
yota fan!
yota fan!'s Avatar
Default
What type of oil would you recomend? It seems like wd-40 would just make it squeek more. Sorry for the noob question.
Old 03-28-2010, 07:55 AM   #20
yota fan!
yota fan!'s Avatar
Default
Thought i'd give this a bump to the top because I'm doing it today. I got the same "all balls" bearing as the op from a local bike shop for $5.24, It was the last one they had in stock.
p.s.
How often do you guys change your ps,ac and alt belts?
Old 03-28-2010, 08:42 AM   #21
yota fan!
yota fan!'s Avatar
Default
Does anyone have any good pics of where their idler pulley is? I thought i knew but now I'm questioning myself I dont wanna fuck up my timing belt
Old 04-08-2010, 12:53 PM   #22
mgyver1
mgyver1's Avatar
Default
X2.
Yeah if someone could explain the process of removing it too that'd be good.
Mgyver1
Nevada TTORA
4X4HIM
Best In The Desert Racing Association
'02 Ext. cab Prerunner V6 Auto SR5 TRD
mgyver1 is offline   Reply With Quote
Old 04-08-2010, 02:17 PM   #23
PismoJoe
PismoJoe's Avatar
My Rig: 2002 Tacoma
Default
Idler Pulleys are present wherever there is a belt that is tensioned by it. In other words, they are used to adjust belt tension. They are NOT present on some alternator and A/C compressor pulley setups.
We will be referring to the 22RE because, well, its simple!
Sorry for the bad picture, but she will do.
This is a picture looking down at your power steering belt, however, this setup is pretty much the same as any belt that is tensioned by an idler pulley.
I like room to work, so I take a few extra steps.
1. Remove fan shroud. 4 Bolts hold it to the radiator
2. Remove Fan Clutch. 4 Bolts hold it to the crank pulley
3. Loosen and remove the pulley tension bolt
4. Loosen and remove the bolt that holds the idler pulley on. careful not to drop the bolt that the tension bolt goes into on the backside of the pulley. Pay attention to how the washers are placed.
5. Push the pulley to the right, so you can slip the PS belt off.
6. Pull the pulley out
7. Replace bearing as described in previous posts in this thread
8. Installation is the opposite of dis assembly.
9. Make sure you tension the belt as specified in the FSM
PismoJoe is offline   Reply With Quote
Old 04-08-2010, 02:48 PM   #24
shocktaco
shocktaco's Avatar
Default
I have 2 of these bearings. If anybody is interested
sorry for the thread jack
Sway-bars are like condoms. Its safer with it on, but it feels way better with it off
shocktaco is offline   Reply With Quote
Old 04-08-2010, 05:06 PM   #25
DocMcCoy
DocMcCoy's Avatar
My Rig: '98 Tacoma
Default
In a v6 Taco ... the A/C idler pulley is the one with the A/C belt connected to it that is not the compressor itself. No help?
Well, it's that little fooker down at the bottom that I keep having to replace. It is the bottom most pulley and it is connected to the second belt in. On the sixer.
Old 04-08-2010, 05:25 PM   #26
freejake3
freejake3's Avatar
Default
I replaced mine but instead of the idler bearing that was making the noise its the AC COMPRESSOR PULLEY/BEARING. Any idea of how I replace the bearing inside of that pulley. Thought I saw a write-up at one point on this one. SOrry for the hi-jack.
Surf to Live - Live to Surf
'99 Taco 3.4 with some goods
'95 4Runner 3.slow with some goods
freejake3 is offline   Reply With Quote
Old 04-08-2010, 07:19 PM   #27
SAR_Squid79
THAT guy.
Default
Originally Posted by mgyver1 View Post
X2.
http://www.ncttora.com/fsm/2003/Repa...ribel/remo.pdf
http://www.ncttora.com/fsm/2003/Repa...ribel/inst.pdf
~Jamie
Old 04-08-2010, 10:21 PM   #28
mgyver1
mgyver1's Avatar
Default
Well just replaced the bearing in the idler pulley. Do you know if the bearing in the AC clutch is the same? And how do you remove that. The bolt is a 10mm, but when I try and turn it the flywheel just spins. Also I see the ft lbs for the idler pulley is 29lbs, what about the ac compressor pulley?
Mgyver1
Nevada TTORA
4X4HIM
Old 12-14-2010, 06:18 PM   #29
fishingorwishing
Default
I had to get some bearings and seals for my boat trailer a whille back. Being that the trailer was built in 84 all I had to go by was bearing numbers. I don't know about all places but in Portland,OR there is a place that does nothing but bearings believe its called mcguire bearings. So if you can't find at motor cycle shop you probably google and find a place like this in most major metropolis.
98 v-6 ext. cab Manual
3" Toytec lift
Bilsteins
2.5" inch cat and exhaust
flowmaster
K&N intake
fishingorwishing is offline   Reply With Quote
Old 12-14-2010, 07:21 PM   #30
pittim
Default
Mine was completely shot, so I put a new one in, and after the first trip out its startin to make noise again. I'm about to axe the AC all together...don't really need it in PA.
pittim is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
AC idler pulley darwink1 Performance/Engine/Exhaust 10 09-18-2008 10:07 PM
idler pulley sicki Newbie Tech 5 07-25-2008 08:25 AM
where to buy a/c idler pulley billy rolfe Performance/Engine/Exhaust 6 01-29-2008 09:48 PM
URD S/C idler pulley TimF Performance/Engine/Exhaust 0 01-22-2007 06:13 PM
A/C Idler pulley going bad? Chargedtaco01 Early Tacoma Tech 1 12-11-2006 01:42 PM
