Best Battery For Tacoma - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 08-18-2010, 08:36 PM   #1
toyo58
Default Best Battery For Tacoma
I have a '95 4x4 tacoma. What is the best, most powerful battery anyone has used in their Tacoma? It seems the Tacoma has the pos and neg terminals different from most other batteries. The Sears platinum group 35 has 740 cca and 100 reserve minutes for what that is worth, for 189.00. It looks like a longer battery would fit, with more reserve power, but most other sizes have the polarity reversed. the cables could be lengthened but that may or may not be that easy or maybe neccesary. I have an ARB fridge and plan on winch, lights, etc in the future. My current Interstate battery wont keep the fridge on for a day without the fridge turning off due to low voltage. I live in Texas where the temp where the fridge is is 120 during the day.
Thanks.
toyo58 is offline   Reply With Quote
Old 08-18-2010, 09:20 PM   #2
jctaco02
My Rig: 2002 Tacoma PreRunne
Default
In that price range, look into the Optima Yellow top. It's desinged to run aux equipment in addition to being the main vehicle battery.
jctaco02 is offline   Reply With Quote
Old 08-18-2010, 09:24 PM   #3
NorCalTaco
NorCalTaco's Avatar
My Rig: 97 fo fiddy
Default
Time for a dual battery setup
NorCalTTORA
NorCalTaco is offline   Reply With Quote
Old 08-18-2010, 09:32 PM   #4
BattleWagon
BattleWagon's Avatar
Default
Been happy with my red top..
Had it for about 4 yeras and its still going strong!
Support Friends of The High Lakes!!
http://www.friendsofthehighlakes.com
87 4Runner Build (Current Rig)
http://www.ttora.com/forum/showthrea...65#post2159265
01 Dcab Taco Build..Sold 09/10
http://ttora.com/forum/showthread.php?t=156417
BattleWagon is offline   Reply With Quote
Old 08-18-2010, 10:30 PM   #5
fibbado
Default
There is a very good reason why people claim Optima' are the best battery. Yellow or Red they are the best out there, I kept a record of battery failures for the last three years at the shop I was running.
Duralast's were the worst, Optima's hardly ever fail. I had a customer with Optima's that were six years old in AZ...
2000 Tacoma TRD SR5 4WD
15" Steelies & 33" Cooper ST's
Bilstein CO's & 5100's
4XInnovations Bumpers & Sliders
XRC8 Comp, 20lb CO2
fibbado is offline   Reply With Quote
Old 08-18-2010, 10:51 PM   #6
miguelitro
miguelitro's Avatar
Default
Thanks.
i can multi quote
Team Bad Habits
Don't own one yet but there is nothing but diesel cruisers and tacos down here.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day. " ~Frank Sinatra
miguelitro is offline   Reply With Quote
Old 08-18-2010, 10:57 PM   #7
drabnor
Home Grown Tacoma
drabnor's Avatar
My Rig: 2000 Tacoma
Default
Originally Posted by miguelitro View Post
i can multi quote
I thought you were going to say, the best battery for a tacoma is the one you find on the side of the road
TBH IE division
Originally Posted by Scuba View Post
Did you read any part of the reply that just took me 10 mins to search for and write?
I know I hate having to poke my wire into such a tight hole...
mike
drabnor is offline   Reply With Quote
Old 08-19-2010, 08:00 AM   #8
Rob.hall
Default
Also check out Odyssey batterys. Same gel-cell design as the Optimas, but smaller and pack more punch.
'99 TRD 2.7l 4x4- pacesetter header, donahoes, camburg UCAs, deaver 8s with bils 5100s, pro comp 8069s wrapped with 32" STTs, custom prerunner bumper, and some other random shit
Rob.hall is offline   Reply With Quote
Old 08-19-2010, 08:06 AM   #9
szembek
Default
I have the stock battery still running strong in my '03. Unless you're doing somethign that specifically requires a lot of juice when the truck isn't running (which some of you validly are) no need to spend big bucks.
szembek is offline   Reply With Quote
Old 08-19-2010, 08:07 AM   #10
ROCTAC
ROCTAC's Avatar
My Rig: 1997 Tacoma
Default
Thanks.
I just put an Optima D-31M Blue Top in my truck. Biggest Baddest out there that I could shoe horn in. You just need to fab up a couple of brackets. The specs speak for itself. This bitch is huge!!
