Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 11-02-2009, 12:43 PM   #1
AllTerrain82
AllTerrain82's Avatar
Default Supercharger Install Kit (PTR29-60020)
Does anyone know what the TRD Supercharger Install Kit (part number PTR29-60020) Includes? I have called the local dealership, a couple of online places and TRD directly, but no one can tell me what this kit includes. It costs over $170 so I don't just want to order it and hope for the best. I searched, but if I missed it go ahead and and kindly post a link.
2001 Extra Cab Tacoma 5 Speed 5VZ-FE
Lifted, Locked, Armored and Supercharged
Build Thread
AllTerrain82 is offline   Reply With Quote
Old 01-28-2010, 12:54 PM   #2
ryu
Default
^^^ i'm wondering the same thing. any luck finding the info?
ryu is offline   Reply With Quote
Old 01-28-2010, 05:31 PM   #3
AllTerrain82
Default
No I never got any feedback on this part number. TRD and all the dealerships I tried have no info about this part#
It is likely that you won't need the kit though; I just completed a (used) SC install last month and was able to get all the parts I needed separately through Toyota and alternate sources. The only part I was not able to get a hold of was an accelerator cable bracket for a MT, but I was able to make one. Let me know if you are having a hard time locating any of the parts you need, I may be able to help.
Here are some of the Toyota part numbers I needed:
IAC Check Valve PTR26-35042
Cut out Template PTR26-60029 (or download here)
http://ttora.com/forum/showthread.php?t=146219
Dynamic Tensioner Kit PTR29-60032 (includes all hardware below)
Tensioner Plate and Pulley assembly
Bolt, 10 x 1.25 X 70mm Flat Head Bolt
Bolt, 10 x 1.25 X 135mm Hex Head Bolt
Washer, 10mm Flat Bolt
Wiring Loom Relocation Bracket
Dipstick Relocation Bracket
6 X 10 X 12mm Bolt
6mm Flat Washer
Belt Routing Sticker
I also got a replacement bypass valve (mine did not actuate properly) and oil change kit which included a new oil drain plug, nose drive assembly coupler, sealant and 4oz of the proper synthetic gear oil from Manguson.
The link below is a good source for any of the bolts and the and the manifold support bracket spacer if you are missing them, all the fastener sizes are listed on the Kit Contents page of the SC install manual. I was able to get all my hardware in Stainless Steel from here:
http://www.mcmaster.com/
Hope that helps
Build Thread
Old 01-28-2010, 07:44 PM   #4
ryu
Default
Wow, if I could buy you a six pack I totally would. I'm in the middle of the process and i'm already getting started with a few online orders pending delivery. You've just saved me hours and hours.
I noticed the dynamic tensioner increased in price drastically over the past year or so.
Can I ask approx how much in total you ended up spending on the spare parts? In spare parts I mean everything but the blower - seems like you're just like me... starting with just the blower.
Old 01-28-2010, 08:54 PM   #5
Bear
H-O-L-Y-------S-H-I-T-H-H-A-A
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default
Good thread topic
I recently removed my Sc for other reasons but plan to re-install in the spring. Do you know if your source carries the "rebuild kit" for the superchargers?
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
… remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 01-29-2010, 12:16 AM   #6
AllTerrain82
Default
No Problem
Yes I did have to acquire most of my parts except the SC belt and Intake manifold gasket. I had to replace some of hoses with parts I had on hand, but you can make all the stock hoses work in necessary.
