Finally getting started..... - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 03-14-2010, 12:17 PM   #1
goofballtech
goofballtech's Avatar
Send a message via Yahoo to goofballtech
Default Finally getting started.....
Ok guys.... It's time to spend some money.
I already has a leak from the drivers side of my rack. Then on the Sweetheart Run last month my Driver's side CV started sounding like Jiffy pop when crowded in either direction. I then realized i had a hose clamp off on one side and a busted boot on the other. So.. instead of spending money on repairs.. i decided to rip all that crap out of there and go SAS.
so, after the last 2 years or so of browsing around and reading build threads... i am finally gonna go for it.
So, i already have an axle... now i am shopping for my other stuff.
The axle came from an 85 Yota, it....
..has been flipped for driver side diff drop so i can put it on my Taco
..has been armored and reinforced
..has 5.29 gears
..has disc brake rotors already installed
..has Asco Hubs
..has Marlin High Steer Arms
..was originally set up for a coil over setup (mounting eyes install) but i will have to change that to some spring perches.
On the way to my house right now is a FROR Tacoma Spring mount kit and a third member with 5.29 that i will be putting in the back.
There is a possible used IFS box i may be getting.
A call to Alcan Springs on monday morning with a few final measurements will get the ball rolling on my springs. I will be going with 6" of total lift so i had to get all the other measurements right so Alcan can make the springs like they need to be made.
I have been talking to the guys who will be doing the install and what we are planning is to get everything installed then use his lift to flex it out.. then measure out the proper length for the shocks. So i can get the best possible flex out of it.
There are a few more things i need... and a few more things that i want. But it's all coming together.
I am getting the install done at Searchers 4WD in Prarieville, LA.
Will update as things happen.......
1996 Tacoma Extended Cab, 3.4L, SAS with Flipped Toy front and Alcan Springs at all four corners.
My Build Up
2010 Tundra with 6" Mall Crawler lift on 35" Toyo Open Countrys
goofballtech is offline   Reply With Quote
Old 03-14-2010, 12:48 PM   #2
SAR_Squid79
THAT guy.
SAR_Squid79's Avatar
Send a message via Yahoo to SAR_Squid79
Default
Very nice!
...where'd you score that thing?
~Jamie
2000 Tacoma TRD 4WD PreRunner
Supercharged. Locked. Armored.
Mountain: She can crawl it.
Ass: She can haul it.
"Roads? Where we're going we don't need . . . roads."
~Dr. Emmett L. Brown
My Rig My Trailer 4xInnovations
SAR_Squid79 is offline   Reply With Quote
Old 03-14-2010, 12:56 PM   #3
kigmob
kigmob's Avatar
My Rig: 97 V6 TRD S/C
Default
I posted on your lattora thread about this also, but do you plan on using the same alcans in the rear that you have now or are you getting new ones? I may be interested in the old ones if you get rid of them...
1997 Black Tacoma Ext. Cab 4x4 V6 5spd
1st Gen Grey TRD Supercharger
URD 7th Injector Kit|URD 2.2" Pulley
ICON/TC MidTravel
33" Duratracs|Pro Comp 7069
AFE Dry Pro|Airaid M.I.T.|Deckplate Mod|Magnaflow
Demello Front Tube Bumper|RAT Rear Plate Bumper|RAT Skidplate
1997 Black Mustang Saleen Supercharged S281 Convertible
kigmob is offline   Reply With Quote
Old 03-14-2010, 03:40 PM   #4
goofballtech
Default
Very nice!
A guy that lives in New Orleans and is going to school. I think he used to live in Cali and moved here for school. He been building it and planning on using it for a while then decided to sell it. So i scooped it up!
I talked to him on the phone a little while ago. i am fairly certain he is a member too but have no idea what his user name is. Maybe he'll chime in to the thread.
I am getting new springs that will be built for flex. The ones i have now are built to mock the stock spring as far and weight handling and towing. Just 3" higher. I would take 300 for the set if you are interested. They have been wheeled a few times but mostly just ran around town. i think they were 250 per spring new plus shipping. They come with the U-Bolts as well if you want them.
My Build Up
Old 03-14-2010, 09:15 PM   #5
L_plantation
Default
pretty solid axle. still researching for my taco though. correct me if im wrong, but isnt the hilux axle alittle too short in width to match up with the tacoma rear?
