Belt squeal upon acceleration? Serpentine or pulley? - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 11-09-2009, 09:02 AM   #1
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Send a message via AIM to Toyo4x4
Default Belt squeal upon acceleration? Serpentine or pulley?
Ok, so I recently switched out my serpentine belt (82K miles) because it was squealing regularly. Problem fixed. Fast forward to a few weeks later, and I'm starting to get a subtle squeak under the hood (sounds like it could be more towards the driver's side) when accelerating. It's usually more prominent during warm up, but it definitely only happens when accelerating. If I let off the pedal, it stops. Oddly enough, before replacing the serpentine, the squeal happened regardless of whether or not I had the pedal pressed. Any ideas? Not sure if it's a pulley, bearing, or what? I haven't had the chance to get someone to sit in the truck and accelerate for me while I listen.
1996 Xcab 2.7 4wd 5spd-Sold
2005 TRD AC 4x4-265/75
Stock...for now.
Pennsylvania Toyota Territory Assoication
Toyo4x4 is offline   Reply With Quote
Old 11-09-2009, 09:11 AM   #2
AHeppner
Default
I have the same problem. Drives me bonkers and I can't maintain a constant speed on the highway without this ridiculous squeal. I feel like it has to do with the throttle cable...
AHeppner is offline   Reply With Quote
Old 11-09-2009, 10:36 AM   #3
kirk
Default
Did you get oil on the new belt or any of the pullies? If so, try blasting some black magic tire shine on it .... might help.
kirk is offline   Reply With Quote
Old 11-09-2009, 10:42 AM   #4
hrtbrk1
hrtbrk1's Avatar
Default
idler pulley???
99' tacoma, OME 882's, alcans, 31x10.5 BFG AT's, trail gear front bumper, Champion 7500lb winch w/Amsteel synthetic cable.
hrtbrk1 is offline   Reply With Quote
Old 11-09-2009, 07:20 PM   #5
taco4x4rar
taco4x4rar's Avatar
My Rig: 06 Tacoma
Send a message via AIM to taco4x4rar
Default
Your ider pulley is dead, get a new one. It really sucks when it finally caves and you lose power everything along with the alternator and water pump.
Originally Posted by Jomentum View Post
I drink everclear for the flavor.
Originally Posted by Spacecwboy View Post
I'm still a homo!
http://toyotaoff-road.com/
Randy
2006 Tacoma x-cab, flat bed, leaf sprung Dana 44, Dana 60/ 14 bolt coming soon
1992 Chevy C-1500 swapped D60/14bolt 454 and th400 (wrecked it)
taco4x4rar is offline   Reply With Quote
Old 11-09-2009, 09:16 PM   #6
fast frank
fast frank's Avatar
My Rig: 2001 Tacoma 4X4 Dcab
Default
http://www.tacomaterritory.com/forum...ht=idler+pully
2001 Double Cab V6 Auto Tranny 4WD TRD Offroad.
Bone Stock and Loving Every Minute Of It.
fast frank is offline   Reply With Quote
Old 11-10-2009, 05:42 AM   #7
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
Originally Posted by fast frank View Post
Thanks. Not sure which idler it is, but I suppose it couldn't hurt to fix both. Never got into any mud, so I suppose just premature failure. I would expect these things to last longer than the 80K I have one my truck, but oh well.
Stock...for now.
Old 11-10-2009, 09:49 PM   #8
Shakerhood
Shakerhood's Avatar
Default
The only time mine makes noise is when I first turn on the AC.
Shakerhood is offline   Reply With Quote
Old 11-10-2009, 11:53 PM   #9
johnecon2001
Tiny red truck
johnecon2001's Avatar
Default
Pretty sure there are actually three of them. Two do have the same part number.
