recommended power steering fluid flush procedure? - TTORA Forum
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 02-20-2010, 05:02 PM   #1
bibi_mwewe
Default recommended power steering fluid flush procedure?
Hi guys and gals. I have a 98 TRD V6 Tacoma that's about 200k miles young. To make a long story short, when an axle bearing went out during a long road trip and I was forced to stop at a dealership to get it fixed (who ended up being really nice people for once, a shout out to Lake Charles LA Toyota), they told me that among other small maintenance needs, it could use a flush of the power steering fluid.
My question is, will it be good enough to pump out as much fluid from the reservoir as possible using my handy fluid evacuator, and then topping off with fresh ATF, or is there another way to more fully drain the system? Other than the fluid looking grimy, there are no symptoms of system weakness such as noises or stiffness in steering.
Thanks in advance for the advice.
bibi_mwewe is offline   Reply With Quote
Old 02-20-2010, 06:28 PM   #2
sasaholic
sasaholic's Avatar
Default
yep suck as much out as you can top off drive around for a while and do it all over again to be sure all the old crap is out. atf is cheap anyways. my power steering was growling like a bitch, and when i sucked the old fluid out it looked like mollasses topped of drove a while did it again and my steering is smooth and noice free.
Never make your passion your occupation. it will loose it's luster and become work. that's why i never wanted to become a gynecologist!
1997 toyota 4 runner. lc coils and donahoe coils goin on soon with 255 75 17 brk km's on titan rims
sasaholic is offline   Reply With Quote
Old 02-20-2010, 07:30 PM   #3
Tacoma4life
Tacoma4life's Avatar
Default
Exactly, you can pump (or drain via disconnecting the return line) and fill three times with a single quart of fluid. Just drive around a few miles (or start and idle it a bit) after each fill. My PS fluid is super clear and fresh now.
In case you want a fluid recommendation, I used Valvoline MaxLife Dex/Merc ATF fluid and it works great. Dextron II ATF is what it requires, not power steering fluid...
-Peter
2002 Double Cab Prerunner to 4x4 swap
2.7 (3RZ) with a 5-speed manual
Manual locking hubs
Aussie Locked front diff
Trail Gear rock sliders
Home made bumpers and skids
Airbag delete/dash swap from a 1997 (because I wanted too...)
Tacoma4life is offline   Reply With Quote
Old 02-20-2010, 07:35 PM   #4
ikrete
Default
you could use denaturated alcohol (blue stuff) ,cleans very well
ikrete is offline   Reply With Quote
Old 02-20-2010, 08:12 PM   #5
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
Follow the steps detailed in this thread:
http://www.ttora.com/forum/showthread.php?t=103145
Next Socal TTORA event - Miller Jeep Trail - June 13
www.ttora-socal.com
SoCal TTORA on Facebook
ShowStop is offline   Reply With Quote
Old 02-21-2010, 02:09 PM   #6
bibi_mwewe
Default
Thanks, everyone. I had searched in this particular forum for advice, didn't think to check in Early Tech for details. Sounds like either sticking with repeated use of the Mityvac or pulling off the return hose would work just fine...
Old 02-24-2014, 05:43 PM   #7
firewood
firewood's Avatar
Default
My '09 (4.0 V6) has around 56-57K miles on it. When doing the seat belt bolt recall work at the dealer, they wanted to flush/replace the steering fluid for $99.00, saying it was very dark.
1.) Is this a good age/mile mark to do this job?
2.) Can I do a reasonably good job myself draining (turkey baster), running, and refilling a few times, or is it significantly better to have them do it?
3.) If I do, what fluid should I buy for this vehicle?
Also, is this a good time to bleed/flush/replace brake fluid?
July '09 White SR5 TRD Off-Road Tow Package Access Cab; 4.0, 5-sp automatic; rear susp. TSB, ARE fiberglass cap/topper. Looking for woods-driving and firewood hauling/towing suggestions. I like dark beer too.
firewood is offline   Reply With Quote
Old 02-25-2014, 10:39 AM   #8
Dick Foster
Dick Foster's Avatar
My Rig: 95.5 Tacoma
Default
I would recommend NOT running the pump dry. If it makes unlubed metal to metal contact at any time the pump will be done for as you'll score the walls of the pump cavity. I've had them apart a few times. It has metal vanes in a metal cavity.
BTW Toy says use ATF instead of PS fluid. I run Redline which is good for either type of system. It's expensive but good stuff.
Drain, then fill the system. Crank up the engine then turn the wheel lock to lock a couple of times then shut it down and walk away for a couple of hours to let any bubbles or foam settle out. Restart then top up as necessary. Job done.
I admit to being Crazy but I'm not Stupid
Dick Foster is offline   Reply With Quote
Old 02-26-2014, 10:01 AM   #9
DETrOi529
DETrOi529's Avatar
My Rig: 1991 Toyota XCab 4x4
Default
It originally went in for seat belt bolt work. The dealer trying to make some money if asking about power steering fluid.
DETrOi529 is offline   Reply With Quote
Old 05-10-2014, 06:56 PM   #10
firewood
firewood's Avatar
Default
Very delayed response, but better late than never. I figured that is what has been going on; the dealer is doing forced free work and they want money. The steering has been fine, and I figure I should wait a while before doing it. Is there a recommended odometer mark for replacing the steering fluid?
You may not post new threads
You may not post replies
Forum Jump
98 tacoma leaking engine oil, power steering fluid and question on transmission fluid sinful Early Tacoma Tech 13 10-11-2009 07:47 PM
power steering flush RAB89 Early Tacoma Tech 6 08-18-2009 12:45 PM
Power steering flush Bent Wheel Early Tacoma Tech 2 02-02-2007 05:48 AM
Power Steering Flush? Spacecwboy Early Tacoma Tech 3 12-12-2005 06:00 PM
Power Steering Pump Flush, Drain, Lifespan? Beave Early Tacoma Tech 6 01-07-2005 10:58 PM
