#1 |
Search brought up few hits. Who here has abandoned their two piece drive line, and went for a single aftermarket unit? Thinking of going this route...really not that expensive when you figure in labor to repair a factory line.
thanks.
99 Tacoma, bug-shield, and air freshener. Rusty tailgate mod, oxidized paint mod, cracked windshield mod. |
#2 |
My Rig: 1999 tacoma
On an extra cab taco I think you would just be moving from a fairly safe driveline to a rock magnet.
Degenerate I like goats 87 cherocar 99 v6 trd taco-some stuff 07 Ninja 650R |
#3 |
thats why i have never done it.. however when i swap my engine and tcase mounts over to poly (pretty much solid) I am going to find a industrial carrier bearing without the rubber. one thats just the bearing mounted in steel/aluminum surrounding and mount it to a piece of 1x2 that dosent mover around..
4x4 Conversion Fabtech Coilovers up front and Deaver 7packs in back Hidden 10" sub under seat mod Trail Gear motor mounts, Trails less traveled T-case mount SAS soon to come....
#4 |
Pretty sure I need a new carrier, and my U-joint is also suspect. If the cardon is jacked too, it is going to be a pain in the ass. I also think the rubber around the carrier allows too much play.
#5 |
Yea i think once the center shaft is fully supported in place with solid mounting the only shaft that I will have a problem with is the 2 piece one... and I dont see many problems with that happening
#6 |
I've got a one piece...single cabs FTW
1997 Tacoma, Standard Cab, v6, 5spd, 4x4. PIAA 520 fogs up front Scan GaugeII mounted in my dash Shell, it helps to cover stuff. 2.5" DR coil spacer up front and a home brew 5 leaf in the rear. |
#7 |
My Rig: 1999 tacoma
#8 |
My Rig: 3.4 swapped 85 xcab
You really need to take the driveshaft profile as well as the terrain you normally wheel into account. It's not really a matter of preferring one style over the other or one being better than the other based on design alone.
Consider this: If you're climbing ledges in an xtra cab, a long one-piece will get trashed quickly. If you have a 2-piece and a short wheelbase, then you're pinion angle will be super steep with a pissed off pinion bearing. If you're mudding or mall crawling it doesn't make that much of a difference.
de·gen·er·ate I'm outside your window watching you read this. |
| Thread Tools | |
| Display Modes | |
| FS: 05+ 2-piece drive-shaft for AC auto.... | hilux30 | Parts/Electronics/Wheels & Tires For Sale | 1 | 10-21-2010 09:43 AM |
| NTB: 2 piece drive shaft from 98 xtra cab | Mythica | For Sale/WTB in CO | 0 | 07-01-2008 09:34 AM |
| One piece rear drive shaft? | slander | Early Tacoma Tech | 8 | 06-09-2008 01:32 AM |
| 85+ front CV drive shaft or taco 2 piece rear drive shaft | robinhood4x4 | Wanted | 3 | 11-12-2007 06:09 PM |
| 2 piece drive shaft | Captkirkyota | Classifieds | 16 | 01-22-2007 02:22 PM |