Here is the list:
From TRD Parts 4U:
PTR29-60032 TRD DYNAMIC TENSIONER $256.01
PTR26-35042 TRD Replacement Check Valve $6.50
Shipping $15.66
Order total 278.17
From McMaster-Carr:
91287A323 18-8 SS Hex Head Cap Screw M8x170x1.25mm Pack of 1 $5.28
91292A210 18-8 SS Socket Head Cap Screw M8x65x1.25mm Pack of 10 $6.75
93810A485 Bumax Hex Head Cap Screw M8x35mmx1.25mm Pack of 5 $10.10
Shipping $11.25
Order total $33.38
From Magnuson:
Bypass Valve Vacuum Actuator (Part#: 45-01-41-112) and Oil Change kit shipped $50.74
From Local Dealership:
PTR2660029 TRD SC FRONT LN TEMP $7.07
Bottom Line: $369.36
Regarding the manifold support bracket spacer I didn’t know what length to get until the SC was in place. Turns out that a spacer with an ID of 8mm and length of 25mm (or equivalent 5/16”x1”)works well. I got a chrome plated steel spacer in this size from the local True Value, but McMaster-Carr has a SS one in this size (Part# 92320A734) if you are going to place an order with them.
I also got these additional parts from URD:
SuperGrip Supercharger Pulley for $89.99 (Black Friday special)
SuperGrip Crankshaft Pulley $249.99 (Black Friday Special)
SuperGrip Idler Pulley for TRD Supercharger Dynamic Tensioner $99.00
Throttle Body Gasket for 5VZ-FE O-Shaped $4.95 (Same as TRD part)
URD 7th Injector Kit for TRD 5VZ-FE Supercharger
- Supercharger : Black
- Add AFR Calibrator : Yes +$79.00
- Spark Plugs : Denso Iridium IK22 +$49.00
$1,127.00
Build Thread
Old 01-29-2010, 12:35 AM   #7
AllTerrain82
Default
Originally Posted by Bear View Post
Good thread topic
Magnuson used to offer rebuilt nose drive assemblies on an exchange basis, but when I contacted them about this (before Christmas) I was informed that TRD was now handling this and they no longer offered the service. I never contacted TRD about this so I am unaware if TRD will rebuild the nose drive assy or simply sell new ones. I am guessing the latter, but that is just a guess. Not sure if this is what you were talking about or not.
Seems like I remember hearing something about a SC rebuild kit before as well, but have not researched it. The folks at TRD Parts 4U were able to answer a lot of my questions about SC parts, as one of the guys there was in the process of sourcing/researching parts to rebuild a SC for himself at the same time I was last DEC. You may want to give them a call and see if they can offer some assistance or supply a rebuild kit.
I know TRD Parts 4U could get the TRD Supercharger Install Kit mentioned in the first post (part number PTR29-60020) but didn't know what it contained.
Build Thread
Old 01-29-2010, 09:32 AM   #8
ryu
Default
AllTerrain82 - Thank you for the effort. If this isn't worthy of a sticky I don't know what is...
I received some feedback yesterday regarding the original P/N in question (PTR29-60020). According to TRD (take with a grain of salt) it contains "everything" you need to install the SC except the blower and the dynamic tensioner pulley kit assembly (P/N PTR26-35040 which changed to PTR29-60032?). I could not get a straight answer on what exactly it included as in a parts list. I'm almost tempted to get this installation kit and the tensioner kit and see what else falls out.
I'm so glad you were able to located the bypass valves. Those are key!
Old 01-29-2010, 09:34 AM   #9
ryu
Default
Also, there is an ebay seller by the name of "engineersanonymous" who rebuilds the snout assembly. Based on their ad they claim to replace the wear parts with better than original quality replacements.
Not sure if anyone has any feedback on them?
Old 01-29-2010, 09:47 AM   #10
drabnor
Home Grown Tacoma
drabnor's Avatar
My Rig: 2000 Tacoma
Default
rebuild parts:
http://www.rollingperformance.com/
haven't done mine yet but need to soon. the only scary part is tapping the s/c for grease zerks to get the rotor bearings out
TBH IE division
Originally Posted by Scuba View Post
Did you read any part of the reply that just took me 10 mins to search for and write?
Originally Posted by miguelitro View Post
I know I hate having to poke my wire into such a tight hole...
mike
drabnor is online now   Reply With Quote
Old 01-29-2010, 05:12 PM   #11
AllTerrain82
Default
I am afraid I cannot take much credit for sourcing parts. Gadget, both through his website and over the phone, supplied the vast majority of the info. Great guy with lots of knowledge and willing to take the time to share it.