Battery Model: D31M
Part Number: 8052-161
Nominal Voltage: 12 volts
NSN: 6140 01 502 4405
Description: High power, dual purpose engine start and
deep cycle, sealed lead acid battery
Physical Characteristics:
Plate Design: High purity lead-tin alloy. Wound cell configuration utilizing proprietary
SPIRALCELL® technology.
Electrolyte: Sulfuric acid, H2SO4
Case: Polypropylene
Color: Case: Light Gray
Cover: “OPTIMA” Blue
Group Size: BCI: 31
Standard Metric
Length:
Width:
Height:
Weight:
12.774”
6.529”
9.370”
59.8 lb
324.46 mm
165.84 mm
238.00 mm (Height at the top of terminals)
27.1 kg
Terminal Configuration: SAE / BCI automotive and 5/16”-18UNC-2A threaded stainless steel stud.
Performance Data:
Open Circuit Voltage (Fully charged): 13.1 volts
Internal Resistance (Fully charged): .0025 ohms
Capacity: 75 Ah (C/20)
Reserve Capacity: BCI: 155 minutes
(25 amp discharge, 80°F (26.7°C), to 10.5 volts cut-off)
Power:
CCA (BCI 0°F): 900 amps
MCA (BCI 32°F): 1125 amps
Recommended Charging:
The following charging methods are recommended to ensure a long battery life: (Always use a
voltage regulated charger with voltage limits set as described below.)
Model: D31M
These batteries are designed for starting and deep cycle applications and for use in vehicles
with large accessory loads.
Recommended
1997 Toyota Tacoma linked SAS,
39s, ARBs, Bobbed, Exo, Full Widths.
1968 Ford F100 big block
03 Cummins 6 speed
09 Acura MDX
ROCTAC is offline   Reply With Quote
Old 08-19-2010, 11:07 AM   #11
toyo58
Default
Battery Model: D31M
Case: Polypropylene
Group Size: BCI: 31
Standard Metric
Length:
Width:
Height:
Weight:
12.774”
6.529”
9.370”
59.8 lb
324.46 mm
165.84 mm
27.1 kg
Performance Data:
Power:
Model: D31M
Recommended
So, how tall is the battery? It looks like I can fit 8.75, maybe 9" max from eyeballing it with a ruler from the bottom of the tray to where the hood closes. Looking from the right front of the truck, is the negative terminal next to the fender and closest to the windshield? Length I seem to have some room to play with, maybe 3" longer than stock. The cables are too short to reach to the front of the battery.
Old 08-19-2010, 11:37 AM   #12
ROCTAC
ROCTAC's Avatar
My Rig: 1997 Tacoma
Default
It's 9.375" tall. It fits once you move the battery toward the passenger side a bit, extend the battery tray, and build a new mount to replace the factory one. Took me an hour to fab up. My stock cables worked fine.
03 Cummins 6 speed
09 Acura MDX
Old 08-19-2010, 11:46 AM   #13
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
My Optima red top has been serving me well for years. I'll be sticking with an AGM battery since I'd killed several conventional batteries in my truck. The lead plates just don't like all the vibrations.
Next Socal TTORA event - Calico - Apr 11/12
www.ttora-socal.com
SoCal TTORA on Facebook
ShowStop is online now   Reply With Quote
Old 08-19-2010, 01:03 PM   #14
Duurty1
Default
i have my red top mounted on its side with screw in battery terminals on the side. Some how I got 2 red tops in a row that were bad- both lasted less than a year. I have had my current one in it for about 5 years and it still works just fine. The 2 previous ones were replaced under warranty from Optima. I got mine back when they were 90 bucks. These are what the military uses too.
97 2.7 5 speed
NWOR header
toytec C/O
OME rear springs
much more to come
Duurty1 is offline   Reply With Quote
Old 08-19-2010, 01:14 PM   #15
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
Look for yourself at the specs of both the Optima and Odyessy batteries.
Best way to make a choice...
http://www.odysseybattery.com/battspecs.html
http://www.optimabatteries.com/optim...wtop/specs.php
as for Optima choices... and being a sole battery...
I'd go with a Yellow Top.
I've run the same D34 YT (aux.) and D34R RT for near 4 years now...
without a glitch...
so I'm good with that.
My Aux. Yellow Top had taken tons of abuse from accessories and winching.
without fail nor a worry. Holds it's charge well when sitting and not in use.
