1st Gen 4Runner tailgate to pickup tailgate conversion - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Pickup/Early 4Runner Tech
Thread Tools Display Modes
Old 01-31-2010, 04:00 PM   #1
Volcom
Volcom's Avatar
Default 1st Gen 4Runner tailgate to pickup tailgate conversion
I'll start by giving CUBuff 4Runner a big thanks in helping me yesterday at his dad's sheetmetal shop. There's no way I could have done the tailgate conversion by myself in my garage.
The bonus for swapping tailgate is getting rid of the heavy 4Runner tailgate. You loose all the glass, elec. motor, and all the other stuff in the window to make it go up & down. You also gain 4" of clearance at the bottom of the gate. It makes connecting a bumper to the frame much easier. The negative, you loose the back window. I've only run the hard top 5 months out of the year and don't get much during that time. If it was a daily driver, I probably wouldn't suggest the conversion. I'll make a soft top window for the rear to keep some of the heat inside.
I took some heavy damage to the driver's side rear quarterpanel a couple of years ago running BV Carnage on 33's with no rear bumper. Wasn't the smartest idea I've had. Here's the result of that trip.
Instead of fixing the damage, I just cut out the damage and left it for a couple of years.
The conversion was a good way to get rid of that low hanging quarterpanel and to make it eaiser to connect a bumper to the frame. Here's the pics.
Last picture with the stock tailgate in place. You can see my orange test spots to see what color orange I want to paint it somebody. The passenger side rear quarterpanel has taken some damage over the years as well.
Here's the damaged area that I've covered with cardboard & duct tape to keep the CO fumes from getting inside while running it with the hard top. Nice & ghetto.
Here's the pickup tailgate test fitted. Notice how much trimming has be done on the bottom quarterpanels.
Jeff welding up the 1" by 1" sqaure tubing frame that we used to relocate the hinges. The hinges sit between the 2 supports on each side.
Hinge supports tacked into place on the rear 2" by 3" crossmember I've put in between the rear framerails.
Hinge supports welded in. This shows that rear crossmember better.
Pickup tailgate hung and quarterpanels trimmed.
We welded a bottom piece of sheetmetal to the quarterpanel.
Driver's side was worse since we had to weld in a filler piece of sheetmetal between where I had trimmed and the bottom cap.
Passenger side welded. Just need some seam sealer on the inside and it's done.
Amazing how well the pickup tailgate fits in there.
Just need some paint and a rear bumper.
Driver's side was hard to work on. The Toyota sheetmetal is sooooooo thin. It's hard to weld without blowing holes in it left and right. This side will need some grinding and some bondo to make it look OK (it's not a show car so I'm not worried about it )
Another picture of th driver's side. The exhaust pipe used to touch the bottom of the quarterpanel. It's now 4" low
The finsihed product.
I'll get some pictures of the sheetmetal work inside. With the conversion, I gained 4" of interior space as well.
Addicted Off Road
Originally Posted by DIRTCO
If you build an F-Toy it better be the Toyota motor home class, because your going to be living in it! Your wife would kill you if took on that big of a project!
Originally Posted by poorboyota26
Yeah it needs more troyangulation
Volcom is offline   Reply With Quote
Old 01-31-2010, 04:32 PM   #2
88cleve4runner
88cleve4runner's Avatar
My Rig: 97 4runner
Default
that is a butt ton of ground clearance in the back. i'm just not fully understanding the frame thats under the tailgate attatched to the crossmember, but it still looks good and that ground clearance, you have to be happy with!
DD: '15 DCSB TRD OR Tacoma
97 4Runner
Also Sold
97 Build Thread: http://ttora.com/forum/showthread.php?t=193628
88 4Runner (slow and old trail rig) - Sold
88 Build Thread: http://ttora.com/forum/showthread.php?t=149638
88cleve4runner is offline   Reply With Quote
Old 01-31-2010, 04:37 PM   #3
Volcom
Volcom's Avatar
Default
The frame is what holds up the tailgate The truck tailgate hinges bolt to that frame (they are different than the 4Runner hinges).
The extra clearance will be very nice to have!
Addicted Off Road
Old 01-31-2010, 04:42 PM   #4
88cleve4runner
My Rig: 97 4runner
Default
oh ok so it will still hinge up and down, it almost looked like it just help the tailgate there and didn't let it move. i understand now. now build you a high clearance bumper... correction its already high clearance. any ideas on the bumper yet?
97 4Runner
Also Sold
Old 01-31-2010, 04:48 PM   #5
Volcom
Volcom's Avatar
Default
It will be a tube bumper. Just got a JD2 air over hydro bender built. I'm really wanting a swing down tire carrier (similar design they did on extreme 4x4 on their scout project).
Addicted Off Road
Old 01-31-2010, 04:50 PM   #6
88cleve4runner
My Rig: 97 4runner
Default
haven't seen that but i'll check it out. this happening soon?
97 4Runner
Also Sold
Old 02-02-2010, 11:01 AM   #7
me_tu05
Hawaii's Damage Control
me_tu05's Avatar
My Rig: 86 4rnr 1ton, 1UZ
Default
I like the tailgate trick, It looks really good. Seeing how it doesn't get cold here, I may consider this to add to the list of things to do.
