Sponsored Ad
Go Back   TTORA Forum > Expeditionary Tech > Recovery and Exploration Gear
Thread Tools Display Modes
Old 04-14-2010, 05:26 AM   #91
Dominion
Default
Originally Posted by NorcalPR View Post
Any update on selling the shackles that fit the crush thimbles? I don't see them listed.
Wow, you guys are good.
I've been doing some testing and here's what I've found. Under HEAVY load, the crush proof thimbles are closing around what ever is placed through them. This causes the thimble eye to become smaller and I'm worried that even the smallest of the 3/4" shackle pins becomes too large. This is not a problem for a link hook, as the thimble can only close to the point where the tube ends touch each other. What I'm taking away from this, is that the direct shackle to tube thimble connection can cause un-happy customers for me. It's not worth it to me to offer the shackle as an option for what we have talked about. I'm not saying that it doesn't work, just how well. If the thimble closes around the shackle pin, it can be bent open to release it. But that's certainly not an elegant solution.
I can certainly get you guys some shackles if this sounds okay to you.
Thoughts?
Dominion is offline   Reply With Quote
Old 04-14-2010, 06:21 AM   #92
GatorTaco
GatorTaco's Avatar
Send a message via AIM to GatorTaco
Default
Originally Posted by Dominion View Post
shipping to Florida tomorrow.
Awesome!
-Chris
'99 Taco V6 4x4 Manual Everything
Rearranging Photobucket account- for broken pic links, PM me with link to thread
GatorTaco is offline   Reply With Quote
Old 04-19-2010, 12:43 PM   #93
GatorTaco
GatorTaco's Avatar
Default
Looks to be great quality and got super quick shipping and response! looking forward to getting it on my winch! Thanks and i'll update when everything is put together.
-Chris
Old 08-26-2010, 04:17 PM   #94
GatorTaco
GatorTaco's Avatar
Default
Still happy with this rope! Just wondering- Are you offering any chafe guards yet? I'm thinking of going with some of this stuff as mentioned in another thread on here.
-Chris
Old 09-11-2010, 08:40 PM   #95
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
Default
Chris,
I just (Finally) installed my winchline and winch in the bumper. Before spooling everything up and installing it all, I went to REI, and had them cut 10' of 1" tubular webbing like you posted. They come in a bunch ofdifferent colors, so I got the green one to match the winchline. Make sure you are getting webbing that is tubular, and not flat. You can find out which is which by trying to roll the webbing between your thumb and index finger.
Once cut, I stuck a 3/8" bolt head about 1/4" down and used a soldering iron to burn te end. This kept the end round.
Slid the whole thing on. It's very easy to slide if there's slight tension on the line.
One thing I did notice is that the protector does not go all the way to the end of the line, because of the bury splice. That's ok though because if you pull it tight against the bury splice, it doesn't slide back in as you're spooling in. Once spooled in, it tucks away very nicely...
-Phill
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is online now   Reply With Quote
Old 09-12-2010, 10:12 AM   #96
TEJASYOTA
Come and Take it!
TEJASYOTA's Avatar
My Rig: '01TACO-DCLimitedTRD
Default
Originally Posted by gatortaco View Post
sweet!!!
One thing I noticed, did you have to trim your grill to make the winch fit?
Ciao! - - Nathan - -The "UN"-Official TTORA Welcomer
'01 Tacoma DCab (some mods - click here)
www.Z3POWER.net
TEJASYOTA is offline   Reply With Quote
Old 09-12-2010, 10:20 AM   #97
sasaholic
sasaholic's Avatar
Default
ya it looks like his grill is trimmed to fit the winch. id way rather cut my grill up and have a better approach angle than have it stick out another couple inches and make the angle worse. ill have to snap a pic of how little grill i have left with my 8274 mounted up haha. got me in another 1 3/4's though
Never make your passion your occupation. it will loose it's luster and become work. that's why i never wanted to become a gynecologist!
1997 toyota 4 runner. lc coils and donahoe coils goin on soon with 255 75 17 brk km's on titan rims
sasaholic is offline   Reply With Quote
Old 09-28-2010, 06:03 PM   #98
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
I was able to finally find a shackle that the body fits in the crush proof thimble.
Crosby 3/4" shackle, 4 3/4T WLL. You can find these things nearly anywhere.