L_plantation is offline   Reply With Quote
Old 03-14-2010, 09:28 PM   #6
goofballtech
Default
Yup, Not a huge deal.. i think it's like 2 inches total or something. Between some wheel spacers and the IFS disc conversion it'll push it out about right.
My Build Up
Old 03-15-2010, 12:18 PM   #7
goofballtech
Default
Just got off the phone with Alcan, springs will be on the way in three weeks.
Damn thats a long time.
My Build Up
Old 03-24-2010, 12:13 PM   #8
js_iron
js_iron's Avatar
My Rig: 2004 Tacoma
Default
Subscribed
04 X-Cab
Custom bumpers & armor
TG sliders
Bilstein 5100's
Wheeler's AAL
1" RB 4Crawler BL
255/85R16 Toyo M/T
Prerunner to 4wd conversion done.
My Build
js_iron is offline   Reply With Quote
Old 03-31-2010, 08:57 AM   #9
goofballtech
Default
So at the end of last week i pulled the knuckles off to prepare for the FROR brake mounting kit so i can keep my Tacoma rotors and calipers up front.
The kit should be in the mail headed my way, along with some IFS hubs and lockers.
http://frontrangeoffroadfab.com/nfos...422908a749d02c
Yesterday i got my Tacoma SAS kit also from Front Range....
and my t100 oil pan and accessories listed here:
T100 2wd oil pan # 12101-65030
T100 2wd oil pan pickup tube # 15104-62060
T100 2wd pickup tube gasket # 15147-62020
T100 2wd dipstick # 15301-62060
T100 2wd dipstick guide tube # 11452-62060
T100 2wd union # 90405-10033
got all this stuff from toyotapartsales.com.
Will takes pics later today.....
My Build Up
Old 03-31-2010, 03:21 PM   #10
goofballtech
Default
here is a few shots, First the FROR hanger kit.
then, the t100 oil pan and parts..
My Build Up
Old 03-31-2010, 03:50 PM   #11
sicktacoma
sicktacoma's Avatar
Default
do you absolutly need those ifs disc conversion kits for the sas tacomas. and will the stock tacoma calipers fit on the 85 toyota rotors/ ones in trail gear kit??? thankss
sicktacoma is offline   Reply With Quote
Old 03-31-2010, 03:56 PM   #12
goofballtech
Default
the caliper for the tacoma is a bit bigger than the ones for the IFS toyota mini-trucks. I am getting the kit because i would rather use the IFS hubs than some wheel spacers and i can then use my existing rotors and calipers on the 85 axle after. In addition to making it a little easier to disassemble when needed just by the way the FROR kit comes together.
I would assume you could use a tacoma caliper with the stock SA rotors but i am not 100 percent. just seems like they might be a little bit too then... i would be worried about maybe hyper-extending the rams in the calipers if you let the breaks wear too much.
Don't even know if it's possible in a toyota calipers but i have seen it done on some others.
My Build Up
Old 04-07-2010, 11:24 PM   #13
goofballtech
Default
Got the call earlier this afternoon. My Springs are done and should be either already on a truck or loading up tomorrow morning.
My Build Up
Old 04-13-2010, 04:21 PM   #14
goofballtech
Default
And here they are. Loaded in the truck. Will get some more pics later on. This was just throwing them in the back of the truck and snapping a shot witht he blackberry.
My Build Up
Old 04-14-2010, 09:49 PM   #15
goofballtech
Default
So, i was home from work today and decided to do something to the truck... figured it was a good time to bob the bed. I got a good start but my buddy who normally does welding stuff for me ( i have no machine and can't weld for crap, though i am trying to learn) was busy so we'll stick it together properly tomorrow after work. Got 11 inches cut off and got it fit back together pretty close.
First cut made
Second cut in progress...(Drank so much red bull my truck has wings... )
Pile of stuff....
Inside of seam...
Side View....
My Build Up
Old 04-25-2010, 03:54 PM   #16
goofballtech
Default
Been mocking up my brakes today.
Haven't put all the bolts in yet because my RTV isn't nearby and i haven't yet had the hubs turned down yet to accept the rotors. here are a couple pics of a few bolts in to hold everything.
My Build Up
Old 04-25-2010, 04:10 PM   #17
Scuba
Scuba's Avatar
Default
Was he a former marine named Jeff ?
Long shot but could be the same guy..