94 SC300 She boogies
86 4runner turbo diesel swap Now has a 1UZ
me_tu05 is offline   Reply With Quote
Old 02-03-2010, 10:06 PM   #8
Volcom
Volcom's Avatar
Default
Here's the rest of the pictures to show the latches and the sheetmetal work inside the tailgate.
I just reused the stock latches from the pickup. Seemed easier than fab'ing up another solution.
Height difference between the pickup latch vs. the 4Runner latch. I'll just leave the 4Runner latch as another tie down point for the rear.
We used sheetmetal over the 1"x1" frame and just tacked it to the tub in multiple spots. It's plenty strong to stand on.
Close up of the pickup hinge location, sheetmetal, and the orginal hinge location for the 4Runner tailgate.
Just alittle gap that I'll close up. Once I seam seal and heculine the rear, it will look somewhat stock.
Here's the space I gained in the cargo area. It's not much but I'll take as much of it for camping gear as I can get. I've always loved the way 4Runner's looked bob'ed but I use all the cargo room when I go camping so it wasn't feasible for me to bob the rear behind the seats.
Couldn't see the rear frame rails before the trim. Now it's a straight shot. It will make building a rear bumper easier & stronger.
Just sits in the garage 98% of the time.
Addicted Off Road
Old 02-04-2010, 06:43 AM   #9
88cleve4runner
My Rig: 97 4runner
Default
Nice work, I would like to do this whenever a make a new bumper.
97 4Runner
Also Sold
Old 02-04-2010, 02:00 PM   #10
John Doe
Default
1 more vote for you to make those tail light fillers.
"Ok I'm sorry if I hurt your feelings. If you'd like them to feel better. LEAVE!" Rebuilt98
Too busy Fighting for our Freedom to Wheel.
Cant wait to get back on the Trails.
John Doe is offline   Reply With Quote
Old 02-04-2010, 02:41 PM   #11
mrdoug
mrdoug's Avatar
My Rig: 3.4 swapped 85 xcab
Default
Have you considered using some sort of soft rear window along the lines of the jeep soft doors? Like you said, you don't use it much, but could be an easy fix to enclose the back.. just some snaps around the window and find a fabric shop to make up a vinyl window to snap in?
Just a thought, nice work.
de·gen·er·ate
mrdoug is offline   Reply With Quote
Old 02-04-2010, 02:45 PM   #12
Volcom
Volcom's Avatar
Default
I'll have to talk with my buddy & his dad to see if they would want to start making them.
Yeah, I've got a roll of clear plastic window material & snaps that CUbuff4Runner gave me. I will make a soft rear window to keep the heat in and the rain / snow out. It's a easy shape so it shouldn't be too hard to make.
Thanks for the idea though!
Addicted Off Road
Old 02-05-2010, 04:12 PM   #13
staceman
staceman's Avatar
Default
I gained more room in the back of my 4Runner doing this to the tailgate:
http://www.tacomaterritory.com/forum...ad.php?t=42013
staceman is offline   Reply With Quote
Old 02-06-2010, 07:34 PM   #14
Volcom
Volcom's Avatar
Default
Nice mod as well!
Addicted Off Road
Old 02-11-2010, 12:31 AM   #15
Volcom
Volcom's Avatar
Default
Here's how my buddy Jeremiah said I should paint my 4Runner
Addicted Off Road
Old 02-11-2010, 12:37 AM   #16
My Rig: 1999 tacoma
Default
Nice conversion. I say go for the pink.
ike is offline   Reply With Quote
Old 02-11-2010, 03:35 AM   #17
louis
louis's Avatar
Send a message via MSN to louis
Default
You trying to be like that pink jeep behind yo runner or what!!?!?!
Sas'd 94 Pickup
WARN, FOA, 3.0, 39.5x16.5 pitbull rockers, 5.7R&P, 63 Chevys, Lincolned front/rear, Hybrid F-leafs, Longfield 30splines, Lotso Armor. I Have Gone To Find Myself, If I Dont Return Before I Get Back, Please Leave Me Here
Originally Posted by Tylas View Post
Id show you a picture of it, but when I attatch a picture its always hella small
louis is offline   Reply With Quote
Old 02-11-2010, 09:13 AM   #18
Son of Mayhem
Son of Mayhem's Avatar
Default
Very nice, If I ever get a soft top I want to swap the gates out.
2007 Toyota Super Taco
Son of Mayhem is offline   Reply With Quote
Old 02-11-2010, 09:49 AM   #19
Avsfreak1234
Avsfreak1234's Avatar
My Rig: 98 Taco, 35s n Stuff
Default
aww how cute, it matches the lil jeep.
Avsfreak1234 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
WTB: White 2nd gen pickup tailgate. 87pickup For Sale/WTB in AZ 2 01-15-2010 05:31 AM
1989 toyota pickup bed, tailgate, and bed-liner excellent condition pray4surf278 Parts/Electronics/Wheels/Tires 0 12-31-2009 11:51 AM
95 4runner Tailgate mgull123 Newbie Tech 0 08-12-2008 01:09 PM
tailgate 95 4runner dean s Wanted 1 03-02-2008 07:13 PM
FS: 93 Pickup Tailgate W/ New Paint frdvschvy Parts/Electronics/Wheels/Tires 0 06-09-2007 09:54 PM