ARB ~ Bilstien ~ Doug Thorley ~ AllPro ~ Desert Fab ~ Hankook ~ PowerMaster ~ Stubbs ~ Tom Woods ~ Total Chaos ~ TRD Trail Team ~ Bovads ~ Wheelers ~ Nitro Gear
johnecon2001 is offline   Reply With Quote
Old 11-11-2009, 06:22 AM   #10
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
You're correct. I missed one in the belt routing diagram.
Stock...for now.
Old 11-11-2009, 11:23 AM   #11
mpower
mpower's Avatar
Default
take the belt off and spin the pullys by hand . if its rough or dosent spin for very long . its most likely done or on its way out.
the two uppers are the same pn , the lower idler pully is different than the rest . the idler pulley on the tensioner is not a servicable part so it must be swapped out as an assembly , ( found that the one of the uppers will work in a pinch with a .100" spacer , to replace the tensioner pulley).
i have a few upper idler pulleys that i have as spares , i could sell one . but for 15-20$ more you can get a brand new one.
Defined Engineering
- Fab Services - Installs - Prep -
Light Racing Jouncestop Rebuilding
King Shock Servicing
Yorba Linda , CA 951-217-4947
http://definedengineering.com
2005 tacoma access 4wd sport
getting to be too much to list!!
"I didn't fail 3,000 times. I found 3,000 ways how not to create a lightbulb"-Thomas Edison
"Wise men talk because they have something to say, fools talk because they have to say something."- Plato
mpower is offline   Reply With Quote
Old 11-12-2009, 05:22 AM   #12
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
Thanks, that's a huge help. I was looking down in there tonight wondering how the heck I'm going to finagle a wrench and my hand in there to get the tensioner slid to the side and slide a pin in Suppose I'll get after it this weekend.
Stock...for now.
Old 11-12-2009, 11:44 AM   #13
johnecon2001
Tiny red truck
Default
It gets a lot easier if you remove the Fan shroud.
Old 11-12-2009, 12:32 PM   #14
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
Yeah that's what I was thinking. Thanks again, guys.
Stock...for now.
Old 11-12-2009, 03:49 PM   #15
mpower
mpower's Avatar
Default
x2 take the 4 bolts that hold the fanclutch off and the 2 that hold the shroud and its a hell of a lot easier. in fact that the only way i will do it, its tough with custom skids and bumpers .
Defined Engineering
Old 11-16-2009, 02:43 PM   #16
hunter4runner
Banned
Default
Your idler pulley is crapping the bed it will die completely soon, i just had that issue
hunter4runner is offline   Reply With Quote
Old 11-18-2009, 10:52 AM   #17
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
Do the bearings in the idler pulleys all have the same part #?
Stock...for now.
Old 11-18-2009, 12:31 PM   #18
NwiTACO
Moderator
My Rig: 2005 TACOMA DCSB
Default
Can't replace just the bearing, only the pulley assembly. And no, you can't get just the bearing from a supply house either.
And it is a five minute job to replace the idler (any one) from below, if you remove the skids plate. Its not worth removing that other bs people are talking about.
NwiTACO is offline   Reply With Quote
Old 11-18-2009, 01:01 PM   #19
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
Fast Frank is wrong, then?
Stock...for now.
Old 11-18-2009, 01:16 PM   #20
NwiTACO
Moderator
Default
Read the thread. Not for 2005+ Tacomas. The idlers are completely different for the new taco.
Blue Ribbon Coalition #4847
'05 Tacoma DCSB on Tons
Old 11-18-2009, 01:28 PM   #21
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
You posted the day I read the thread, sorry. FF has an 05+ Tacoma, so I assumed that's what he was talking about since he doesn't specify otherwise. I'm still not convinced it's the pulleys. It's intermittent. Some days it does it, some days it doesn't (no correlation to weather or temps really either), and it's certainly not getting worse. I'm planning to drop the skid (I guess if that's easier) this weekend, and check things out.
Stock...for now.
Old 11-18-2009, 10:20 PM   #22
fast frank
fast frank's Avatar
Default
When i did that write up, I was working on a '96 with a 3.4.
My '05 hasn't needed any pulley work yet.
