20r head on 22re block - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Pickup/Early 4Runner Tech
Thread Tools Display Modes
Old 02-21-2010, 03:04 PM   #1
camogonewild
camogonewild's Avatar
Send a message via AIM to camogonewild Send a message via Yahoo to camogonewild
Default 20r head on 22re block
wat do i need to do an how much pf a power gain am i looking at im looking to build a mildly high compression motor how much compression will i look at using standard pistons from an 94 block
1994 toyota 3in body lift sas full-size 3/4 ton chevys 305 SBC 350/205 automatic 4.88s 44 boggers
1987 short bed 20/22r hybrid straight axle 38.5 tsl sx's 4.88s daily driver
cowboys do it for 8 seonds mudders do it till the blow
camogonewild is offline   Reply With Quote
Old 02-21-2010, 05:36 PM   #2
gittinit
gittinit's Avatar
Default
You can't, er shouldnt try putting this head on a 94 block. Toyota offered 2 different 22r series blocks, 1st was talldeck, and 2nd was short deck. Youll want a tall deck block for using the 20r head. tall deck blocks were offered between 80/81, and 84/85. The details are out there search and you will find them, but definately do your homework this mod is not for everyone.
Whats left of a 85 Toyota, 22r Slightly Modified, Got propane, lots of tube n stuff.
=Greene County Crevise Crawlers=
gittinit is offline   Reply With Quote
Old 02-21-2010, 06:14 PM   #3
camogonewild
Default
well accoriding to lc engineering im gonn have to mill the head for my application it should be great i plaing on runnin dual row timing chain adjustable timin gear might change rods an pistons im wanting to know who has done it an how much of a diffrence
Old 02-22-2010, 04:38 PM   #4
tacomatrax
tacomatrax's Avatar
Send a message via AIM to tacomatrax Send a message via MSN to tacomatrax Send a message via Yahoo to tacomatrax
Default
Wouldn't it be easier to just do a good motor rebuild on the 22RE and get the performance upgrades for it from LC? I did mine with a few upgrades and I noticed a bit of power gain. I'm still using the stock air manafold but will probably get the upgrade from LC with in the next few months to gain a bit more power.
91 Toyota 4x4 Pickup Extended Cab
2.4L 22RE with TRD SOHC
31x10.5 BFG Mud Terrains
ARB Front and Rear lockers
Rancho Shocks
K&N Air Filter
Truck has 171,000 Miles
Motor has 251,000 Miles Pull from an 89
89 Toyota 4x4 Pickup Single Cab Long Bed / Parts Truck
No Motor
31x9.5 TSL Super Swampers
3" Body Lift
No shocks
228,000 Miles
tacomatrax is offline   Reply With Quote
Old 02-22-2010, 07:09 PM   #5
camogonewild
Default
im having major complete problems with my re an id probally fry it wheeling the way i do but id like to keep it an all everything eith the fuel injection is going against me rite now so i thought the 20r head on my block would give me bmore power then wat i have now an be more reliable ill been running a weber carb so wont have problems with the fuel department
You may not post new threads
You may not post replies
Forum Jump
20R block and head for sale da'Burd Miscellaneous Items 2 05-22-2008 09:53 AM
2.4 Head bolt threads stripped out of block David B Newbie Tech 1 03-10-2008 08:22 PM
22R block, 20R head?? Yotaoffroad27 Pickup/Early 4Runner Tech 3 07-21-2007 05:01 AM
blown head gasket? cracked head? or cracked block? RJD Early Tacoma Tech 1 11-26-2006 03:14 PM
cracked head? block? or blown head gasket RJD Tell us who you are 1 11-26-2006 01:47 PM
