Fit
how? Sounds like you're not shy in the garage, if you have an 85 you're building...
First option is the drop bracket...personally I wouldn't go that route, but many have, works fine. More belly clearance than the next option, but you gotta choose between spotting the support bars through the rocks, or considering the torque on the frame of an unsupported drop bracket.
Then there's the coilover/spacer/whatever plus a body lift...that's less expensive, works fine as well. Same clearance everywhere as stock plus two inches from the tires.
IMHO the best solution involves a couple cutting tools and a welder. You can pull the fenders, take care of everything, put it back together with some Herculiner in the wheel well, and it'll look stock but with 35" tires. You'll also tear the screws right out of the fender flares when you flex
You'll need 16x8 wheels with 3.5" backspacing or so, to keep the tires from rubbing the frame. I ran 16x8@4.5, with 1.5" wheel spacers, for years, on and offroad.
Add fiberglass fenders, trim them back about an inch, and you'll have no problems clearing the tires.
Looks about like this when you're done.
You won't need any lift, but I found the best ride height was about 3" over stock, with a set of uniball upper arms. Get the Camburg arms. Wish I had. That oughtta give 5" up, 5" down, and keep the truck off the bumpstops when you come down ledges or hit the bigger g-outs and chunks on the trail.
Add a basic LT kit and it only gets 2" wider, cuz you can lose the wheel spacers up front, and everything fits great.
-Sean
