#1 |
Alright, I am hopefully be purchasing a TRD rear end next weekend. Got some questions about the swap.
I have a 99 regular cab 5speed with 4.10's, the axle is outta of a 01 TRD V6 5speed. This is also 4.10's I believe am I correct? Also will the drive shaft be correct? going from a extra cab 8" diff to a regular cab 8.4" diff? It has the yoke still if it helps... All the brakes are still on the axle, so the only thing needed to be done is disconnect flex line reconnect and bleed. I seen some things on here about the E-brake cable though. Mine goes up over the leaf spring so will the 01 be the same? As for wiring the E-locker in. It has the wires up to the first plug from the locker. I know I will need more...just dont know what is missing? Any Toyota Factory parts or just things from the local parts store? I used the search function...but seems like its a different story depending on what year the axle is. Also didnt see anything about regular cabs.
I hate cookie cutter rigs.... Black 99 reg cab 2.7 5spd 196k miles sitting on Q's Build up here |
#2 | ||
![]() My Rig: '00 Tacoma
driveline bolt pattern will be the same Ebrake configuration should be the same...I think they changed in '03 as for wiring....your dash may already have the wiring so you may just need the harness that goes from the axle to the cab. If you do have the dash wiring you can then just install the OE switch. If not you can wire the locker up w/o the OE wiring and switch using a simple home-make harness and off the shelf switch. there is a rather detailed thread that just went through all of this a couple weeks back so try scrolling through the tech folder. you suck at search ![]() punched in 'elocker' and got 6 different threads... try this one. http://www.ttora.com/forum/showthrea...hlight=elocker
Inchworm Rock Walkin' Gear |
#3 |
So the placement of the flange off the TRD is close enough to 8.4 that the drive shaft length is correct..?
Thanks for the reply... Sorry...That was the one thing I didnt use for a search. duh
#4 | |
they should be the same...even if not exact, your DS has plenty of slip to compensate.
#6 | ||
#7 |
I am about to purchase a front diff and rear complete axle out of an 02 non-trd tacoma. Not sure if it is a v6 or not yet? Called the guy but had to leave a message. The reason I am swapping axles is because he has 4.10s compared to my 3.58s. He is going to remove the front and rear parts and sell them to me for $350. He also stated the axle was not an e-locker. Which is fine I just need a lower gear ratio for the time being.
I have searched trying to study up about swapping the axles. Nothing really concise yet except this thread: http://ttora.com/forum/showthread.ph...rear+axle+swap Basically its not going to be a hard swap but I would just like some recommendations about doing the swap. Change the diff-oil of course. Is there anything I need to look out for or possibly do while I have everything unhooked. And if it is v6 still should bolt up perfectly correct. Of course I am on a small budget. Thanks
96 2.7L Ext. cab 4x4 4.56 Locked F & R Factory 4 Runner 16s 255/85R 16 KM2s Brush Guard w/ Hella 500s Build-Up |
#8 | ||
rear 3rd is a direct swap. you might as well order a pair of outer axle seals and replace them since they are cheap and easy to do while you have the axles out. If you have a different front it is still an easy swap but you may have to change the Dr side tube (depending on manual hub or ADD). once you get them double check the ring gear (rear) for the factory stamp of the gear ratio...should be 4.1
#9 | |
thanks
#10 | ||
just swap out the tube on the pass side (goofed above ) or...keep if and wire in a switch so you can actually use it...nice if you have a full-time locker up front. the writeup on this is in the faq/tech section...can't remember exactly where...done by Dick Foster.
#11 | |
#12 | ||
![]() If you just want to retain what you have and not add the ADD stuff just swap your manual tube for the ADD one onto the new diff and bolt it up. check the FSM for a parts breakdown and torque specs. Use the '01-04 fsm for ADD and '00 or earlier for manual. I can't remember if there is a gasket between the tube and diff but if there is you can just use RTV in place of it.
| Thread Tools | |
| Display Modes | |
| axle swap on a 86 e-cab 4x4 | mudslut | Newbie Tech | 4 | 11-19-2009 07:06 PM |
| Axle Swap | HUNTER_SLLRS | Pickup/4Runner Tech | 14 | 11-30-2008 12:39 PM |
| My Axle Swap | Avsfreak1234 | Extreme Mods & Wheeling | 44 | 05-17-2008 01:58 PM |
| 98 / 97 axle swap | jmitchell151 | Early Tacoma Tech | 9 | 11-01-2005 03:29 PM |
| TRD axle swap | SAStoy | Early Tacoma Tech | 10 | 02-20-2005 08:49 PM |
