#1 |
Well after the carnage of the last comp I decided I needed a flat bottom. I called BudBuilt and he shipped me out this beauty:
The install is pretty straight forward. You will need to drill out the threading on holes 1-3. You will also need to remove the hole pin below hole 4 and above hole 8. It came with all the hardware including a new seal for the transmission. Install this with the metal side facing the front of the transmission. Here is where the new seal goes. It did create a problem in the cab that I had to cut out a lot. Here is where the tcase shifter ends up. Here is what it looks like now, with 37” tires, running chevy 63” in the rear and 44044’s with two leafs removed it sits at 28” from the bottom of the tcase to the floor. I can not find where I wrote down what the distance was before. The steel across the bottom of the picture is where the bottom of the frame rails are located. I am saving now for a set of PRP seats to install. Here is the truck as it sits now. While doing this I also shortened the wheel base by about a foot while replacing the rear most part of the frame that was bent. The passenger side frame was about 3” higher than the driver side. For more random pics of the work you can go here: www.r65.org/tacoma/framefix/ The install went very smoothly, I still need to cut the hole for the tcase shifters, bend the shifter and finish welding up the tcase/crossmember. |
#2 |
looks good....you need rear steer!
holley
formerly known as earl7
#3 | |
New Mexico Chapter
you don't have dual cases?
also what kind of "comp" do you do? I see no cage???? -David
www.nmttora.com 95 SFA Tacoma 60's (both spooled), Dual cases, Caged List goes on and on.... Quote:
#4 | |
Crime and Punishment
![]() Join Date: Mar 2005
Sweet how long did the install take?
04 Taco Locked and loaded front and rear Budbuilts / Chevy 63" springs / 285/75/16 AT 1980 1st Gen Detroit Front / Welded rear NC TTORA http://www.ncttora.com/ Quote:
#5 | |
I am saving for dual cases right now, that is why the hole in the floor is so big. I have been competing in some local comps in the stock mod class which if it has cab on it, it does not need a cage. I know its not the best thing, but after all these mods I will be bumped to pro mod I think. I just got a bender so as soon as I find a source for some DOM I will be putting an exo on it. |
#6 | |
#7 |
I was thinking about getting the BB clocker kit but I didn't know it required cutting a large hole in the floor pan. Would a stock Taco still need a hole in the floor pan to clear this kit? Thanks for the info.
2008 Trail Teams FJ Cruiser SOLD - 2003 X-Cab V6 4x4 TRD Badland's Rock Sliders\OME 881 & N91S's\M/T Classic II's\BFG AT KO's\ 4Runner Seats\Hella 500's\Line-X\ “Give them nothing! But take from them everything!” Leonidas, 300 |
#8 |
Retired
![]() Join Date: Dec 2004
Yes, unless you want to install a body lift.
Go to Bud's site and READ about the setup. It does say that modifications must be made to the floor of the cab.
-Thomas ![]() I love to buy my parts from TRDParts4U.com |
#9 |
I have been told that some have been able to do it with a hammer and I have also heard some made much smaller box. I made a larger to fit a marlin doubler in there later.
#10 | |
TTORA GOLD Sponsor
![]() Single case: You will need to cut the floor or run at least a 1" body lift. I trimmed mine about 5" front to rear and 9" left and right. You MUST either cut or use a body lift NOT pound for this one, because it is right under the front seat mount! Dual Cases: Just pound it or do the 1" body lift. It is under the driver's seat, and plenty of very thin sheet metal under there that moves easily. ![]() Does that help? |
#11 |
hardcore dude
Uhh no. (responding to my edit, haha)
Also, does this conflict with oil draining or circulation at all. I dont know much about t-cases. But kinda like if you rotate a engine too much it can prevent it from sucking up any oil. Or I imagine it -could- anyhow... Last edited by Kyota; 09-07-2005 at 08:53 PM. |
#12 | ||
New Mexico Chapter
-David
#13 |
TTORA GOLD Sponsor
Sorry man. Machining still required. Got a slick setup for doing it now tho, so it goes fast.
Lemme know when you are ready! Bud |
#14 | |
shane
i found the cure for hope |
#15 | ||
New Mexico Chapter
-David
#16 | ||
![]() My Rig: '00 Tacoma
![]() If you lose a seat mount how the heck do you bolt in your seats?? Jim's getting a stet of shifters to replace the OE ones, wee! now all I need is your xmember...hint, hint...before I figure out a way to make my temp xmember do the same thing, LOL have you come up with any other ideas on the e-brake relocate?
Inchworm Rock Walkin' Gear |
#17 | ||
#18 |
i'm hoping with my 1.5" body lift i won't have to cut or pound my floor at all. glad to see someone get this in, i'll be ordering mine in the next couple months.
2002 4Runner SR5 4wd |
#19 | ||
#20 | |
Yop is a new center plate only. Lower is our clocking xmember. Just finishing up the details, and we'll have these ready to go.
1st Place We Rock World Competitor. Front Range Off-Road Fabrication http://www.frontrangeoffroadfab.com Your source for rockcrawling Tacoma products. Diamond Axle http://www.diamondaxle.com World class axles, proven by WINNING WE Rock World Championships! |
#21 | ||
New Mexico Chapter
Nice!!!!!!!!
-David Quote:
#22 | |
Extra Cab Double Bed
| Thread Tools | |
| Display Modes | |
| List of 15" and 16" Wheels for Tacomas | Mikevr007 | Tires/Wheels | 179 | 08-10-2012 09:48 AM |
| Tacoma rear axle, 4.88 gears, master install kit, lockrite for sale... | sureshot40sw | Parts/Electronics/Wheels & Tires For Sale | 4 | 03-08-2006 07:04 PM |
| Master install kit necessary? | Miguel | Newbie Tech | 3 | 08-23-2005 03:20 PM |
| Affordable lift kit for a 2WD Tacoma | 98kickenTaco | PreRunner Tech | 2 | 04-27-2005 06:26 PM |
| Gear Install - Is master install kit required? | Vince | Early Tacoma Tech | 5 | 03-25-2005 11:48 AM |
