Sprinkler Valve problem. Sprinklers won't turn off! - TTORA Forum
Go Back   TTORA Forum > Miscellaneous > Off Topic
Thread Tools Display Modes
Old 03-30-2010, 09:37 PM   #1
Johnnie
Johnnie's Avatar
Default Sprinkler Valve problem. Sprinklers won't turn off!
I'm trying to replace the diaphragm on my Lawn Genie sprinkler valve. I took it apart was not able to locate the part locally. I put the valve back together and as soon as I turned on the water the sprinklers went on and they won't go off on one of the zones. I turned off the water and took it apart and put it back together again. It finally went off. Then I turned on the sprinklers for 1 minute to make sure it was functioning properly and it stayed on.
Any solutions?
Thanks.
DADDY'S TRUCK
2001 PreRunner
SAW 2.0
All Pro Leafs
Fox 10" RR Shocks
All Pro Rear Bumper
Frontline Fab Front Bumper
ProComp 51 Series
Revenge-Fab Sliders
Daddy's Bed Bar
Icom V8000 w/ Larsen NMO150BK
Johnnie is offline   Reply With Quote
Old 03-30-2010, 10:19 PM   #2
tacotoy
Dun DUn DUN!
Default
what kind of valve?
99 Taco with 5 inches of lift and some toys....
12 Jetta TDI that the wife commandeered
03 Silverado tow pig double extra long green edition
tacotoy is offline   Reply With Quote
Old 03-30-2010, 10:24 PM   #3
Johnnie
Johnnie's Avatar
Default
Originally Posted by tacotoy View Post
what kind of valve?
Lawn Genie L7010 1" valve.
DADDY'S TRUCK
2001 PreRunner
SAW 2.0
All Pro Leafs
Fox 10" RR Shocks
All Pro Rear Bumper
ProComp 51 Series
Revenge-Fab Sliders
Daddy's Bed Bar
Old 03-30-2010, 10:59 PM   #4
Triple BB
Triple BB's Avatar
Default
Did they all turn on or just the ones you took apart. Sounds like a bad solenoid. If you have a valve that works, pull the solenoid and put it on the one that keeps turning on. And then put the bad sol on the valve that was working fine.
Triple BB is offline   Reply With Quote
Old 03-31-2010, 12:00 AM   #5
Trevor 3blacktoys
Trevor 3blacktoys's Avatar
Default
Dam Johnie.....you and your lawn issues....LOL....
The government is like a baby's alimentary canal, with a happy appetite at one end and no responsibility at the other.
-Ronald Reagan
If you believe in our 2nd amendment, please consider helping us keep it http://membership.nrahq.org/
Trevor 3blacktoys is offline   Reply With Quote
Old 03-31-2010, 09:22 AM   #6
tacotoy
Dun DUn DUN!
Default
eh.... solenoids usually default to off.... its either a control box issue - disconnect the solenoid wires and see if they shut off
or its a worn out diaphragm, they get weakened and then will flex on their own just from the water pressure.
either one is common depending on your control box, and i have never been a huge fan of lawn genie...
Old 04-05-2010, 07:41 AM   #7
joeylead
Default
that lawn genie valse is a knockoff irritrol (formerly richdel) valve. Toro also makes one that is similar. If the diaphram when back on ok, it should still shut off. usually they only have a small leak with a bad diaphram. When you took it apart, did you put the spring back in? That needs to be there. Also, did you remove the solenoid? Make sure the plunger didnt fall out. If either are missing the valve will stay on. Also, the black toro valves at home depot should work for parts (well there are two types but one will look the same). Look at one, it is the same thing...
On the lookout for a new rig
joeylead is offline   Reply With Quote
Old 04-05-2010, 10:34 PM   #8
Johnnie
Johnnie's Avatar
Default
I got it fixed. I don't think I had the diaphragm on correctly. I replaced it with a new one because that's what I was trying to do in the first place.
DADDY'S TRUCK
2001 PreRunner
SAW 2.0
All Pro Leafs
Fox 10" RR Shocks
All Pro Rear Bumper
ProComp 51 Series
Revenge-Fab Sliders
Daddy's Bed Bar
You may not post new threads
You may not post replies
Forum Jump
Tailight/Turn Signal Problem Aleco911 Interior/Electrical/Electronics 7 07-26-2008 11:59 PM
Turn signal problem Jasab420 Newbie Tech 2 04-14-2008 05:21 PM
Turn Signal Problem chrismx Interior/Electrical/Electronics 8 12-27-2007 04:36 PM
Turn signal problem Hutch98 Early Tacoma Tech 2 08-19-2006 10:18 AM
98 5VZFE Valve Train Problem TacomaUtah Early Tacoma Tech 10 07-29-2006 11:15 AM
