Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Pickup/4Runner Tech
Thread Tools Display Modes
Old 12-07-2010, 01:15 PM   #1
countryboyAL
countryboyAL's Avatar
My Rig: 1989 pickup
Default 22re valve adjustment?
i need to adjust my valves, i was wondering if anyone had the gaps and the order you adjust them in.
flame away.
i did search
89 Pickup
AO front winch bumper, taylor fab sliders and skids, trailmaster lift in front, stock duals, 36x13.50 Irok, 4.88 gears, lockrite in the rear, 63" Chevy leafs
Originally Posted by TacoDell View Post
~ off road thought, for the day ~
" if ya wheel like an idiot... it probably shows "
Originally Posted by cztheman64 View Post
yeah but you wheel like Tim Cameron
countryboyAL is online now   Reply With Quote
Old 12-07-2010, 01:26 PM   #2
Kurtis
Kurtis's Avatar
Default
Haynes manual has all that stuff... I don't remember it off the top of my head but the manual gives a good layout of it as well.
1994 Pickup: Brand Spankin' New 22RE w/ New Cam SAS'd, 5.29 Gears, 7in Suspension, Dual T Case, Locked Rear on 36in.
2002 4Runner: Bone Stock.
The 2nd Amendment exists in case the government forgets the other ones.
Tears only make your gun rust.
Kurtis is offline   Reply With Quote
Old 12-07-2010, 01:27 PM   #3
Yotaoffroad27
Yotaoffroad27's Avatar
Default
flame away.
i did search
Found via Google.com
You can still do the adjustment cold, instead of running temp.
Just adjust them to .007 and .011 cold instead of .008 & .012 hot.
Only thing is, after adjusting them cold, and running it it around for a day or two, its a good idea to pop the valve cover off and recheck the adjustment.
While you have the valve cover off is a good time to inspect the tops of the timing chain guides, and timing chain.
Its been a wile since i Adjusted valves but I wanna say you adjust them in the firing order? 1-3-4-2
hope this helps!
-Yota
NCTTORA.COM
My Transmission swap
V8 4.7L swap
99 Tacoma- Stockish
87 4Runner- Not so Stockish
Originally Posted by *Darcy* View Post
.. I know you're extremely knowledgeable
Yotaoffroad27 is offline   Reply With Quote
Old 12-07-2010, 01:42 PM   #4
PTCBernie
Default Valve Adjustment
I know I'm going to catch all sorts of nasty comments for this post, but unless you're having problems or hearing a lot of noise I'd be inclined to leave them alone.
I'm on my 4th Toyota, plus 2 Hondas in between, and all the times I've done the valve adjustment I find myself going through a lot of work only to find that they're still well within spec and don't need to be adjusted. 20R, 20RC, 22RC, 3ZR, etc, etc, they are all excellent products.
Has anyone's experience been that they have found the valves to be out (assuming normal maintenance, oil changes, etc) ?
B
PTCBernie is offline   Reply With Quote
Old 12-07-2010, 01:58 PM   #5
Scuba
Default
i did search
really?
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
99 Single Cab 2.7. Awaiting 3 Link SAS.
Scuba is offline   Reply With Quote
Old 12-07-2010, 03:12 PM   #6
keepitonall4s
keepitonall4s's Avatar
Default
Why not just go to ncttora.com and download the FSM. That way you will have it whenever something like this comes up.
keepitonall4s is offline   Reply With Quote
Old 12-07-2010, 07:04 PM   #7
countryboyAL
My Rig: 1989 pickup
Default
because thats for a tacoma...
89 Pickup
Old 12-07-2010, 07:15 PM   #8
Yotaoffroad27
Default
there is more there than just tacomas.... ask me how i know
-Yota
NCTTORA.COM
V8 4.7L swap
99 Tacoma- Stockish
You may not post new threads
You may not post replies
Forum Jump
valve adjustment! Merkaba55 Performance/Engine/Exhaust 2 04-09-2008 02:23 PM
valve adjustment 91V6TOY Newbie Tech 1 03-03-2007 03:13 PM
valve adjustment on 3.4l fabtechprerunner Early Tacoma Tech 2 08-23-2006 11:42 PM
2.7 Valve Adjustment??? drewcruikshank Performance/Engine/Exhaust 12 10-23-2005 07:33 PM
V6 Valve Adjustment? Jerrym49 Performance/Engine/Exhaust 1 03-29-2005 08:43 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
