Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 03-04-2011, 03:36 PM   #1
ratboy85
Default tacoma to tundra brake swap question
if i swap the brake setups. from my 02 tacoma to a tundra setup wil my 15" wheels still fit over the tundra calipers.. how much bigger are the tundra calipers then the tacoma vs the tundra
ratboy85 is offline   Reply With Quote
Old 03-04-2011, 03:44 PM   #2
Scuba
Default
No.
99 Single Cab 2.7. Awaiting 3 Link SAS.
Scuba is online now   Reply With Quote
Old 03-04-2011, 03:53 PM   #3
ratboy85
Default
are they way bigger.. would it be possible to shave the corners down on the caliper or is ti a straight no
Old 03-04-2011, 04:08 PM   #4
AlexXx
AlexXx's Avatar
Default
research please its been covered in previous threads here.
AlexXx is offline   Reply With Quote
Old 03-04-2011, 04:08 PM   #5
hunter4runner
Banned
Default
it's a straight no, no amount of modification will allow the caliper to function and allow a 15 inch wheel.
hunter4runner is offline   Reply With Quote
Old 03-04-2011, 08:49 PM   #6
DocMcCoy
Canada Toyota 4 Wheel Drive
DocMcCoy's Avatar
My Rig: '98 Tacoma
Default
Straight no. Some 16" wheels that are not high dish style wheels don't fit.
White '98 TRD Extended Cab
Custom YotaFab Bumper, 10,000lb Superwinch, Lightforce Striker 170s, 35" BFG KM2s
Icon Coilovers, Total Chaos UCAs and Spindle Gussets, Alcan Springs, Bilstein 5150s
Manual Hub Conversion, Tundra Calliper Upgrade, Brembo Drums, SS Brake Lines
Fenders Cut, Bed Bobbed and Painted White
CT4WD Team - "See you on the trails!"
DocMcCoy is offline   Reply With Quote
Old 03-06-2011, 12:20 PM   #7
AI03Taco
AI03Taco's Avatar
Default
Hey there, i have a huge question about modifying the banjo bolt for the conversion, i have everything else down pretty pat but i just cant understand how to drill it out. any help would be much appreciated. thank you
NEW: 02' Taco TRD 4x4, V-6 Dbl Cab, 6in Fabtech lift, 315/75/16" PROCOMP Extreme A/T's, 4.88 Gears, Grey Wire, Tundra Brakes ----> All from 03' Taco
OLD: 03' Taco TRD 4x4, V-6, 5 speed, 6in Fabtech lift, 315/75/16" BFG M/T's, 4.88 Gears; Tundra Brakes, 4" Deck Plate MOD, IRS Removal MOD, Free Alarm MOD
Stay DIRTY My Friends!!
AI03Taco is offline   Reply With Quote
Old 03-06-2011, 01:23 PM   #8
yzrider3087
yzrider3087's Avatar
Send a message via AIM to yzrider3087
Default
If you pull out the banjo and look at it, its pretty straight forward. There are holes on the side of the bolt that sit in the banjo its self, and a hole at the tip of the bolt that goes into the caliper. The hole at the tip of the bolt is the one you want to drill out. I used a 1/4" drill bit if I remeber correctly. You drill the hole out just past the tapered part of the bit. that should be plenty. This allows the banjo to seat properly on the nipple inside the caliper... Also make sure when getting the brake lines back on that the copper washers seated as well, if you get the banjo bolt tight and the washers are squished youll need to drill just a hair more out of the tip of the banjo bolt.
I also used new copper washers. It helps insure a good seal.
2002 Xtra Cab 3.4L Auto TRD SR5-TRD Supercharger-TRD 7th Injector-TRD Headers-Catless Straight Pipe w/ TRD Catback- URD O2 Sim-Front 4" ProComp w/ OME 882's, Rear 5" AllPro Springs 1.5" Shackles and Bilstein 5125's-315/75/16 BFG KM2's on Black Steelies-Tundra Brake Swap w/ Slotted and Dimpled Rotors-Trail Gear Sliders-Demello Hybrid Rear Bumper-Custom Mounted XRC8 Winch-Viper Security w/ Remote Start
yzrider3087 is offline   Reply With Quote
Old 03-06-2011, 02:02 PM   #9
AI03Taco
AI03Taco's Avatar
Default
do you drill out any of the two holes on the side or just the one on the tip of the bolt?
Old 03-06-2011, 02:15 PM   #10
yzrider3087
Default
Just the one on the tip of the banjo bolt. Dont touch the holes on the sides. The only thing you are trying to accomplish by drilling out the tip of the bolt is to allow it to seat properly in the caliper. Without driling out the tip of it, the bolt wont even go all the way in... If you look inside the Tundra caliper you'll see the nipple in there, and it will be pretty obvious what drilling out the tip of the banjo is supposed to accomplish.
Old 03-06-2011, 02:17 PM   #11
AI03Taco
AI03Taco's Avatar
Default
awesome for the help, the truck is on stands right now and i'm going to go drill it out, thank you very much for all the help.
You may not post new threads
You may not post replies
Forum Jump
16" Wheels and the Tundra Brake Swap DocMcCoy Early Tacoma Tech 23 12-06-2012 09:56 AM
Tundra brake swap done-Now, brake pressure question? yzrider3087 Early Tacoma Tech 15 09-11-2011 09:47 PM
Tundra 231 Swap Brake Line Help Toy Boy Early Tacoma Tech 7 02-27-2011 09:38 PM
Feasability of Tundra brake swap in 2010 4x4 Tacoma Offroad with ATRAC DevL Late Tacoma Tech 4 05-25-2010 12:29 PM
Tundra Brake swap problems blackdog76 Pickup/4Runner Tech 10 08-25-2009 12:55 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