99 Single Cab 2.7. Finally SAS'd and sitting on full width Toyota axles.
Scuba is offline   Reply With Quote
Old 04-25-2010, 04:20 PM   #18
goofballtech
Default
Have no idea what branch he was in. And my phone shit the bed so i don't have his name/number any more.
He's a member here but i don't know his name. Maybe he'll speak up and tell us.
My Build Up
Old 04-25-2010, 04:21 PM   #19
SAR_Squid79
THAT guy.
Default
You're cutting the wrong end!
...That axle is supposed to go on the FRONT!!!
~Jamie
Old 04-25-2010, 04:25 PM   #20
goofballtech
Default
I like to mix it up. Keep it interesting.
My Build Up
Old 04-26-2010, 01:27 PM   #21
goofballtech
Default
A few more pics... just because.
Turned down to fit the rotors and got some new Bling.
Might give them a little bit of wire wheel loving later on too.
My Build Up
Old 04-26-2010, 01:53 PM   #22
DreamMachine
DreamMachine's Avatar
My Rig: 03 Tacoma 4x4 TRD
Default
Subscribed!
- Kole
From Deep in the Heart of TEXAS
2003 Tacoma Xtra Cab TRD 4x4
285/75/16 Duratracs
Front: OME 882's on Nitrocharger Sport Shocks & 10MM Trim Packer
Rear: Factory Locker, Tundra/Taco Hybrid leaf pack, 1.5" Downy Shackles & Rough Country N2.0 Shocks
Accessories: TG Sliders, Skid Row Skid Plate, A.R.E. Shell, Safari Snorkel, DieHard Platinum G-35, Cobra CB, Ultra Gauge
DreamMachine is offline   Reply With Quote
Old 04-26-2010, 07:14 PM   #23
sicktacoma
sicktacoma's Avatar
Default
so i have another question for you. what steering lines are you useing and did you have to customize them??
Old 04-26-2010, 08:11 PM   #24
goofballtech
Default
Honestly i haven't even looked to see if the hose fittings that connect to the rack are the same as the ones on the IFS box. That's small potatoes compared to all the other stuff i been getting done so i haven't even worried. Hoses and fittings are easy.....
I been thinking hard about just going ahead and going full hydro. But i might just go with what i have for now and do that in the fall. Still on the fence.
My Build Up
Old 05-13-2010, 05:19 PM   #25
sicktacoma
sicktacoma's Avatar
Default
finished my sas on monday. finally getting pwr steering today
Old 05-21-2010, 09:21 PM   #26
goofballtech
Default
Attachment 22671
Pictures kinda small. But it looks good from what i can tell. I been really tied up with work lately and havn't had time for doing much of anything to my truck.
My Build Up
Old 06-01-2010, 12:49 AM   #27
sicktacoma
sicktacoma's Avatar
Default
Old 06-01-2010, 10:46 AM   #28
DreamMachine
Default
2 thins:
1. That bumper is RIDICULOUS! thing looks beef!
2. Damn that truck is up in the air! gonna be a sick SAS!
That is all
- Kole
285/75/16 Duratracs
Old 07-24-2010, 05:34 PM   #29
goofballtech
Default little bit of progress
About a month ago i got bored one day and decided it was a good time to bob the bed. So i busted out the grinder and lopped 11 inch off the back.
Finally got a little time to do some work on my axle.
Got the 4.10 third put in yesterday afternoon and today i put the knuckles back together on either side.
I just got my u-bolt flip kits in so i plan on putting my new springs on the back of my truck one day this week so i can get my 3" lift alcan springs over to Kigmob because he's patiently waiting for me to get them off of my truck.
My Build Up
Old 08-14-2010, 11:18 PM   #30
goofballtech
Default
I finally got the chance to put my springs on the back. here are a few shots.
What do you guys think of the shackle angle? These are the shackles i got from alcan when i ordered the springs. They are certainly good and stout but seem a bit steep to me.......
My Build Up
You may not post new threads
You may not post replies
Forum Jump
Look what I started. STOMPER Land Use 4 04-02-2009 09:21 AM
Finally started my tube doors. 91 4 Runner Fabrication/Tools 11 05-02-2008 06:13 AM
Started going? ShawnTRD Interior/Electrical/Electronics 11 09-12-2007 05:16 PM
Getting started... viatierra Tell us who you are 3 06-11-2007 12:16 PM
SAS started Clark0098 General Discussions 17 03-07-2006 02:26 PM
