Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Indiana Chapter > Tech
Thread Tools Display Modes
Old 10-06-2010, 07:56 PM   #1
Bear
H-O-L-Y-------S-H-I-T-H-H-A-A
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default New "top hat"
While I sit around staring at my in-operable truck, I decided to turn some scrap metal into something productive.
One troublesome area on any solid axle vehicle is the front diff. But especially for a vehicle equipped with a dana axle as the only protection from the rocks is a 1/16" cover.
So to protect all of this:
I started with the stock cover :
notice the nice saucer size dent right in the center of the cover
and I began with reconstructing the flange using the old cover as a template. I cut one inch strips out of a piece of 3/8" metal I had, and welded eight pieces together to make it. (no photos as I tend to become too absorbed in my work to take photos)
After taking precautions to make sure the flange was not warped from the heat of welding by clamping each end of metal to the bench as I welded. I copied over the bolt holes to the new flange. Unfortunately I guess Dana does not deem it important to keep the holes consistant as you can probably see some of the holes are close to the edge of the flange.
After making the flange, I cut the walls out of cardboard to construct my template for them. From the template I transferred the shapes over onto 1/4" metal.
After welding all the walls solid and again clamping the flange to the flat surface while welding to keep everything straight all the pieces went together nice and easy. I never had to recut a single piece.
while constructing the walls for the diff cover, I should mention that the stock D44 cover only has one fill plug. To drain the axle you must remove the cover do so. I have always hated that. So when I located fill plug inserts from Ballastic I ordered two. One as a fill and the second as a drain plug. The holes were cut before the actual wall pieces were cut and shaped to make things easier. Then once the walls were tacked in place the inserts were welded into place so that I could weld completely around not only the exterior side but also the interior side of the insert.
you can make both of inserts out in the photo above.
After the walls were put together. the diff cover actually was bolted to the axle to check for clearances. Everything checked out so it was onto making the "cap".
Again, I had another piece of 3/8" laying around so I traced where the walls landed on the plate and cut to size. So to recap the dimensions of the actual cover, I have the flange made out of 3/8" the walls made out of 1/4" and the cap made out of 3/8" where the stock cover was merely 1/16" or roughly 22 gauge.
From there I decided to add a little more weight to the cover and welded a "cage" around the cover out of 1/2" solid round stock. Total amount of metal used for this cage was exactly 4 feet. The cage top is not completely round but contours the cap fairly well. to bend it, I used my bare hands, vice, and at times a 5lb sledge. But with a little bit of patience I think the cage contours the cover pretty well. both the legs of the cage are welded to the flange as well as the intersection corners of the walls. Once the top piece of the cage was placed onto the legs. I also welded the inside of the "halo" to the cover of the actual diff cover.
This cage was completely overkill on my part, but what can I say, that is the way I like things, after all my spring hangers are made out of 3"x4" tubing with 5/16" plates actually holding the springs on. I have actually split rocks with my spring hanger without so much as slight bend to them.
Onto the photos, again, not any of the actual construction, but enough of the final product minus the finaly cleaning and painting of the "top hat"
you can see why I think it resembles a top hat from these photos
here you can see the extra space I built into the new cover. I did it for both added protection from any possible bomb going off as well as extra fluid capacity.
So there you have it, the new bomb proof diff cover I'll be pushing around and cracking rocks with if I can ever get the truck back on the trails.
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
… remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 10-06-2010, 08:28 PM   #2
Fuod
The original
Fuod's Avatar
My Rig: '04 TRD 4x4 X-Cab
Default
Is that a Briggs and Stratton back there?
Fuod is offline   Reply With Quote
Old 10-06-2010, 08:39 PM   #3
Bear
Bear's Avatar
Default
damn out of all this you pick out a lawn mower in the background
It is actually a craftsmen with a B & S motor.
BEAR
GO SPURS GO!!!!
Old 10-07-2010, 07:19 AM   #4
jason6746
inttora
jason6746's Avatar
Default
i think that should take care of the weak cover.
