Sponsored Ad
Go Back   TTORA Forum > General Tech > Performance/Engine/Exhaust
Thread Tools Display Modes
Old 08-31-2011, 06:32 PM   #1
4wd_mofo
4wd_mofo's Avatar
My Rig: 2001 badass red
Send a message via AIM to 4wd_mofo
Default Failed Smog need help!!
Well the 99 4x4 V6 taco went in today to get smoged. CO2 is fine, HC and CO fine, it's the damn NO (PPM) whatever the frunk that means. I live in California and they are strict as a MOFO on in this bitch. Max value at 15mph is 512 and i ran a 685. Realized that i had the deck plate mod open, and closed it up to make it stock again. put some 91 octane in, ran it hard for about 60 miles then came back. Second go dropped from 685 down to 601.
The truck is stock, outside a K&N drop in and deck-plate mod, and 2.5" cat back piping with flow-master muffler. This bastard passed 2 years ago no problem. It's Got 197K miles on it, I've had it for 4 years, and put 54K miles on it. Only thing i can think of is to swap out the O2 sensors. IIRC there are only 2, one in front of the cat, one behind. Any help would be great, thanks!
1997 4x4 V6 5-spd (SOLD)
1999 4x4 TRD V6 (SOLD)
2001 Taco V6 (red) Lifted and sh!t
2005 Yamaha R6 (red)
Originally Posted by Scuba View Post
You CAN'T HANDLE THE TRUTH!!
4wd_mofo is offline   Reply With Quote
Old 08-31-2011, 06:53 PM   #2
Wainiha
My Rig: 2000 Tacoma
Default
NO is nitrous oxide.
Do you have a check engine light on?
Vacuum leak?
Clean MAF?
Do you cats rattle when hit(loose material inside)?
Bad O2 sensor?
Maybe Seafoam it.
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline   Reply With Quote
Old 08-31-2011, 06:56 PM   #3
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
High NOx readings are usually caused by high combustion temps and or a failing cat. One of the functions of the cat is to reduce the NOx levels. Assuming your cat is good due to the other readings and the comment about your deck plate, I'd look at a possible issue with the EGR not functioning correctly or the fuel mix is too lean.
Clean the MAF if you haven't already. You can buy specific MAF cleaner spray at the autoparts stores. NEVER touch the sensor element, just dowse it with cleaner and let it air dry. Next, check to be sure the EGR is opening and closing by drawing a vacuum on the top port. If you reach under the EGR (when cold), you should feel the diaphragm retract.
If you have never replaced the front O2 sensor, then it is due. They are only rated for about 100k miles of use anyways. www.sparkplugs.com has good prices on Denso OEM replacements or you can get factory OEM from www.toyotapartsales.com
Also, if you haven't done a tune-up recently, do that. Just changing the spark plugs and the oil has a noticeable effect on the smog performance. Make it a habit to do a tune-up and oil change before you get a smog check. You'll have far less issues. Don't forget to change the PCV valve also.
If none of that helps, then its probably time for a new cat. You can always inspect it with a flashlight to see if the honeycomb is largely intact with no deep holes.
Next Socal TTORA event - Miller Jeep Trail - June 22
www.ttora-socal.com
TTORA-Socal on Facebook
ShowStop is offline   Reply With Quote
Old 08-31-2011, 06:57 PM   #4
4wd_mofo
4wd_mofo's Avatar
Default
Vacuum leak?
Clean MAF?
Bad O2 sensor?
Maybe Seafoam it.
i changed the plugs and wires at 180k, should be fine. The cat hasn't even been on the truck for almost 2 years. i put it back on a month ago so the ECU would work with the O2 sensors to remember what a cat is like. No CEL, no codes, no leaks. Sense the other read outs on the smog are good the only thing i can see would be a problem with be a leak, or the sensors. it's $53 each on amazon.com right now, for replacement Denso o2's. gonna order them up and see how it turns out.
Old 08-31-2011, 07:02 PM   #5
4wd_mofo
4wd_mofo's Avatar
Default
yea, been running Royal purple since 155K miles, that was recently done. The cat is fine, when i pulled it 2 years ago it looked fine, and it just sat in the garage, doubt it went bad. I didn't even know we has PCV's on these. never even looked. I have cleaned the Throttle body 2 times, and never the MAF, and never the O2's. the stupid kid i bought the truck from with 144K miles took it to a shop that changed on only one side of the block (the easy side) spark plugs. So i change them every 30K. Should go get a PCV and check the EGR.O2's wouldn't hurt, been debating doing them cuz my MPG have been slowly getting worse.
thanks for the link but Amazon's got you beat :P
http://www.amazon.com/Denso-234-4162...1999&carId=001
Old 08-31-2011, 07:03 PM   #6
gotblika
Default
Not sure which one you need, but Amazon has the best price I think.
Denso 234-9001 Oxygen Sensor (Air and Fuel Ratio Sensor)
Denso 234-9003 Oxygen Sensor (Air and Fuel Ratio Sensor)
gotblika is offline   Reply With Quote
Old 08-31-2011, 07:08 PM   #7
4wd_mofo
4wd_mofo's Avatar
Default
Originally Posted by gotblika View Post
umm, those don't fit a 99 tacoma 3.4V6...
