The center support bearing on the Tacoma's is garbage, so I searched around for the "solid carrier bearing" part number and found it, but it's since been discontinued from the mcmaster-carr catalog so I found the beefiest one I could. I looked into the ford superduty carrier bearings, but they were expensive and I couldn't find one in stock nearby. Pretty much any high rpm 1.5" ID pillow block style bearing will work, but this one just so happens to line up exactly with the factory bolt holes (which I drilled out and put 1/2" bolts in), precisely fits the factory shaft, drops the centerline a few degrees, and it's only $101.51. It's amazing how much noise the d-shaft flopping around makes, the solid bearing quieted it right up.
http://www.mcmaster.com/#2722t25/=cjr53h