I've replaced those bearings in lots of different stuff, American and Metric, so I assumed that the pulley on this motor is the same.
What's different about it?
Does it have something other than a bearing in it?
Old 11-18-2009, 11:59 PM   #23
Shakerhood
Shakerhood's Avatar
Default
Thanks for the Input, I will have it checked next time I take it in the Dealer. It does a quick squeal and bangs when the AC kicks in the 1st time.
Old 11-19-2009, 06:42 AM   #24
NwiTACO
Moderator
Default
Nope just a bearing that is not comercially available. I called three bearing suppliers I use for work all the time and none can get the bearing.
FWIW its a Koyo 6302RMX Bearing whose dimensions are:
42mm OD
10mm Bore
13mm Brng Length
Everyone can get a 42/15/13 but then you have to have a special shoulder bolt made or some sleeves to reduce the bore, and by then you are at the cost of the new Idler assembly, $45.
Hell, if someone can find a bearing with those dimensions, I'll take three right off the bat for the three toasted idlers I've got sitting at home.
Old 11-19-2009, 07:06 AM   #25
fast frank
fast frank's Avatar
Default
If you look a little to the right of the box I'm pointing at...
I'm pretty sure that's a 6302. Maybe I'm confused.
Old 11-19-2009, 08:22 AM   #26
rader
rader's Avatar
Default
That noise is likely the AC electric clutch engaging, the bang is from the clutch the squeal or chirp is from the belt slipping a little when it has to start the cold compressor spinning from a dead stop. IMO nothing to worry about.
rader is offline   Reply With Quote
Old 11-19-2009, 09:53 AM   #27
NwiTACO
Moderator
Default
Yeah, you are. Instead of checking the specs on that bearing you just post up your pick with a smart comment. The regular 6302 has the 15mm bore...thats what they tried to sell me [/
Old 11-25-2009, 03:30 PM   #28
LBPtaco
LBPtaco's Avatar
My Rig: 2006 Tacoma
Default
looks like mine is startin to do the same thing (i think). gonna pull the belt off tomorrow to see for sure.
'06 DC TRD Prerunner. Camburg Mid Travel (10.5"), Allied Spindles, Light Racing Jounce Shocks up front, Dakars, Bilstein 5150s, Fox 2.0 Air Bumps out back, Cooper Discoverer STT (285 75 16) on AR Teflon Chambers, Downey Skids, Demello Rock Crushers, Marlin Crawler E-locker Skid, URD TCAI & MAF, JBA exhaust, EdgeStar freezer, 4 Kragen HIDs
LBPtaco is offline   Reply With Quote
Old 11-25-2009, 04:29 PM   #29
Toyo4x4
Wheeler Wannabe
Toyo4x4's Avatar
Default
I dropped the skid plate last weekend, and pulled the belt. Spun the pulleys, and they all seem fine. The tensioner seems to be in the worst condition of them all, but it still spins freely. Usually the belt squeals in the morning and afternoon during cold starts, but it didn't do it at all today. Strange.
Tensioner pulley/assembly is $100+ though.
Stock...for now.
Old 11-25-2009, 07:21 PM   #30
NwiTACO
Moderator
Default
It's not so much as whether it spins or not, but how much slop is in the bearing. If you grab the pulley and wiggle it and it moves, the bearing is shot.
You may not post new threads
You may not post replies
Forum Jump
Serpentine Belt Question 07 docjake Newbie Tech 4 03-22-2009 01:44 AM
Serpentine Belt Slipping Problem rijrunr Tech/Tricks 10 03-20-2009 07:41 AM
Is it possible for a timing belt to squeal? matttaylor Pickup/Early 4Runner Tech 14 12-29-2007 10:28 PM
New belt with new pulley? YoTRacer158 Performance/Engine/Exhaust 1 03-28-2006 03:19 PM
serpentine belt redwillie Performance/Engine/Exhaust 0 01-26-2005 06:25 PM
