#1 |
I need some info and feed back on replacing 87 4runner OEM auto hubs. I'm looking at going with Warn Hubs. Is it a basic swap or is there more parts involed than just the hubs? Any advice on where to get hubs and parts would be helpful. I live in nor-cal. thanks Wil
2007 FJ Cruiser 4x4...Yellow and White. A-trac, rear differential lock, Upgrade package #2 with 17" alloys. 285/70-17 MTR's, Home made level lift, Rock sliders, LCA skides, All-Pro extreme LCA links, Home made Highlift jack clamps, 4 KC's on roof rack, 1987 4runner SR5 22RE 5spd. Budbuilt skids & transf. case cross member, Flowmaster. 32x11.50/15 BFG MT's, home made 1" body lift, sliders, winch plate. Had a 81 PU SR5 4x4 long bed brand new as my first new vehicle.... loved that truck! |
#2 |
River Rat
If you don't mind i'd like to add on to that question. Can I use any Tacoma's manual hubs and swap them out for my ADD taco? I mean take the spindles, cv's, and hub assembly from the manual taco and swap them on mine. Is that all I need?
Thanks, kaleo
05 Taco - SAC'd HPD44 - F.O.A. Coilovers - Armored and Locked. 99 Cummins - Workin towards 1,000lbs Torque 05 GSXR 750 - 20th Anniversary - My Coffin I'm Brown And I will Rule The World One Day. |
#3 |
For hawaiianbro:
http://offroadsolutions.com/products...drivetrain.htm You can get a manual hub conversion kit there. Runs for about a grand.
Justin '03 V6 5spd 4x4 TRD Extended cab 6" Fabtech, OME 881s, Downey HD shackles, Bilstein 5125s, 35x12.50 MT Baja Claw Radials, 4:88s and other stuff |
#4 | |
River Rat
#5 | |
Member Dismemberer
Next Socal TTORA event - Miller Jeep Trail - June 22 www.ttora-socal.com TTORA-Socal on Facebook |
#6 |
Numba 2 Ho
![]() Join Date: Dec 2004
Taco to taco yes if you're trying to convert an ADD truck to manual hubs. If you're tring to go the other way you have to change part of the axle half shaft( the add actuator part) that is part of the diff. When you say spindle you really want to swap the entire knuckle otherwise the press work is a real bitch to do.
I admit to being Crazy but I'm not Stupid |
#7 | |
River Rat
Just wondering because people keep parting there trucks out on here and i'm wondering what exactly i need to buy. So since i'm going add to manual i dont have to do anything with the add actuator part? Thanks, Kaleo
#8 |
Numba 2 Ho
Yeah, the bit with the ball joints, the axle and the hubs. However, it best thing to do is just get an ARB locker if that is why you want the hubs. If it's to lift higher, that is bad too because you're much more prone to roll overn an IFS truck with a lot of lift.
#9 | |
River Rat
Thanks for the help dick! Kaleo
#10 | |
thanks Wil
#11 |
Numba 2 Ho
No you don't have to have manual hubs with a locker. What happens with an automatic locker like a Lockrite is that the front driveshaft will spin all the time because the driver’s side axle spins the front diff all the time. The locker will then cause the front drive shaft to spin. I didn't want that to happen so I did a manual hub conversion because I had too as the only locker for the Tacoma front diff at the time was the Lockrite automatic locker. It was not an easy mod or cheap mod to do because of the press work and parts required if you need to press the spindle, hub and wheel bearing apart out of your knuckle assembly. It is not trivial press work, one of mine took 30 tons before the wheel bearing assembly finally exploded and came free, the other side took 25 tons before it let go.
Since then, ARB has come out with a selectable locker. In my opinion, that is the best way to go if you intend to stay IFS for any significant period or time. With the selectable locker, you do not really need manual hubs as it is a fully open diff just like stock when the locker is switched off. A selectable is an all round better option anyway especially for a front axle and it is stronger too. BTW you also want to be aware that the manual hub outer axle ends are a little weaker than the ADD axles. If you are going to wheel any IFS rig very aggressively, I suggest you always carry at least one spare CV axle anytime you are out on the trail. They are fairly easy to break but are easy to change out on the trail.
#12 |
sorry I didn't make myself clear; I'm talking about the hubs at the wheel , like Warn hubs. I know all about lockers and when I can I'll get them(after some O.T.) ,but until than I need to get my Hubs to ingauge the front wheels.
thanks Wil
#13 |
Numba 2 Ho
I was not talking to you, I was talking to hawaiianbro.
#14 | |
Home Grown Tacoma
![]() My Rig: 2000 Tacoma
#15 |
Numba 2 Ho
Don't give me any of yer sass, young man.
I did post the right way..
#16 | |
Home Grown Tacoma
#17 |
Numba 2 Ho
I don't want any of that either.
#18 | |
Home Grown Tacoma
#19 |
For the older 4runner question, check yotatech. lots of threads about this and a couple good writeups.
93 4runner, V6, Auto, ARB'd front and rear, 5.29s, custom armor. Gettin' off 4x4 Club member |
#20 | |
. I found what I needed. Good site, Thanks again Wil
| Thread Tools | |
| Display Modes | |
| Aftermarket Locking Hubs | HoT_DoGgIN | Tires/Wheels | 5 | 12-24-2005 06:55 AM |
| General Motors to Buy Indian Auto Parts | 99tacx | Off Topic | 5 | 08-05-2005 08:05 PM |
| 17's Sequoia Wheel Fit 99 Tacoma Manual Hubs | Bryce77 | Tires/Wheels | 6 | 07-28-2005 12:02 PM |
| When did Tacomas go to Auto Hubs? | Pinion | Early Tacoma Tech | 12 | 03-02-2005 05:23 PM |
| locking hub conversion? | denver d | Early Tacoma Tech | 5 | 12-11-2004 07:17 PM |
