#1 |
just consolidating this now that i have real internet
the tank is a 1990-1997 ford F-150 rear gasoline tank. the diesel version is the same but its fuel pump will be different. the fuel pump that goes with the gas unit is close enough to the toy 3.4 unit (possibley others) that people have had this swap for years without issue. the tank sits in the stock spare tire location up and out of the way for the most part. so on with it... the cost I have about $350 into this mod. I had hoped to come in $100 less, but my tank source was pretty expensive at $225 for the tank/pump/sender and mount brackets. in the past people have gotten the tank/pump/sender for only $50 the tank its 18 gallons (same as stock) @and 34-3/4" x 27" x 7-7/8". you can safely pound that down to 25" by flattening the pinch weld on both ends(yup just like your wheel wells). the tank is also oddly deep in a small area at the rear. that can be pounded down as well without loosing more then a 1/4 gallon. -they come in plastic too -make your own air purge line so you can fill faster at the pump. -evap (charcoal canister) line is 1/4" low preasure fuel line ![]() ![]() the fuel pump the ford pump ues nice quick release fittings. feel free to go through the trouble of adapting to them...or cut them off as most do lol. leave as much tube as possible to clamp to. I think it runs at roughly 35 psi and i worried hose clamps wouldnt hold, but they make special fuel hose clamps that do great at the job. The sending unit is said to have the wrong ohms for our system. feel free to put effort into making it work only as rough estimate...or dont even bother with it and use a ultraguage or scanguage. -light motor oil on the pump seal 0-ring will aid in installation -fuel return is 1/4" low pressure fuel line -fuel feed is XX" high pressure fuel line -fuel pump + is red, negitive is black -toyota harness fuel pump + is blue/orange negitive is white/grey? ![]() fuel filler hose -45deg pre bent 2" exhaust piece -2" fuel filler hose (expensive $19 per foot. measure three times lol) -fits up high on the stock filler neck -2" is not a tight fit for the tank or the neck but its close enough to hose clamp down -air purge fitting is XX" on the stock filler neck ![]() connecting to stock fuel lines - 1/4 fuel return and evap fit perfectly - fuel feed can clamp to the flange of the toy fuel feed line but this is ghetto. so far its working fine though. ![]() 2011-07-11_08-26-54_858 [quote author=Scuba link=topic=8999.msg97851#msg97851 date=1310323665] Tank mount ![]() Forward mounts ![]() You can see the forward mounts as well as the holes drilled through the bumper tube for the rearward mounts ![]() [/quote]
Garage Last edited by Jomentum; 04-09-2012 at 08:50 PM. |
#2 |
Very nice
#3 |
I'm assuming you could do the same thing in a 1st gen Tacoma as well with success?
Stephen Offroadsc.com 98 Taco - stuff 97 TJ - lots more stuff |
#4 |
Looks good!! I'm saving this one for when I get around to it. That fuel tank fits perfectly! Did you use an online source or a junker yard?
Semper Fidelis 1998 4cyl 5spd 4 Runner 1982 mini 4x4 Slowly learning one repair at a time |
#5 |
Does it sit flush with the frame rails or does it hang below? body lift?
1997 4runner SC V6 | URD 7th | Stubbs Sliders | SAS | FROR FF Kit |
#6 | |
It has a 1" body lift.
99 Single Cab 2.7. Awaiting 3 Link SAS. |
#7 | |
Come and Take it!
![]() My Rig: '01TACO-DCLimitedTRD
Sweet job!
Hey check you last few pics, they did not show up.
Ciao! - - Nathan - -The "UN"-Official TTORA Welcomer '01 Tacoma DCab (some mods - click here) '00 BMW Z3 (more mods) + '12 MINI Countryman ALL4 (NO mods) Have fun and do not wheel alone. Quote:
TTORA Member since Nov 18, 2005 - - TLCA Member since June 4, 2008 - - EX-PO Member since Nov 18, 2005 |
#8 |
Has anyone done this on a 2nd gen runner? I'm trying to get my shopping list together and just noticed it was for a 3rd gen.
Owner: Times Are Tough Toys 92 4 Runner trail truck first, DD second. Joyce, long story from my time in Africa. Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Stolen from a friend at a garage sale. 71 Chevy K20, Clifford, new to me tow rig we will see how it goes. |
#9 |
Looks like it fits pretty nice.
#10 |
I would say so but you'll have to get creative with the fuel filler neck.
-The Brain |
#11 |
Its doable. Not too bad. I have to fight mine to fill it sometimes but it works. The tank hangs under the frame by about 2" at the lowest point and I used the factory ford and Toyota fill locations. Worked out pretty good. However I am planning to build a custom fuel tank this winter.
#12 |
When I did my tank swap, I drilled an additional hole through the fuel pump top plate and added an additional wire. Then used the stock Toyota sending unit, so my fuel guage didn't read backwards. If I ever drop the tank I'll post picture on how it was done.
You might want to add a skid plate, even though the tank sits up quite high, I still managed to land on a rock on the Rubicon and crush a corner of it. Locally around where I live you can pick up a complete tank with pump for around $125 from the junk yards.
99 SR5 4Runner Highlander 5spd V6 4WD e-locker |
#13 | |
truck ~n~ tow
![]() My Rig: '00 Tacoma
pounding on that... could mean less reserve fuel ? ![]() definitely needs some plate protecting that fuel tank ![]() good luck with it
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras... Truck... ~n~ ...off road action photo's Trailer... Truck build --- Trailer build |
#14 |
Pretty cool cheap trick!
#15 |
Could this be done as a secondary tank? My one gripe about our 3rd gen is the pitiful fuel tank range. I'm getting around 200 miles to a tank. Compare that with my t100 which gets 350. Then again the T is 100% stock. lol
| Thread Tools | |
| Display Modes | |
| Rear axle swap | Thunderklees | Long-Travel Suspension Tech | 5 | 11-13-2009 09:17 AM |
| 86 4runner axle swap | llwerx | Tell us who you are | 2 | 04-04-2009 07:09 AM |
| Axle swap...TRD rear into non? | 1990dlx | Early Tacoma Tech | 9 | 01-08-2008 09:36 PM |
| trd to non trd rear axle swap ?????'s | darwink1 | Early Tacoma Tech | 31 | 08-09-2007 07:43 PM |
| WTB 4runner rear axle or taco rear axle, NEED BADLY! 96+ | Tacominator | Wanted | 2 | 08-07-2007 04:06 PM |
