Pressure plate torque specs? - TTORA Forum
Go Back   TTORA Forum > General Tech > Performance/Engine/Exhaust
Thread Tools Display Modes
Old 05-09-2011, 05:36 PM   #1
sasaholic
sasaholic's Avatar
Default Pressure plate torque specs?
im finally putting my truck back together after my major oh shit and im doin my last minute read ups. the torque specs for the pressure plate to flywheel are 14ftlbs. is that right? it sure seems low to me, but just checkin with the pros here before i get all greasy. thanks guys
Never make your passion your occupation. it will loose it's luster and become work. that's why i never wanted to become a gynecologist!
1997 toyota 4 runner. lc coils and donahoe coils goin on soon with 255 75 17 brk km's on titan rims
sasaholic is offline   Reply With Quote
Old 05-09-2011, 11:57 PM   #2
hunter4runner
Banned
Default
if thats what the fsm says, lock-tight it lock-tight every bolt you cannot see once its assembled
hunter4runner is offline   Reply With Quote
Old 05-10-2011, 07:52 AM   #3
Jomentum
Old sleepy guy
Jomentum's Avatar
My Rig: 97 T100 Sas on 36's
Default
Torque the 6 bolts on the clutch cover.
Torque:19 Nm (195 kgfcm, 14 ftlbf)
Yes, not much required for those little bolts.
Joe P....
My T100: http://www.tacomaterritory.com/forum/showthread.php?t=76817
www.yotaranch.com/home
Originally Posted by sasaholic View Post
its spelled BITCH and thats exactly what u are
Originally Posted by TOYMINATOR View Post
my girlfriend works
Jomentum is offline   Reply With Quote
Old 05-10-2011, 09:42 AM   #4
Avsfreak1234
Avsfreak1234's Avatar
My Rig: 98 Taco, 35s n Stuff
Default
I was about to replace my clutch this weekend and was surprised by that as well. seems low to me but thats what the FSM calls for!
Avsfreak1234 is offline   Reply With Quote
Old 05-10-2011, 06:39 PM   #5
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
Default
Would it be a good idea to blue loctite those? Just out of curiosity for when I have to do my clutch
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is offline   Reply With Quote
Old 05-10-2011, 06:55 PM   #6
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
Those torque specs are correct and that is really all you need. I often dab a little blue loctite on a couple of the pressure plate bolts, but its really overkill IMHO.
Next Socal TTORA event - Miller Jeep Trail - June 13
www.ttora-socal.com
SoCal TTORA on Facebook
ShowStop is offline   Reply With Quote
Old 05-10-2011, 08:27 PM   #7
hunter4runner
Banned
Default
I use red loctite on everything that I can't see once assembled, I mean if red it stronger and costs the same why not right?
Old 05-11-2011, 09:53 AM   #8
mrdoug
mrdoug's Avatar
My Rig: 3.4 swapped 85 xcab
Default
You'll have fun breaking those bolts loose next time you have to take whatever apart.
I only use red loctite in a few places, crank bolt, hub and knuckle studs (SFA), button head bolts replacing diff studs. Everything else is blue.
After seeing a truck or 2 loose things on the road (clutch slave, pinion flange) I'm kind of anal about loctite'ing everything.. overkill I'm sure, but I shouldn't be finding any missing bolts/nuts.
degenerate
mrdoug is offline   Reply With Quote
Old 05-12-2011, 02:30 AM   #9
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
yup....and don't over torque them...they snap fairly easily...DAMHIKT
blue locktite!
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 05-12-2011, 08:33 AM   #10
sasaholic
sasaholic's Avatar
Default
awesome thanks guys i got her back together yesterday. wouldnt fuckin believe it though one of the nuts for the rear driveline (at the tcase) got all fuckered up and there some wierd fuckin thread that the closest place to me that had one was 125 miles away. fuckin superfine thread metric shit. and when my shit went boom it actually broke one of the mounting bolt ears off the block so im short a bolt, but im not buying a new block or pulling it to half ass weld it. ill wait till something else happens(hope it doesnt) and do a swap. oh well its all back together and everything feels good. the marlin clutch feels light just like everyone says, but seems to grab hard as hell. thanks everyone that helped me out along the way
Old 05-12-2011, 05:39 PM   #11
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
thread on those is 1.0
If you are only using 3 drive line bolts it will fail in short order. you need a replacement end asap. is this on the front or rear?
I have a bunch of spare DL bolts/nuts.
Old 05-12-2011, 10:18 PM   #12
sasaholic
sasaholic's Avatar
Default
oh no i didnt drive it without that nut. i already got a replacement and took it for a drive. i took my canopy off and it raised the rear and now i need bigger pinion shims cause i have a vib again. i know there 1.0, but are a 10 mm?
Old 05-13-2011, 01:46 AM   #13
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
the bolts are not an off the shelf item...dealer only. I think 10mm
I can send you a couple if you want. what about the broken ear??
You may not post new threads
You may not post replies
Forum Jump
torque specs? amishclark Newbie Tech 2 03-31-2011 10:30 AM
torque specs? dblnaknak Late Tacoma Tech 2 03-05-2008 09:56 PM
Torque Specs przn2nv Late Tacoma Tech 2 12-08-2007 05:41 PM
3rz rod cap torque specs taco420 Performance/Engine/Exhaust 6 10-18-2006 08:34 AM
Lug nut torque specs? HawaiiBuilt Tires/Wheels 1 06-11-2005 07:04 AM