Actually found that this shackle worked by accident. Found it in the garage, and tried it out. Worked perfectly!
W6FTW
Old 09-28-2010, 06:41 PM   #99
GatorTaco
GatorTaco's Avatar
Default
Chris,
-Phill
Great to hear! Thanks!
Originally Posted by TEJASYOTA View Post
sweet!!!
Yup I did. I couldve moved it down and not cut, but it doesn't look to bad IMO and it's definitely worth the additional clearance. Coming from the ARB bumper, I never wanted to bang into anything with my bumper again on the trail. So far, so good..
My shackles fit through.. They're from Northern Tool, but I dont remember which model they were.. these are them
-Chris
Old 09-28-2010, 06:48 PM   #100
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
What's wierd is those look the same as the ones I got from Grainer. The pin fits on the crush proof, but the body will not, the end where the threads are is just too thick.
W6FTW
Old 09-30-2010, 07:13 PM   #101
Dominion
Default some thoughts
Hey guys, haven't checked this thread in a while, but thanks to NorcalPR I've finished some testing and have made available some good shackles. I've identified a 5/8" shackle that works very well with the crush proof thimbles. The key to this shackle is that it's forged alloy steel. This makes them much stronger than a standard steel shackle. This 5/8" shackle has a working load limit of 10,000 lbs. a proof load limit of 20,000 lbs and an ultimate breaking strength of 54,000 lbs. FYI, these are not cheap. For fit, shackles must be tested with the thimble closed. I've had a thimble lock onto a shackle pin before, when doing a heavy pull. To get the pin out, we had to pry the thimble open. I've put a thimble in a vice, closed it and these 5/8" shackles still fit both body and pin.
5/8" forged alloy shackles include shipping at the following prices:
1 Shackle - $18.45
2 Shackles - $29.90
3 Shackles - $42.35
4 Shackles - $53.95
RE the tubular webbing as a chafe guard. The biggest problem with using webbing is that if you pull the rope into the winch, under load, the winch line can get stuck and will not de-spool without a load pulling it out. This is why I recommend a removable chafe guard. I haven't had a chance to properly test my design and this is why I do not yet offer a chafe guard.
Picture of 5/8" shackle:
Here's a picture of a thimble, closed in a vice:
Old 09-30-2010, 07:33 PM   #102
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
1 Shackle - $18.45
2 Shackles - $29.90
3 Shackles - $42.35
4 Shackles - $53.95
Awesome. If I have issues with the Crosby shackle that I found, I'll order a 5/8". I'm sure it wasn't too hard to pry open? Just a couple screwdrivers I assume?
Goot point on the webbing, I didn't even think about that. However, the chafe guard can scrunch up towards the end so it wouldn't go in under load. IIRC, I cut it at 8'. It would probably easily scrunch down to 4 or 3 feet.
The other problem I see is if you need to run it through a snatch block. Instead of easily removing it, you'd have to pull a bunch of line out, slide it in, then spool the line/guard in with no load.
We'll see. I haven't gotton any real testing on the winch yet, but so far I'm happy with the 3 dollar guard.
W6FTW
Old 09-30-2010, 09:13 PM   #103
Dominion
Default
Correct, not hard to pry open and yeah, just keep an eye on the guard and you should be okay. Great point on the snatch block, hadn't even thought of that.
Old 10-07-2010, 09:28 AM   #104
GatorTaco
GatorTaco's Avatar
Default
oops, I was mistaken.. I didnt realize ya'll were talking about the crushproof, and I was talking about the safety thimble..
Anyways, I looked at mine and they are 6-1/2 ton WLL 3/4"and fit every direction through the safety thimble..
-Chris
You may not post new threads
You may not post replies
Forum Jump
WTB winchline crolison Classifieds 10 12-11-2008 06:22 PM
Changing Winchline on an ARB Topper Exterior/Paint/Body Panel Modifications 5 02-23-2008 07:42 PM
Quaker State - 4x4 Synthetic Blend vs Full Synthetic ScreamingTaco Performance/Engine/Exhaust 3 03-23-2007 09:37 AM
Going to a synthetic winchline?? Chadman Off Topic 9 02-21-2007 05:19 AM
Synthetic Winchline?? Dom Tech 5 01-21-2007 06:49 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