If you need everything to install the SC it really wouldn't cost much more to just buy the install kit instead of second sourcing all the parts individually; plus you would probably get all the fancy stickers too Let us know what the kit contains if you go that route.
Build Thread
Old 01-29-2010, 06:59 PM   #12
AllTerrain82
Default
Originally Posted by drabnor View Post
rebuild parts:
Just got through checking out that link. Not sure how I would feel about tapping the SC housing either. I assume the ports already exist on the bottom of the housing (don't remember from when I installed the SC) and they just need to be tapped? That may not be so bad I guess. Does anyone know what the expected service interval is for the rotor and snout bearings? Seems like I read somewhere that TRD states the SC has a 100K service life, but they claim lots of stuff...
Build Thread
Old 01-30-2010, 02:36 PM   #13
ryu
Default
I wish I could find the backup for this but I can't locate where I read that rebuild intervals for our SC was 50-60k. I think it was over at Magnuson somewhere. Anyway, this is merely here say until I can find that backup.
Old 01-30-2010, 07:07 PM   #14
Windtech007
Windtech007's Avatar
My Rig: 97 tacoma 4x4 ext
Default
I don't remember needing a install kit for my sc. I think it came with all the hardware.
97 tacoma extcab 4x4 3.4 mt sc
Originally Posted by Tacoma Jake View Post
You can stick that big red thumb up your ass.
Windtech007 is offline   Reply With Quote
Old 01-31-2010, 12:13 PM   #15
AllTerrain82
Default
It does if you get it new, a used SC is a different story....
Build Thread
Old 01-31-2010, 01:29 PM   #16
Windtech007
Default
You have a used SC that didn't come with any of the required hardware? If that is the case then I feel your frustration.
The SC install instructions pdf located in the facts has a parts list that might be of some use as a check list.
I'll try to be more helpful in the future.
Old 01-31-2010, 01:38 PM   #17
AllTerrain82
Default
No worries, I posted this question a while ago. I was just trying to decide between buying the install kit for $170 and hoping it had all the install hardware I would need (and probably some I didn't) or just second sourcing everything. I decided to go with the latter route and the SC is all mounted up and working fine, less a little open loop tuning. I think ryu may purchase the install kit for his used SC install and let us know what the kit includes.
Build Thread
Old 01-31-2010, 09:06 PM   #18
Windtech007
Default
Well now just for curiosity, why or how did you end up with a used SC w/out hardware? If it was used then it must of had the hardware at some piont. Chop shop?lol
Old 01-31-2010, 09:52 PM   #19
QuoteWarz Insurance
QuoteWarz Insurance's Avatar
Default
Yes, most supercharger bolt-on kits are going to included everything that you need. It is important to remember when you ever remove the kit that some parts are going to be replaced the next time you re-install it as many of the parts are not re-useable.
http://www.quotewarz.com
CLICK HERE>>>Tacoma Insurance
Multiple Online Quotes
1-800-610-3464
50 Insurance Companies Nationwide
QuoteWarz Insurance is offline   Reply With Quote
Old 01-31-2010, 10:23 PM   #20
Windtech007
Default
Yea a couple gaskets , sc belt routing inst, premium fuel sticker.
Old 01-31-2010, 11:08 PM   #21
HaOlE
HaOlE's Avatar
Default
the kit includes three different throttle cable brackets (only one is needed), a few zip ties, a length of vacuum line, 1 check valve,a few pieces of hardware and that is it. I felt like i got bent over a barrel.
HaOlE is offline   Reply With Quote
Old 01-31-2010, 11:30 PM   #22
AllTerrain82
Default
Ebay... but I knew what I was getting into; what it came with and what it didn't, how much it would cost to replace all the hardware and so on. Worked out well in the end. It seems to be somewhat common that a used SC doesn’t come with all the hardware. Doesn’t make sense to me, if the SC come off so should the rest of the hardware right?? Maybe some people think it looks cool to have a useless belt tensioner mounted to the block who knows : D
Build Thread
Old 01-31-2010, 11:44 PM   #23
AllTerrain82
Default
If you still have the pats list that came with the kit or remember exactly what hardware came with it and would be willing to post that info here it may be helpful to other people in the future. A scanned image of the kit contents sheet would be great.