The Red Tops are a little more finicky and should only be used in vehicles(as the primary) that are daily operated... as they don't seem to hold their peak charge as well, unless run on a daily basis. (just from my experience)
Either the Odyessy and Optima are capable, durable and reliable batteries.
These two different brands are probably the best known AGM type batteries on the market. So I'd pick one of the two.
For me... the Odyessy batteries seem a little overpriced...
and is likely why I'll never purchase from them.
Originally Posted by Scootn2nature View Post
so fuck off you little 18 yr old lying ass punk.
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is offline   Reply With Quote
Old 08-19-2010, 01:16 PM   #16
toyo58
Default
I have considered dual battery setup. Where have people placed them? If I were to get a AGM, would it be safe in the cab? Or would a box in the bed be better. Any tips on brands, use welding cable etc?
Old 08-19-2010, 01:24 PM   #17
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
If you'd like to run duals... and don't have anti-lock brakes...
I think that offsetting the weight has its advantages...
Link to my DB set up
Truck...
Trailer...
Old 08-20-2010, 01:03 PM   #18
AimCOTaco
AimCOTaco's Avatar
Default
I'm in the process of doing the optima 31d with custom stainless hold down. Almost done...then I may do a tiny red top on the fender for duals.
That said, the normal red top kicks ass for general use
Andy
-1999 UZJ100 -Black, BFGAT285/75-16, Optima D31, FRBv2's, WKOR sliders, ARB locked front, TC UCAs/ Iron Man T-bars, OME866, D/T headers/Magnaflow, Columbus RTT, Drawers n'stuff.
-2001 Tacoma 2.7L Reg Cab 4x4 -Silver,my DD/trail truck, Icon/TC mid trav front, GY Duratrac 265/75-16C, Budbuilt Skids, Optima D31
AimCOTaco is offline   Reply With Quote
Old 08-27-2010, 10:36 AM   #19
mgyver1
mgyver1's Avatar
Default
A group 24 size battery will fit in the stock location with no mods. It's considered the optional size for cold weather Canuk tacos. It's the same height & depth as a group 35, just a bit wider taking up all the space of that plastic tray.
For me being out here in Vegas, it seems no matter what battery you run, it's going to die with this rediculous heat, and at the most inopportune time. I tried one of those AGM dual purpose deep cycle/starting batteries and it lasted just shy of 2 years. So, I get the Maxx battery from Wally world. It's open 24/7 so when it goes out at 11pm the night before I have to be at work, I can replace it.
Also, my deep cycle sits in the bed under the toolbox.
That's just my
Mgyver1
Nevada TTORA
4X4HIM
Best In The Desert Racing Association
'02 Ext. cab Prerunner V6 Auto SR5 TRD
mgyver1 is offline   Reply With Quote
Old 08-27-2010, 01:11 PM   #20
BrownMike
BrownMike's Avatar
Default
x2 on Optima and Odyssey. Ive had two odyssey one was the tiny cube that was in my old eclipse and the other is my secondary in my taco (pc1200) and it works great! I usually pull it out and use it for my 9ft dinghy trolling motor too!
99 TRD Supercharged V6 5spd 4X4
33" Generals, Camburg SAW 2.5", Camburg UCA's, Deavers, TC 9" Shackles, FOA 16" Resi
BrownMike is offline   Reply With Quote
Old 08-27-2010, 01:26 PM   #21
AimCOTaco
AimCOTaco's Avatar
Default
I love the D31 also, just finished mine BUT, my positive to the relay box was too short. I posted a write up in electrical on replacing the cable. (I didn't extend the tray but did make a new top bracket).
Thread here...
http://www.ttora.com/forum/showthread.php?t=162880
Andy
Old 08-28-2010, 02:09 PM   #22
miguelitro
miguelitro's Avatar
Default
that full size truck battery I found has been treating me well
I have a optima yellow top for my aux battery, both are in the bed.
Mike
Team Bad Habits
Old 08-28-2010, 03:27 PM   #23
mrdoug
mrdoug's Avatar
My Rig: 3.4 swapped 85 xcab
Default
Sears platinum P1 for me.. I had to extend the cables a little, but no biggie.
