Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > PreRunner Tech
Thread Tools Display Modes
Old 01-18-2010, 07:46 PM   #31
offroadie
offroadie's Avatar
Default so...
if I'm looking to do this to my PreRunner, find a donor and swap it out. You didn't need to do more wiring work with the ecu?
Awesome write-up - I've been aching for a 5-speed...and 4wd.
Thanks man, you've given me hope.
offroadie is offline   Reply With Quote
Old 01-18-2010, 09:45 PM   #32
Tacoma4life
Tacoma4life's Avatar
Default
Nope, that's it, the wiring was very easy. In fact I probably had only 4 hrs into it total, and that was soldering and shrink wraping every connection, and running everything super cleanly as I can't stand wiring hack jobs.
Of course if you have any questions, please don't hesitate to send me a message.
-Peter
2002 Double Cab Prerunner to 4x4 swap
2.7 (3RZ) with a 5-speed manual
Manual locking hubs
Aussie Locked front diff
Trail Gear rock sliders
Home made bumpers and skids
Airbag delete/dash swap from a 1997 (because I wanted too...)
Tacoma4life is offline   Reply With Quote
Old 02-02-2010, 01:27 AM   #33
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
did you get any pics of the clutch pedal install? I assume everything just bolted up
nice writeup.
added to faq/tech mods section
http://www.ttora.com/wiki/index.php/...les#Drivetrain
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 02-02-2010, 06:34 PM   #34
Tacoma4life
Default
No, but I suppose I could. Also, the donor is just sitting at the shop mostly stripped out, so I could get some clean (inside) shots of the holes that required drilling and the threaded hole that the top of the pedal assembly bolts up to.
-Peter
Manual locking hubs
Old 02-02-2010, 06:50 PM   #35
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
just add it to your post.
Old 05-03-2010, 08:29 PM   #36
Tacoma4life
Default
Update-
The truck is performing fine and no additional CEL's have been triggered. On a trip to Denver and back a week ago I drove 842 miles on 43.04 gallons, so 19.56MPG. Not bad considering I was battleing a headwind on many stretches and speeding on others. Yes a double cab 3RZ can speed.
So I am super happy with my conversion. I gained all the weight of a 4x4 and maintained about the same mileage I was getting with an automatic Pre-Runner.
-Peter
Manual locking hubs
Old 05-04-2010, 02:52 AM   #37
SafetyDang
SafetyDang's Avatar
My Rig: 2002 Tacoma
Send a message via AIM to SafetyDang
Default
Update-
So Never swapped the ECU? You still have the Missing Auto Transmission CELs?
SafetyDang TV Episodes
Revamping Production
SafetyDang@gmail.com
5-Speed Swap Updated 11/20/12
Toyota RV 5VZ Swap
I love to buy my parts from trdparts4u.com!
SafetyDang is online now   Reply With Quote
Old 05-04-2010, 11:06 PM   #38
Tacoma4life
Default
Correct, still using auto ECU.
I posted the exact codes thrown in the origional write-up just above the wiring diagram. The codes were thrown immediately upon first starting the engine after the conversion, but no new codes have shown up in several thousand miles of driving.
I had planned on eventually finding a manual ECU, but it's really not a priority since it runs and drives perfect. Maybe some day...
-Peter
Manual locking hubs
Old 05-17-2010, 05:48 PM   #39
Yotaoffroad27
Yotaoffroad27's Avatar
Default
how are you getting it inspected? i was under the impression ALL 96 and new car/trucks had to be hooked up on a computer to pass inpsection.
If nothing else the always turn the key to see all the light come on, and since your bulb is gone it will not light........
or do you know someone
-Yota
NCTTORA.COM
My Transmission swap
V8 4.7L swap
99 Tacoma- Stockish
87 4Runner- Not so Stockish
Originally Posted by *Darcy* View Post
.. I know you're extremely knowledgeable
Yotaoffroad27 is offline   Reply With Quote
Old 05-17-2010, 09:37 PM   #40
Tacoma4life
Default
Ah, I'm in South Dakota. We don't have ANY kind of emissions or inspections. I feel sorry for all of you who do...
-Peter
Manual locking hubs
Old 05-18-2010, 08:29 AM   #41
Yotaoffroad27
Default
ahhh lucky... i wish you would hurry up and get an ECU so i can see if it will clear the codes... i want a 5speed SOOOO BAD!!!
-Yota
NCTTORA.COM
V8 4.7L swap
99 Tacoma- Stockish
Old 05-18-2010, 07:38 PM   #42
Tacoma4life
Default
Well just send me a 2002 3RZ manual ECU and I'll be happy to test it for you.
-Peter
Manual locking hubs
Old 05-18-2010, 08:02 PM   #43
Yotaoffroad27
Default
lol only if you send me a 1999 3RZ manual ECU
-Yota
NCTTORA.COM
V8 4.7L swap
99 Tacoma- Stockish
Old 11-22-2010, 01:05 PM   #44
WiredTaco
Default Trans Swap
Peter-
I swapped my 96 2.7 from auto to manual back in '02. After living with the CEL for a long time I finally had to get the truck inspected and it wouldn't pass with it on. I tried a manual ECU but they must all have the same logic inside as it threw the same exact codes.
The solution was to read the service manual carefully--it tell you what resistance the computer is looking for at the three shift solenoids. If it doesn't sense that resistance it will throw a CEL. If it sees that resistance the light will go off.
Go out and buy "power resistors" (the kind in the white clay case) of the proper resistance and wattage (do the math, it's been years and I forget!). Wire them in to where the shift solenoids connected to and your CEL will go out! The wattage of the resistor is important here--it's a low impedance circuit and you will burn up a small 1/4 or 1/2 watt resistor if you use them. Not a nice thing to have happen under the truck...
