Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 09-02-2009, 07:49 PM   #1
Wheelin taco2131
Wheelin taco2131's Avatar
Default Control arm bushings
So i have had constant popping in my front end for about a year. I figured it was the rack, but i replaced it and still there is popping. I traced the popping to the control arms. I called toyota and they said the control arm bushings are pressed into the arms and you cant replace them. You have to order new control arms. Yet day star makes poly bushing kits for $85 so there must be a way. Can someone please shed some light on this for me?
also if i choose not to do anything with them, will the worn out bushings effect the trucks ability to hold an alignment?
D cab tacoma, hybrid fabtech 6" with custom deaver leafsprings, 1" reloaction plate, bils in the rear, 37 mtr's, 4.88's, 14" magnaflow dumped, AFE cold air intake, full cbi protection, wheeler type b's, tom woods shaft,compressors, 5 gal tank with train horn, yellow top, lights, skid
1980 truck build in progress d60's and airshocks to come
Wheelin taco2131 is offline   Reply With Quote
Old 09-02-2009, 08:08 PM   #2
Logan
Logan's Avatar
Default
http://www.tacomaterritory.com/forum...ol+arm+bushing
07 Taco with a couple things here and there
Logan is offline   Reply With Quote
Old 09-03-2009, 12:31 PM   #3
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
You can replace the stock bushings. They are pressed in so to keep the stock rubber bushings, you have to press out the old and press in the new. This is the expensive way to go, but what I would recommend. Another option is to find used control arms. Swapping in poly bushings is a bad idea unless you can keep them lubricated. I installed the poly kit and the bushings were worn out in less then 100k miles.
Next Socal TTORA event - Miller Jeep Trail - June 22
www.ttora-socal.com
TTORA-Socal on Facebook
ShowStop is offline   Reply With Quote
Old 09-03-2009, 07:26 PM   #4
Windtech007
Windtech007's Avatar
My Rig: 97 tacoma 4x4 ext
Default
next time I decide to change control arm bushings, please, someone kick me in the nutts over ond over. PLEASE!!!!!!!!!!!!!!!!!!!
Windtech007 is offline   Reply With Quote
Old 09-04-2009, 09:32 PM   #5
richieiscool
richieiscool's Avatar
Default
did you check your ball joints?
put something sweet here
richieiscool is offline   Reply With Quote
Old 09-05-2009, 01:00 AM   #6
Windtech007
Default
no but if I get kicked in the nutts then I will.
Old 09-05-2009, 04:01 PM   #7
00regcab
00regcab's Avatar
Default
Ive got a set of poly bushings form poly performance BNIB, uppers/lowers, black poly.
$50 shipped, if you want them.
00regcab is offline   Reply With Quote
Old 09-05-2009, 07:26 PM   #8
Windtech007
Default
Damn!!! that pisses me off. I had forgotten what the damn things cost me.
Old 09-05-2009, 09:12 PM   #9
tacoma_2002
tacoma_2002's Avatar
My Rig: 2002 Tacoma
Send a message via Yahoo to tacoma_2002
Default
I've noticed a slight "pop/bump" in my front end for about 2months now...Ball joints upper/lower are new (upper about 5k and lower about 1k). TRE's all tight...replaced old coilovers with Fabtech....still a little bit of a bump....checked sway bar connections and all are tight....
I'm going to d/c the sway bar next week and check my UCA and LCA bushings...if they're bad it gives me a REALLY good reason to upgrade...
Camburg....
2002 Xtra Cab TRD Taco 3.4 Manual
Super White 2
Lifted, Locked, Armored
2007 Double Cab TRD Taco 4.0 Auto
Silver Streak Metallic
2.5 SAW's, 2.0 Icons rear with Deaver pack
Originally Posted by SafetyDang View Post
Look at my picture I posted you can see that you may need 2-3 more inches.
tacoma_2002 is offline   Reply With Quote
Old 09-07-2009, 10:44 PM   #10
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
Default
I've got upper and lower Control arms with the lower ball joint...
May be a bit pricey to ship though
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
FS: Polyurethane Control Arm Bushings 00regcab For Sale/WTB in CO 11 09-09-2009 12:33 AM
Control arm bushings hostile Newbie Tech 2 07-06-2009 11:17 AM
Control arm bushings? bry418 Newbie Tech 7 06-17-2009 12:49 PM
Lower Control Arm bushings tacomaman87 Tech 0 10-21-2007 08:56 AM
Control Arm Bushings ???? TacoManny98 General Discussions 11 02-13-2006 08:37 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
