Shifter Hand Throttle - TTORA Forum
Go Back   TTORA Forum > General Tech > Cheap Tricks
Thread Tools Display Modes
Old 03-15-2010, 11:02 PM   #1
jwenz723
Default Shifter Hand Throttle
This was pretty easy to install. I just bought a bicycle brake lever from my local bike store ($15 for 2 levers) and a cable with the housing for $4. I got an additional screw tension adjuster for a brake lever to hold the other end of the cable housing (the part that sits in the engine bay) as you can see in this picture. I put two nuts on the back side of the tensioner, to make sure it doesn't come loose, the nut that came with the tensioner was pretty weak.
I then ran the cable through the fire wall and connected it to the brake lever. The lever just clamps right on to the shifter, i just put some rubber strips between the clamp and the shifter to fill the gap.
After i had the lever all hooked up, i measured out the length of housing that i needed and cut it to length (I pulled the cable out of the housing to make it easier). Then I ran the cable through the throttle body pulley, got rid of all the slack in the cable, and crimped on the end piece. I put 2 of them on, and a little washer, just to be safe. on the other end of the pulley, i put a zip tie around it to hold both the cables in the pulley. Without the zip tie, when the gas pedal is depressed, the hand throttle cable would get a lot of slack in the cable, and would probably eventually slip out of the pulley.
I couldn't find anything laying around, so i wrapped 3 zip ties around the bracket that the cable rubs on, to protect the cable from wearing down on the metal.
When i pull the hand throttle, it forces the stock throttle cable into the housing, so it doesn't kink the cable at all. Pretty much the same thing happens with the hand throttle cable when i depress the gas pedal.
Here is the overall view:
'90 Ext. Cab, 3.Slow
63" Chevies, 1.5" BJ Spacers, 1" Diff Drop, Hand Throttle, HID Head Lights, other little stuff, and currently sitting on 31's, while i try to sell my 32's and figure out if I want 33's or 35's, with IFS...
jwenz723 is offline   Reply With Quote
Old 03-15-2010, 11:55 PM   #2
Avsfreak1234
Avsfreak1234's Avatar
My Rig: 98 Taco, 35s n Stuff
Default
looks good. I keep thinking of ideas on how to do that in my taco. shouldnt be a whole lot different
Avsfreak1234 is offline   Reply With Quote
Old 03-19-2010, 02:26 AM   #3
Hoax 56
Hoax 56's Avatar
Default
complete garbage. you would use zip ties
'98 ExCab Tacoma 2.7, Few mods..
Hoax 56 is offline   Reply With Quote
Old 03-19-2010, 10:19 AM   #4
jwenz723
Default
You're just jealous Ethan
Old 03-22-2010, 12:29 PM   #5
zagman_420
zagman_420's Avatar
Default
what is the purpose for this? i personally have never had my right foot so busy that i said to myself.... Gee i sure wish i had a hand throttle.... just curious
we understand the jeep thing thats why we build toyotas!
id kill you for a klondike bar!
zagman_420 is offline   Reply With Quote
Old 03-22-2010, 02:04 PM   #6
jwenz723
Default
I put it in so when i am wheeling, and i am on a steep hill stopped, i can hold the brake with my foot and operate the gas with my hand so i can get off the hill without rolling back.
Old 03-22-2010, 10:14 PM   #7
wsxpos54
wsxpos54's Avatar
Default
we have done that on a few jeeps, def helps on the rocks especially when you want to hold the line your on and not roll back into other rocks
97 t100 SAS 4.56 aussie front lockright rear 35s
My build-http://www.tacomaterritory.com/forum/showthread.php?t=185319
wsxpos54 is offline   Reply With Quote
Old 03-22-2010, 10:25 PM   #8
sasaholic
sasaholic's Avatar
Default
its also good for when your winching and want to raise the rpm's
Never make your passion your occupation. it will loose it's luster and become work. that's why i never wanted to become a gynecologist!
1997 toyota 4 runner. lc coils and donahoe coils goin on soon with 255 75 17 brk km's on titan rims
sasaholic is offline   Reply With Quote
Old 03-22-2010, 10:59 PM   #9
jwenz723
Default
Ya, that is why I put it in. I was stopped on a hill on my last Moab trip and when i released the brake to do the clutch+gas, i rolled back into a rock with my rear fender...
It is also pretty sweet for doing burn outs . Manual hubs unlocked + x-case in 4-lo+ foot on the brake+ drop the clutch = nice white smoke.
Old 03-22-2010, 11:01 PM   #10
sasaholic
sasaholic's Avatar
Default
damn your hard on your shit arent ya.
Old 03-22-2010, 11:04 PM   #11
jwenz723
Default
Haha, i only did the power braking once, and only because i currently have little 31's on my truck. I did spin the tire (open diff=one wheel fire) until the rubber got pretty tacky, kinda stuck to my finger when i touched it after the burn out
Old 03-26-2010, 03:13 PM   #12
01tacozl
Default
Totally agree, what the heck is up with this ??? Only people named Jeff can manufacter such garbage. I'm punch my eyes out after looking at this.
01tacozl is offline   Reply With Quote
Old 03-26-2010, 03:43 PM   #13
jwenz723
Default
whatever zeek, you know you wish you had zip ties in your engine bay like mine
Old 03-27-2010, 02:55 AM   #14
d33pt
Default
that's pretty cool. just don't blame toyota when it gets stuck and runs away on you.
d33pt is online now   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Hand Throttle barlowrs Late Tacoma Tech 7 12-13-2009 11:54 PM
Hand Throttle bryanhilton Early Tacoma Tech 19 11-13-2007 01:26 PM
Hand throttle ScreamingTaco Late Tacoma Tech 16 04-12-2007 03:55 PM
hand throttle? 1SiCyota Interior/Electrical/Electronics 5 02-16-2007 07:06 PM
Hand Throttle flyingwil Early Tacoma Tech 5 04-26-2005 10:45 PM
