3rd Member Gasket - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 09-27-2005, 11:22 AM   #1
Miguel
Miguel's Avatar
Send a message via AIM to Miguel Send a message via MSN to Miguel
Default 3rd Member Gasket
Hey all,
I just got my new 3rd back from the gear shop yesterday and I'm gonna put the axle back together today.
The entire assembly only has 11 miles on it so the gasket looks brand new still. I was wondering if it would be fine to re-use the gasket? Should I put a bit of silicone sealant on top of the gasket as well? Thanks!
~Miguel
(should this be in Newbie tech? Oh well...if it bothers you...cry)
Miguel is offline   Reply With Quote
Old 09-27-2005, 11:38 AM   #2
dyogim
dyogim's Avatar
Default
I have always used grey RTV sealant by Permatex. Placed a bead around the mounting surface of the 3rd member, bolted to housing(hand tightened), let sit for about 15-20 minutes, then tightened. Have had no problems of leaks.
Mike
SFA '00 Toyota Tundra V8(#5)
dyogim.blogspot.com
dyogim is offline   Reply With Quote
Old 09-27-2005, 11:55 AM   #3
tenntaco
tenntaco's Avatar
Send a message via AIM to tenntaco
Default
I've used copper, but, yes, this is the way to go. I'm not sure if one color or the other is better, though.
1997 FZJ80
1985 4Runner
tenntaco is offline   Reply With Quote
Old 09-27-2005, 12:30 PM   #4
equin
Default
My 99 didn't even come with a gasket from the factory. The various times I fooled with the 3rd, though, I always used RTV sealant. Never had a leak.
Ed Q.
03 Tacoma Ex Cab 3.4L TRD 4x4
equin is offline   Reply With Quote
Old 09-27-2005, 12:41 PM   #5
Fernslinger
Fernslinger's Avatar
Default
I didnt use a gasket, just RTV also.
Fernslinger is offline   Reply With Quote
Old 09-27-2005, 01:03 PM   #6
Miguel
Miguel's Avatar
Default
Would it be a bad idea to use the original gasket AND the RTV? Or should I just use the RTV? Thanks.
~Miguel
Old 09-27-2005, 01:08 PM   #7
Bear
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default
I would say one or the other, that thin cardboard gasket material really doesn't like to be mated up with RTV.
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 09-27-2005, 01:10 PM   #8
equin
Default
~Miguel
I don't know. I've only used the RTV gasket sealant on alot of drivetrain components - Taco 3rd member, Bronco 8.8 rear 3rd, Borg Warner 1356 t-case, t-case to auto tranny adapter, etc. It's supposed to act like a gasket in itself, although I must admit the BW 1356 t-case is currently leaking. Just out of curiosity, what material is your factory gasket made out of?
Ed Q.
Old 09-27-2005, 01:12 PM   #9
GOT COPE?
Big tars, little bed.
GOT COPE?'s Avatar
My Rig: 2000 Taco
Send a message via AIM to GOT COPE?
Default
toss the gasket and use RTV.
My Truck and Specs
Originally Posted by Yotaoffroad27 View Post
I think Colin just rides around looking for a good photo op.
Originally Posted by crawlrunner View Post
Blatent abuse of power ... but funny ... carry on ...
BRC since 2006www.sharetrails.org
TLCA #15854 www.tlca.org
SFWDA since 2005 www.sfwda.org
GOT COPE? is offline   Reply With Quote
Old 09-27-2005, 01:14 PM   #10
Miguel
Miguel's Avatar
Default
At quick glance, it looks like cardboard. Like I said, it looks BRAND NEW.
By the way, does anyone have the torque spec. for the 3rd member bolts on a 2003 E-locker axle? Thanks!
~Miguel
Old 09-27-2005, 01:14 PM   #11
Valkyrie
Cracker
Valkyrie's Avatar
Default
The Toyota factory FIPG (pink pig) seems pretty unpopular because it's not the cheapest stuff on the planet ($14), but I swear by it. Whatever you do, use a good sealer by itself and skip the cardboard gasket.
Valkyrie is offline   Reply With Quote
Old 09-27-2005, 01:21 PM   #12
Valkyrie
Cracker
Valkyrie's Avatar
Default
~Miguel
If you're talking about the 10 outer, it's 18 ft/lbs.
Old 09-27-2005, 01:24 PM   #13
Miguel
Miguel's Avatar
Default
Yea that's it. Thanks a lot.
~Miguel
Old 09-27-2005, 02:23 PM   #14
halfxspaid
halfxspaid's Avatar
Default
Sup shmag,
I would say to inspect the gasket when it comes off, if it looks ok, use it again with a thin layer of RTV. Have you checked Hanlees Toyota and priced a new one? I dont think it would be more than 10 bucks.
Just remember to clean the mating surfaces well, with a razor and then some carb cleaner maybe. See if matt has any suggestions.
2003 x-cab 4x4 TRD
1985 toyota 4x4
halfxspaid is offline   Reply With Quote
Old 09-27-2005, 02:26 PM   #15
halfxspaid
halfxspaid's Avatar
Default
Hrmmm, I hope you know something specific about the rear axles because MOST applications on engines require a thin cardboard gasket and RTV...