I think I put the resistance and wattage in a post way back when so perhaps with some judicious searching it could be found again.
Enjoy the dark dashboard!
Greg
WiredTaco is offline   Reply With Quote
Old 11-22-2010, 04:29 PM   #45
Tacoma4life
Default
That's very cool... Others have talked about doing this but to my knowledge no one had, except you now.
To cure mine, I just pulled the CEL bulb and scan for codes periodically. I'm coming up on the one year anniversary of the conversion and no problems thus far.
-Peter
Manual locking hubs
Old 11-22-2010, 04:33 PM   #46
SafetyDang
SafetyDang's Avatar
My Rig: 2002 Tacoma
Default
Very cool indeed!
Toyota RV 5VZ Swap
Old 11-22-2010, 08:01 PM   #47
Yotaoffroad27
Default
Originally Posted by WiredTaco View Post
Peter-
thats AWSOME!! but i have a question. Here (above) you said you tryed a manaul ecu and you still got a code. I finished my swap and have about 1700miles on it and not one cel. Did you get the correct part number ECU for your truck? just wondering what happend there. Other wise great work. I fugured it would work, but i found a good deal on my ECU.
-Yota
NCTTORA.COM
V8 4.7L swap
99 Tacoma- Stockish
Old 11-25-2010, 01:18 PM   #48
Mr Tacomi
Mr Tacomi's Avatar
Default
Peter-
Greg
Here's your post from the past:
http://www.ttora.com/forum/showthread.php?t=69438
Did you ever find a cure for the P/N CEL issue?
+()X()=
Mr Tacomi is offline   Reply With Quote
Old 12-31-2010, 09:30 AM   #49
sasdreamer
Default questions for the 4cyl/prerun to 5spd 4x guys
So first of all I'd just like to thank all of you guys for providing such valuable information on these swaps. I've been gathering parts for the last 6 mos. now and am coming close to the first part of build. I too have a double cab prerunner. Its an '02 with the 3RZ.
I have been able to track down all the following parts:
-Trans/Transfer case from a '98 Taco
-Clutch Pedal and Master Cyl. assembly (installed)
-New Clutch and Flywheel
-Shift lever boot and trim (& interior plastics)
-Front half of rear driveshaft and new carrier bearing
Items left to get are:
-ECM
-Misc. hardware
My plan is to convert to 5speed 4x first, then into a SAS. Would like to do all at once but my garage hall pass is limited due to wild 2 & 3 year old kids.
I posting my question on Tacoma4life's thread since he's through my exact swap, although I'm extremely envious of his complete donor swap vs. having to piece all this shit togather.
Sorry for the long intro but here's my questions.
#1 In your post you showed the two VSS's, one a mechanical and one electronic. Was the electronic one from your prerunner auto tranny or do I need to track down a manual/electronic one since I have a '98 trans to swap into my '02?
#2 Did your speedo cable reach its new destination from its old auto trans mounting point? I know theres not much difference but its still about 5" or 6" by eyeball measuring.
#3 This is just the start of my questions for you guys once I get started I'm sure so do you suggest posting my work/questions on this thread or 1 like SafetyDang's since its a current thread? Or just post my own.
Thanks for your help
sasdreamer is offline   Reply With Quote
Old 01-01-2011, 02:06 AM   #50
Tacoma4life
Default
#1 In a 4x4 Tacoma the VSS is located in the transfer case, but since a prerunner doesn't have a transfer case, the VSS is located in the tranny. The prerunner and 4x4 VSS's are NOT interchangeable. What I'm showing in the pic is that a 1995.5-1997 4x4 Tacoma (which has a mechanical VSS) and 1998-2004 4x4 Tacoma (which are electronic) ARE interchangeable.
#2 There is no speedo cable on 1998-2002 Tacoma's. Because my 1997 donor truck was mechanical with a cable I had to find an electronic VSS from a newer 4x4 Tacoma. The newer (1998-2004) elecronic VSS does plug right into the 1997 T-case just fine.
-Peter
Manual locking hubs
Old 01-01-2011, 06:42 PM   #51
sasdreamer
Default
Ok. thanks Peter. Its cold as hell right now and my garage is currently inandated with kid toys. Thanks for your help
Old 04-23-2012, 03:42 PM   #52
Tacoma4life
Default
Update- 4/23/12 and 135,518 miles
The conversion is still working flawlessly, even the SECO clutch kit I was so skeptical about. This truck is my daily driver and having had not a single issue, I'd still recommend doing this conversion to anyone.
-Peter
Manual locking hubs
Old 07-24-2012, 11:45 PM   #53
x2468
Default
Will the automatic t-case mate with the manual trans, or no?
The clutch pedal simply mounts to the master cyilnder? no cutting required?
2002 V6 4wd TRD Ext Cab Auto
881s on OME 90004 struts
Wheelers AAL with Bilstein 5100s and Timbrens
Grey Wire mod
Air Horn (previous owner )
x2468 is offline   Reply With Quote
Old 07-25-2012, 12:47 PM   #54
theredhorseman
Default
You have to drill three holes in the firewall for the pushrod and two studs.
theredhorseman is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Manual vs Automatic? ese loco Late Tacoma Tech 30 07-13-2009 11:06 AM
Automatic vs. Manual stargard79 Performance/Engine/Exhaust 8 03-07-2009 04:50 PM
Manual Vs Automatic cheeseheads3 Early Tacoma Tech 17 01-24-2009 07:59 PM
automatic vs manual navyseals101 Newbie Tech 63 09-10-2006 11:00 PM
automatic vs manual futrtacowner Early Tacoma Tech 8 04-26-2005 06:16 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