880 CCA
135 RC
I believe it's an Odyssey under the covers
de·gen·er·ate
mrdoug is offline   Reply With Quote
Old 08-28-2010, 04:37 PM   #24
Scuba
Scuba's Avatar
Default
880 CCA
135 RC
Same one I have! I got away without having to extend the cables. Tight fit but it works. Needed a new hold down. No biggie.
It is an oddesy for sure. There's another thread around here with all that info.
There's also an email convo from an employee at oddesy confirming that the sears die hard platinums are rebadged oddesys.
99 Single Cab 2.7. Finally SAS'd and sitting on full width Toyota axles.
Scuba is online now   Reply With Quote
Old 08-29-2010, 12:37 AM   #25
10.5 tacoma
Default
Odyssey all the way !!!! buddy of mine droped one 8 feet and broke it all 2 shit, tested it 3hrs later and it was still 1300 amps. i run a 2150 in the back of my taco LOVE IT
10.5 tacoma is offline   Reply With Quote
Old 08-29-2010, 01:54 AM   #26
sasaholic
sasaholic's Avatar
Default
runnin a blue top right now solo, but soon to have a cheap costco battery for my starter and then ill use by bluetop for all my high draw shit
Never make your passion your occupation. it will loose it's luster and become work. that's why i never wanted to become a gynecologist!
1997 toyota 4 runner. lc coils and donahoe coils goin on soon with 255 75 17 brk km's on titan rims
sasaholic is offline   Reply With Quote
Old 08-30-2010, 08:17 PM   #27
Toyota4x46921
Toyota4x46921's Avatar
Send a message via AIM to Toyota4x46921
Default
I use the cheap ass ones from walmart.....3 year free replacement....I run an amp, pair of fog lights and pair of driving lights......not to mention radar detectors, gps and phone charger....and the 100 degree heat in Alabama....hasnt let me down yet.
2004 Tacoma Dbl Cab 4x4 3.4L, Lunar Mist, ARB Bumper, Icons on the front and rear....plus the 3 leaf progressive for the rear....
Toyota4x46921 is offline   Reply With Quote
Old 08-31-2010, 09:17 PM   #28
Lagunito
Lagunito's Avatar
Default
X2 And I'll add..
the warranty is a 3 year no questions asked warranty
2009 Tacoma 4.0 SR5 PRERUNNER
1999 Tacoma 3.4 SR5 PRERUNNER
Lagunito is offline   Reply With Quote
Old 08-31-2010, 09:27 PM   #29
Lagunito
Lagunito's Avatar
Default
Thanks.
For a portable camp refrigerator you would be better off getting a propane set-up
To run a 120 compressor you would need a bank of batteries or one huge son of a gun that would out weigh it's usefulness or only give you about 60 minutes of reserve time.
You also need to consider your alternator being abused from the constant cycling,
a solar panel my be another option if you still want to use a battery.
EDIT
I read the ARB fridge stats and still think you'll abuse your alternator.
and found propane refer that makes ice cubes for about half of the regular price of the ARB
http://www.propaneproducts.com/catal...ooler-470.html
Old 09-01-2010, 12:58 AM   #30
superman
superman's Avatar
Default
don't quote me but I've read countless threads of people saying the sears platinum battery is the same as the odyssey battery. i read where one guy called odyssey and he was informed that the sears platinum and the odyssey battery come out of the same manufacturer plant.
another thing is that on the optima battery you are not suppose to hook up winches to the side terminals because of a smaller gauge lead connector to the main battery post terminals that cannot handle high current or they have the potential to melt.
the odyssey and the sears platinum do not have this issue.
funny i just found a lot of information out there about this very same subject and from what ive read i would go with the sears platinum battery for sure. i know people love optima batteries and i trust their opinions on them.
im in the process of upgrading my my battery cables and all that right now myself.
98 ex. cab SR5 V6 4WD Tacoma (manual)
Total Chaos uca/ICON/8Deaver/Bilsteins
15X8 wheels in 33x10.5x15 bfg km2
superman is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
what battery group (size) for my 95 V6 tacoma lapaul Early Tacoma Tech 6 04-14-2010 03:42 PM
2006 Tacoma V6 Double 4x4 Battery??????? L.A.Fire Interior/Electrical/Electronics 7 01-06-2008 01:02 AM
Pics* Installed a deacent Duralast 1000CA battery in OEM location (Big ass battery) lotust Late Tacoma Tech 4 09-13-2007 01:36 PM