Old 08-31-2011, 07:13 PM   #8
gotblika
Default
oKKKKKKKKKKK
Old 08-31-2011, 07:20 PM   #9
4wd_mofo
4wd_mofo's Avatar
Default
oKKKKKKKKKKK
dont get mad, get glad
Showstop, the PCV was covered in oil, looks old as hell and kinda makes a little noise when i shake it. Sounds like its nearing the end of it functionality. The hose that was attached to it as well is cracking at each end so im going to replace both, cheap fix but i think over all the O2's are going to get me to pass.
Also, how am i suppose to check the EGR? im a little confused by your instructions.
Old 08-31-2011, 07:27 PM   #10
Wainiha
My Rig: 2000 Tacoma
Default
Blow through the PCV only one direction will allow airflow IIRC, if it's good.
3.4 TRD
ICON C/O
Marlin Clutch
Old 08-31-2011, 07:46 PM   #11
tacoma2k
Default
The 3.4l V6 dosen't have a EGR system on it.
tacoma2k is offline   Reply With Quote
Old 08-31-2011, 09:31 PM   #12
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
^ that's a fact
Originally Posted by Scootn2nature View Post
so fuck off you little 18 yr old lying ass punk.
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is offline   Reply With Quote
Old 08-31-2011, 10:04 PM   #13
thehackman15
thehackman15's Avatar
Default
I wish.
96 Regular Cab V6 with some stuff....
thehackman15 is offline   Reply With Quote
Old 08-31-2011, 11:30 PM   #14
4wd_mofo
4wd_mofo's Avatar
Default
Originally Posted by TacoDell View Post
^ that's a fact
lol, you were suppose to say " is that a fact?"
Old 09-01-2011, 01:15 AM   #15
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
you can verify if you have an EGR system by looking at the emissions sticker under the hood. All California emissions vehicles will have an EGR.
The EGR is a valve with a round metal cap on it near the back of the engine. On the top, there is a vacuum line that goes to the center of the cap. This opens and closes the EGR valve. Using either a vacuum gauge or just some kind of vacuum pump, draw a vacuum on that line to make sure the EGR opens and closes.
www.ttora-socal.com
Old 09-03-2011, 01:41 AM   #16
4wd_mofo
4wd_mofo's Avatar
Default
very true, I live in CA, and that is where the truck is from. It has an EGR, I can clearly see it. I just sold my MR2 spyder yesterday, so i got $$ now and will be buying 2 new O2 Sensors. I'll let you know the outcome of the newest smog when i take it next week. I believe the O2 sensors are the originals, due to the lack of maintenance before i bought the truck with 144K miles.
P.S. how was big bear? if my lift and tires where installed i would have gone but i needed to sell the car first for the new rear suspension...
Old 09-03-2011, 12:51 PM   #17
So.Cal Taco
Default
Run a tank full of Chevron Get it in the system you will see a big diff on your test my Brother owns a Test only Station.
So.Cal Taco is offline   Reply With Quote
Old 09-06-2011, 12:28 AM   #18
4wd_mofo
4wd_mofo's Avatar
Default
where you located? I might bring my taco by
Old 09-06-2011, 12:55 PM   #19
simigeology
simigeology's Avatar
Default
I would replace your front O2 sensor. I had the same issue with high Nox and 200K in mileage.
1995.5 Tacoma Ext Cab, 2.7L, 33-inch BFGs MT KM2, 4.56 gears, lock-rite in rear, 2.5" SAWs, Custom Deavers, 5125 Bilsteins, LC Eng Header, K&N FIPK, High Flow CAT, 40 Series Flow Master, LC Eng Short Shifter, KC Highlighters, Revenge-Fab Sliders, CBI Front and rear bumpers
simigeology is offline   Reply With Quote
Old 09-06-2011, 11:47 PM   #20
4wd_mofo
4wd_mofo's Avatar
Default
they are only $53 on amazon including shipping. Im going to do both, do you know if the front one is different from the rear one? gotta find some time to get under the taco when it's under 100 degrees outside...
Old 09-06-2011, 11:55 PM   #21
Wainiha
My Rig: 2000 Tacoma
Default
Don't know about your year but CA emissions vehicles are different and I believe at one point they all switched. Front O2 was replaced with A/F sensor.
I have a 2000 taco CA emission spec. The front sensor is an Air/Fuel and the rear is an O2. 250$ for the front and 100$ for the rear.
3.4 TRD
ICON C/O
Marlin Clutch
Old 09-07-2011, 12:49 PM   #22
4wd_mofo
4wd_mofo's Avatar
Default
how can i tell if it's a Air/Fuel vs. O2. And my understanding is that any O2 is an Air/Fuel...
Old 09-07-2011, 01:28 PM   #23
simigeology
Default
I went through www.sparkplugs.com that Showstop mentioned above. I called them for my truck since Denso had several different part numbers. Based on their website and your truck their are 3 different part numbers for the front and 4 for the back. They all say 02 sensor. When I bought mine the different part numbers were related to the length of the electrical wire. I measured the electrical wire and called in the measurement. www.sparkplugs.com matched it up and It was delivered in two days. I believe they came out of Corona so you being in Diamond Bar might be one day delivery.