Some parts, like the throttle cable brackets, are not available separately from Toyota/TRD (at least that is what they told me) so if someone needs all or most of the hardware for an install it may be worth it to them to buy the kit.
Build Thread
Old 02-01-2010, 01:52 AM   #24
Windtech007
Default
Yes , of course Ebay. I have large collection of 2.7 parts that don't fit my 3.4.lol
Old 02-01-2010, 09:51 AM   #25
ryu
Default
+1 on this request. I was just about to place an order for the kit this morning but now i'm questioning my decision if all it comes with are 1 usable bracket, hoses, and a check valve - is it really worth $178~.
HaOlE - if you can help us with a little more detail on the parts (esp. the hardware?) we'd appreciate it!
Old 02-02-2010, 12:32 PM   #26
ryu
Default
Got these so far from toyotaworld.com
PTR29-60032 TRD DYNAMIC TENSIONER $249
PTR30-35040 TRD Belt $9.00
17176-62040 TOYOTA Intake Manifold Gasket $9.04
22271-62050 TOYOTA T/B Gasket $3.32
Can't plunge into the "Installation Kit" just yet. I suspect I will end up buying all the small hardware items separately. $179 for a kit with uknown contents just doesn't make sense. Hopefully HaOlE can chime in with more info...
Old 02-02-2010, 02:17 PM   #27
ryu
Default
From Magnuson:
Bypass Valve (Part#: 45-01-41-112) and Oil Change kit shipped $50.74
RE: the bypass valve.
Is it the part connected to what looks like the vacuum actuator? towards the back of SC? I'm talking about the piece with the yellow sticker on it. I'm asking because I may not have to buy this part but I suppose it's also a wear item I should probably replace.
Old 02-02-2010, 02:56 PM   #28
AllTerrain82
Default
Yes that is the bypass valve actuator. That is what I should have called it in my above post. It is very important that it functions correctly so the SC will not rob engine HP during cruse/idle situations. The actual bypass valve is inside the SC and should not need to be replaced. The cylinder you described above is just the vacuum actuator that opens and closes the valve. The diaphragm inside the actuator can rupture, this was the case with my SC and I had to replace the part. It is really easy to test though. Remove the vacuum line from the SC end. Manually move the actuator compressing the return spring and hold. Cover the end of the vacuum line you removed from the SC with your finger and release the actuator; it should be held in place by vacuum pressure and not return to its original position. If it does it is leaking and you need a new actuator. Be careful if you remove the vacuum line from the actuator itself because there is a small brass orifice pressed into the actuator. It is easy to pull it out when removing the vacuum line from the actuator. Not a big deal if it comes out just put it back before reinstalling the line. It is common for it to get stuck in the vacuum line and go unnoticed.
Build Thread
Old 02-02-2010, 04:43 PM   #29
ryu
Default
thanks for the clarification, and as usual, the excellent follow up detail.
Old 07-17-2010, 12:14 AM   #30
The_Dude
The_Dude's Avatar
Default
Might be buying a supercharger tomorrow that includes nothing. Great write up. Really appreciate the time you invested in researching and posting for us.
I'll be in my room painting..homo things
The_Dude is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
3RZ-FE Supercharger install Porky133 Newbie Tech 3 11-14-2007 04:44 PM
supercharger install hockeyplayer4 Performance/Engine/Exhaust 0 05-30-2007 10:05 PM
supercharger install aelogbi Performance/Engine/Exhaust 4 06-26-2005 01:05 PM
1st Gen. SuperCharger Install or not? batesmotel@mac.com Performance/Engine/Exhaust 2 06-01-2005 09:27 PM
Supercharger install AK95Taco Performance/Engine/Exhaust 2 05-26-2005 07:00 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
