Sponsored Ad
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 08-15-2005, 02:22 PM   #1
jdillon971
jdillon971's Avatar
Send a message via AIM to jdillon971
Default King Coil Over install
As the title says. I wanted to hear anyones experiences on there install of the 2.5 bolt on CO. Any issue with Brake line mounts or steering bind? Let me know. I am getting Donahoes in a few monthes but could not pass up the deal I got on the kings. They should be here in an hour or so. Also - I read some where about dropping the sway bar for an install but the write up was for a 4x4 Tacoma.....
Joseph Dillon
DillonMotorSports.com
2004 Double Cab Prerunner
Sway Away 2.0 Coil Overs
Work in progress
Icom Race radio
Deck plate mod
Stereo mod
Power outlet mod
Hella 500's with 100 WATT upgrade
jdillon971 is offline   Reply With Quote
Old 08-15-2005, 03:53 PM   #2
atwinda
atwinda's Avatar
Default
Disconnecting at least one side of the sway bar (prerunner or 4x4) will allow each side to move freely, and makes it easier to get the old coilovers out, and the new ones in.
Other than that, three 14mm bolts on the top, one 19mm bolt on the bottom. pretty straight forward. Use loctite on any bolts you remove during the installation process as well.
atwinda is offline   Reply With Quote
Old 08-15-2005, 03:57 PM   #3
Rob
Rob's Avatar
Default
http://www.parksoffroad.com/tacomamo...g%20shocks.htm
Rob is offline   Reply With Quote
Old 08-15-2005, 06:28 PM   #4
jdillon971
jdillon971's Avatar
Default
Thanks for the responses. That site is where I got my info originally. That is also where I read about the brake line issue.
http://www.parksoffroad.com/tacomamo...brakelines.htm
. Got the shocks and am going to install them right now. Will update later. Thanks again....
Old 08-15-2005, 06:46 PM   #5
Chas
Chas's Avatar
My Rig: Tundra
Send a message via AIM to Chas Send a message via Yahoo to Chas Send a message via Skype™ to Chas
Default
Ive done many sets of Coilovers. Let me know if you have any questions. Ziptie the brake line out of the way if you need to.
TAP AUTO PARTS
Las Vegas - Worldwide
702-979-1577 | 888-244-6166
chas@tapautoparts.com
Chas is offline   Reply With Quote
Old 08-16-2005, 11:21 AM   #6
jdillon971
jdillon971's Avatar
Default Install....
Well, after some some work I got the shocks installed. Had an issue with the top holes not lining up. Ended up boring them a little bigger to get the screws in. Everything seemed an 8th of an inch off. All in all it went well. The guy I got them off of had them lifted pretty high. I am going to have to drop the lift some. Anyone have a stock measurement (for Kings)? How much thread should be exposed? I could not compare to a stock height as I had Revtec spacer. All in all I gained 1.5". That is compared to the 3" Revtek. Which would make for a total of 4.5" of lift. I think that is 1.5" to much so I am going to back it down. Also noticed my upper ball joint is at an angle now. The ride is definately better. Way less body roll in corners as well.
Joseph Dillon
Work in progress
Icom Race radio
Deck plate mod
Stereo mod
Power outlet mod
Old 08-16-2005, 01:17 PM   #7
jdillon971
jdillon971's Avatar
Default
I found out the problem.
Tundra shocks not Tacoma
Just a heads up for people. If you install the shocks and the King logo is offset towards the rear of the truck you have Tundra shocks. As wellas the bolts holes not matching up by as little as an 1/8". Live and learn I guess. King says the ride will be stiffer but I thought it was ok. I also dropped the truck down a bit.
Old 08-16-2005, 01:19 PM   #8
Rob
Rob's Avatar
Default
How was the brake line issue?
Old 08-16-2005, 01:22 PM   #9
jdillon971
jdillon971's Avatar
Default
I am going to look at that this afternoon....
Joseph Dillon
Work in progress
Icom Race radio
Deck plate mod
Stereo mod
Power outlet mod
Old 08-16-2005, 01:28 PM   #10
Rob
Rob's Avatar
Default
So the person who sold you them told you they were for the Tacoma? I hope you got a really good deal. I would not have been happy about that.
Old 08-16-2005, 01:32 PM   #11
jdillon971
jdillon971's Avatar
Default
475.00 and he got them from the dealer. He said the box even said Tacoma 0n it. My call to King confirmed it as being a Tundra shock.
Joseph Dillon
Work in progress
Icom Race radio
Deck plate mod
Stereo mod
Power outlet mod
Old 08-16-2005, 02:18 PM   #12
jdillon971
jdillon971's Avatar
Default
Here are some shots. I am not pleased but want some input.....
Also note that the truck is on the ground already.....
Joseph Dillon
Work in progress
Icom Race radio
Deck plate mod
Stereo mod
Power outlet mod
Old 08-16-2005, 08:05 PM   #13
jdillon971
jdillon971's Avatar
Default
Bump
Joseph Dillon
Work in progress
Icom Race radio
Deck plate mod
Stereo mod
Power outlet mod
You may not post new threads
You may not post replies
Forum Jump
Coil Set DON WATERS Parts/Electronics/Wheels & Tires For Sale 2 12-05-2005 09:21 PM
ARB locker install in so-cal DCabTaco Early Tacoma Tech 2 07-26-2005 06:23 PM
1/2" lift Top Coil Spacers Toyota4ever Parts/Electronics/Wheels & Tires For Sale 0 06-26-2005 09:20 PM
Gear Install - Is master install kit required? Vince Early Tacoma Tech 5 03-25-2005 11:48 AM
KING COIL OVERS 600.00 used cb77DEMELLO Parts/Electronics/Wheels & Tires For Sale 3 02-01-2005 03:38 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