Old 09-07-2011, 02:35 PM   #24
4wd_mofo
4wd_mofo's Avatar
Default
oh thank god. I just looked at the o2's on my taco, the part numbers do not match the ones on Amazon.com. However, the ones on sparkplugs.com do match up with the ones on Amazon. i see there are 4 wires coming out of each O2. I guess i'll measure then order both.
Old 10-01-2011, 06:16 PM   #25
4wd_mofo
4wd_mofo's Avatar
Default
Now here's the kicker, a month ago my numbers for the NO(PPM)
15mph test=685 Max allowed is 512
25mph test=479 Max allowed is 765
So i plugged up the Deck plate mod, put the truck back to stock minus the K&N drop in filter, and the flowblaster exhaust. Ran $15 worth of 91 octane and drove the truck hard for a day. Returned the next day and got these numbers
15mph test=601 Max allowed is 512
25mph test=505 Max allowed is 765
So again i failed the second test. got the new O2's in, a new vac line and PCV valve, runs great, no CEL and my MPG seems to be a little better. Drove for about 4 days after i replaced them and reset the ECU (unplugged the neg on the bat). I got to another Smog only station (just incase the one i was at wasn't working correctly) and i get these numbers
15mph test=676 Max allowed is 512
25mph test=540 Max allowed is 765
WTF?!?! it got worse after i replaced the O2's! So now, i'm going to change out the spark plugs (even tho there is only 14-16K on the ones in there now) And run a can of sea foam thru the Brake vac line into the intake manifold and some in the tank. Maybe run some 91 octane again, seemed to help. I'm out of ideas, need to get this smogged asap. The worst thing is, i found my smog report from 09, about 19K miles ago, I got these numbers...
15mph test=142 Max allowed is 512
25mph test=8 Max allowed is 765
Old 10-01-2011, 10:48 PM   #26
thehackman15
Default
Just dealt with the same exact deal. Check your egr valve and the modulater. Replace if needed or try and clean them out.
Old 10-01-2011, 11:01 PM   #27
4wd_mofo
4wd_mofo's Avatar
Default
You had 600+NO(PPM) readings? where were they? I got a can of MAF cleaner, going to do that and the SeaFoam tomorrow. How do i clean the EGR? take all the hoses off and blow it out with my compressor?
Old 10-02-2011, 09:42 AM   #28
thehackman15
Default
Yes I did I would fail the 15mph test by leaps and bounds then the 25mph test I would pass. The egr is bolted to the back of the intake manifold. There are 2 bolts holding it onto the manifold and 2 bolts holding the tube to that. If you take it off you can see a bunch of carbon build up and crap in it, but having cleaned my once before i just said screw it and bought a new one from toyota. The modulator has 3 vacuum lines coming off of it and one on the bottom that attaches to the egr. These are all on the back of the motor near the firewall. and no blowing it out with an air compressor wont get that stuff off, you'll have to remove it and hit it with some carb cleaner or something. I've also heard of people soaking the egr in gas, but I don't know about all that.
Old 10-02-2011, 01:17 PM   #29
4wd_mofo
4wd_mofo's Avatar
Default
Good looking out, i'll check that today when i'm working on the taco. maybe tues or weds i can re-smog the truck and see how things are.
Old 10-02-2011, 06:46 PM   #30
Jomentum
Old sleepy guy
Jomentum's Avatar
My Rig: 97 T100 Sas on 36's
Default
NOx is caused by high combustion temperatures:
The egr releases exhaust back onto the intake, and displaces the amount of combustible matter in the cylinders.Because NOx forms primarily when a mixture of nitrogen and oxygen is subjected to high temperature, the lower combustion chamber temperatures caused by EGR reduces the amount of NOx the combustion generates.
The EGR is either clogged (passage between the valve and intake)
or the Vacuum system is not working properly.
easy way to test EGR valve, is to pull a vacuum line on the intake, and use it directly on the EGR valve, the engine should run rough or stall out.
The other three components to check for the EGR system, are the EGR vacuum modulaor, the Vaccum switching valve, and the Engine Computer.
Joe P....
My T100: http://www.tacomaterritory.com/forum/showthread.php?t=76817
www.yotaranch.com/home
Originally Posted by sasaholic View Post
its spelled BITCH and thats exactly what u are
Originally Posted by TOYMINATOR View Post
my girlfriend works
Jomentum is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Failed smog, horrible mileage...wtf? YoTRacer158 Performance/Engine/Exhaust 11 06-09-2010 02:55 AM
smog failed. Rylee_xxx Performance/Engine/Exhaust 2 06-24-2009 09:53 AM
22r failed smog Camstoy86 Pickup/4Runner Tech 8 12-05-2008 10:59 AM
1996 v6 FAILED CA SMOG zracing Early Tacoma Tech 17 09-24-2008 09:45 PM
Failed Smog.. then Passed Smog mrbigbri Early Tacoma Tech 17 03-31-2007 06:08 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