2001 tacoma 2.7 5sp.
with some
amsoil dealer
jason6746 is offline   Reply With Quote
Old 10-07-2010, 10:32 AM   #5
ron86toy
ron86toy's Avatar
Default
if it does not work out as a diff gaurd you can always throw it in the bed and use it as a porta jon
86 4 runner sas
toy-d60 hybrid with hi-pinion front
5.29's locked f/r
duals w/triple stick
hydro assist
LC Engineering 22re
37" comp Treps on forged Alcoa's w/ OMF BL
CBI bumpers/sliders
Tmax
218 dents
1386 scratches
Page 108 in CRAWL Nov/Dec '07
'83 stepside on 33's
ron86toy is offline   Reply With Quote
Old 10-07-2010, 10:34 AM   #6
Bear
Bear's Avatar
Default
nope! I'm more full of shit than what it will hold!
BEAR
GO SPURS GO!!!!
Old 10-11-2010, 08:28 PM   #7
brinner
Brian
brinner's Avatar
Default
yeah so now your diff holds more oil than your oilpan?
brinner is offline   Reply With Quote
Old 10-11-2010, 08:49 PM   #8
Bear
Bear's Avatar
Default
hahaha! I just got that reference!
but to attempt to keep this "tech":
I haven't calculated nor measured the extra volume of the diff cover yet. but I am estimating where the stock cover allows 1.66 quarts of gear oil, the new cover will probably hold roughly 3.0 quarts, which is where I want to be. it will allow for better lubrication as well as cooler fluid due to volume increase.
On the national board Cronus brought up the issue of over-filling. I had already made concessions about being able to calculate the amount of oil I add. Last night I found my old IFS dip stick. I plan to measure the length needed and then cut that dip stick down so that when I add fluid, I can actually use that stick to add the proper amount.
I am getting closer and closer to listening to you about swapping the 302 into the truck. If a few more test do not yield better or positive results my only other options will cost as much if not more than it would to build up the V8 and swap it in. So in the world of dollars and horsepower it is beginning to make more and more sense.
BEAR
GO SPURS GO!!!!
Old 10-13-2010, 08:49 AM   #9
brinner
Brian
brinner's Avatar
Default
plus with the V8 you move all the useable torque to the low RPM range which is where you want it if your a rock crawler....versus wanting mid RPM torque which is a characteristic of V6's. HP is never really the issue unless your looking for absolute wheel speed.
Old 12-07-2010, 09:53 AM   #10
Bear
Bear's Avatar
Default
forgot to post the final photos of the diff cover. got it on just prior to the rain and snow. glad I did! anyway! here are the final images
The paw is made out of individual pieces of 1/4" steel welded to the cover
BEAR
GO SPURS GO!!!!
Old 12-07-2010, 11:22 AM   #11
Fuod
The original
Fuod's Avatar
Default
That's purdy.
Maybe one day I'll actually see it hit something.
Old 12-07-2010, 12:06 PM   #12
Bear
Bear's Avatar
Default
Originally Posted by Fuod View Post
That's purdy.
Maybe!
BEAR
GO SPURS GO!!!!
You may not post new threads
You may not post replies
Forum Jump
""new price rock crawler rims"" chris85053 Classifieds 0 01-06-2008 10:07 PM
""new price rock crawler rims"" chris85053 Parts/Electronics/Wheels & Tires For Sale 0 01-06-2008 10:05 PM
"CheckEngine" + "E-Brake" light on when freezing Alex Early Tacoma Tech 4 11-04-2006 05:37 PM
WTB: 05/06 Tacoma badges "SR5", "V6", and "PreRunner" Matt151B Wanted 7 06-18-2006 12:06 PM
58 "known" and 188 "reasonably anticipated" cancer-causing substances PRB_Ohio Off Topic 0 01-31-2005 08:07 PM
Privacy Policy
Links monetized by VigLink