2003 x-cab 4x4 TRD
1985 toyota 4x4
Old 09-27-2005, 02:33 PM   #16
halfxspaid
halfxspaid's Avatar
Default
Found a pirate4x4 thread which would help...they say no gasket needed.
http://www.pirate4x4.com/forum/showt...=member+gasket
2003 x-cab 4x4 TRD
1985 toyota 4x4
Old 09-27-2005, 02:39 PM   #17
Valkyrie
Cracker
Valkyrie's Avatar
Default
Well, Bear does know what he's talking about, and so do I. Mating the cardboard gasket with either sealant on one side or both sides is more likely to result in a leak than just using sealant alone. Reusing the old one is just silly.
Like you said, the key is to scrape both mating surfaces as clean as possible from old material residue. I always "lightly" scuff the surface with 220 grit (paying careful attention to the area around the studs) and wipe down with solvent. When using FIPG, let it sit & form a light skin before installation. Some sealants should be abblied wet (no skin), so the directions should be followed.
Old 09-27-2005, 02:54 PM   #18
Miguel
Miguel's Avatar
Default
No gasket it is then! Closest thing I have to carb cleaner is WD40 so that'll do I guess. I'll clean that shit off nice and prawpa! Thanks for the help guys!
~Miguel
PS: HalfxSpaid's wang = large
Old 09-27-2005, 02:57 PM   #19
Valkyrie
Cracker
Valkyrie's Avatar
Default
~Miguel
WD-40? Who said use WD-40?
Come off the hip & spring for some acetone, paint thinner, brake clean, carb cleaner... anything that dries to the touch and does not leave an oily residue. Otherwise, you'll be doing it over.
Old 09-27-2005, 03:02 PM   #20
dyogim
dyogim's Avatar
Default
WD-40 will make the surface less adherent.
For about $5, get some brake or carb cleaner. When you are wiping the sureface are down on the housing, watch out for metal shavings. When I was cleaning the housing and widping it down with a paper towel I had a piece of metal shaving go into my finger about .5". Not horribly, just hurt like hell when I pulled it out.
Mike
dyogim.blogspot.com
Old 09-27-2005, 03:17 PM   #21
halfxspaid
halfxspaid's Avatar
Default
Was I saying otherwise?
2003 x-cab 4x4 TRD
1985 toyota 4x4
Old 09-27-2005, 03:46 PM   #22
Miguel
Miguel's Avatar
Default
Please bang your head one more time. 3 wasn't enough. I'll buy some "insert wide variety of appropriate solvent here" next time I get the chance.
I was only thinking about the cleaning part, not the adhesive part. I've used WD40 to clean metal many times so that was my first thought.
Commencing "coming off the hip (?)" 3...2...1...NOW!
~Miguel
Old 09-27-2005, 03:48 PM   #23
Miguel
Miguel's Avatar
Default
I saw exactly what you're talking about. Those look brutal!
Thanks for the heads up!
~Miguel
Old 09-27-2005, 04:01 PM   #24
Valkyrie
Cracker
Valkyrie's Avatar
Default
~Miguel
LMAO! Sorry, couldn't tell what you were "thinking", had to go by what you said.
Come off the hip is an old-timey term similar to pony up.
Here's 4 more for you being too young to understand my humor:
Old 09-27-2005, 04:01 PM   #25
Fernslinger
Default
~Miguel
I would think one or the other also.
Old 09-27-2005, 04:15 PM   #26
halfxspaid
halfxspaid's Avatar
Default
Hey, does your website sell books on how to deal with Elitist web-wheelers?
2003 x-cab 4x4 TRD
1985 toyota 4x4
Old 09-27-2005, 04:21 PM   #27
equin
Default
You mean elitist web wheelers like me? No, he deals with the likes of me in the worst way possible - with the torturous, ever hurtful guilt trip. Helps remove stubborn rotors in his driveway, sells parts at cheapest rates possible, offers great advice on where to go to get hard to find paint that matches paint codes, helps organize and coordinate wheeling runs, then invites us to 'em, all the while putting up with elitist web wheeling nonsense from the likes of me -
Ed Q.
Old 09-27-2005, 04:23 PM   #28
halfxspaid
halfxspaid's Avatar
Default
Thats great, doesnt mean I cant bust some balls if he makes some comments. A helpful ttora member is always welcome by me.
Old 09-27-2005, 04:29 PM   #29
equin
Default
I know what you mean. He actually wheels alot and has pretty much lent a helping hand on practically all the active users' Tacomas here in the DFW area one way or another. Kinda funny you mentioned "web-wheeler", though, since he's been calling me that for awhile now just to get me to go out on the trails with him and the rest of the crew - hehe! Not that I don't want to go with them, I've just had my wheeling trips crossed with another 4x4 group lately. Hence, I couldn't resist replying. But I digress.
Just to stay on topic and wrap things up - use RTV sealant to create a gasket for the rear diff, but first wipe it clean (carefully) with carb cleaner or some other such solvent.
Ed Q.
Old 09-27-2005, 04:36 PM   #30
Valkyrie
Cracker
Valkyrie's Avatar
Default
LMAO! search n00b...
You may not post new threads
You may not post replies
Forum Jump
WTB: 4:88 3rd member Zackattak Wanted 2 09-05-2005 01:11 PM
rear 3rd member? JDUBTacoMUD Wanted 5 08-14-2005 07:51 AM
3rd member grumpy Wanted 10 05-05-2005 09:29 AM
Where to buy Toyota 3rd member md1 Early Tacoma Tech 5 03-31-2005 07:07 PM
Removing 3rd Member? 2LONGTOY89 Early Tacoma Tech 6 03-30-2005 07:21 PM
