Sponsored Ad
Go Back   TTORA Forum > Rock Crawling Tech > Solid Axle Swap Tech
Thread Tools Display Modes
Old 12-11-2011, 09:59 PM   #1
dyogim
dyogim's Avatar
Default To replace or not replace.....wheel bearing cups
I've replaced my wheel bearing cups (inner and outer for my HP44) when replacing the bearings in the past but, have always noticed the surface to be unmarked and looked as the day I bought them. I know they sell them separate from the bearings and they are not that expensive to replace. What are your thoughts on replacing the bearing cups or keep them and just replace the bearings?
Mike
SFA '00 Toyota Tundra V8(#5)
dyogim.blogspot.com
dyogim is online now   Reply With Quote
Old 12-12-2011, 06:22 PM   #2
taco4x4rar
taco4x4rar's Avatar
My Rig: 06 Tacoma
Send a message via AIM to taco4x4rar
Default
You talking about the races? I've always thought (and practiced) that when you replace a bearing, always replace the race along with it.
Originally Posted by Jomentum View Post
I drink everclear for the flavor.
Originally Posted by Spacecwboy View Post
I'm still a homo!
http://toyotaoff-road.com/
Randy
2006 Tacoma x-cab 12" bobbed bed and the usual 3" lift with a locked rear and a lot of broken parts. Dana 44 soon
1992 Chevy C-1500 swapped D60/14bolt 454 and th400 (wrecked it)
taco4x4rar is offline   Reply With Quote
Old 12-12-2011, 07:15 PM   #3
dyogim
dyogim's Avatar
Default
So have I but, I've always noticed that the races are always sold separately from the bearings. If it was really reaquired, I would think the races and bearings would be packaged together.
Mike
dyogim.blogspot.com
Old 12-13-2011, 09:52 PM   #4
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
Default
Bearings will always wear into a race even if you can't see it with the human eye
Not to mention some manufactures may sell the same part number, but the taper or dimensions are very slightly different
It's like replacing brake rotors, but not changing the brake pads...
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is online now   Reply With Quote
Old 12-14-2011, 08:34 PM   #5
TRoss
TRoss's Avatar
My Rig: 1985 Toyota Ext PU
Default
x2 typical maintenance practice. Get the "matched set" (bearing and race together in the box from the manufacturer... it's cheap and easy insurance.
Ted
Project BR
TRoss is offline   Reply With Quote
Old 12-14-2011, 08:39 PM   #6
Jomentum
Old sleepy guy
Jomentum's Avatar
My Rig: 97 T100 Sas on 36's
Default
Different bearings/race combinations, fit multiple applications..
Joe P....
My T100: http://www.tacomaterritory.com/forum/showthread.php?t=76817
www.yotaranch.com/home
Originally Posted by sasaholic View Post
its spelled BITCH and thats exactly what u are
Originally Posted by TOYMINATOR View Post
my girlfriend works
Jomentum is offline   Reply With Quote
Old 01-05-2012, 12:32 PM   #7
dyogim
dyogim's Avatar
Default
Started changing out my front wheel bearings/races last night. Come to find out the inner race had a crack. I believe this was causing the "flat" spot when the driver side was rotating. So, as everyone else has stated and what I've always done in the past, it's best to change the races when changing the bearings.
In the process of installing the new bearings/races. The inner bearing/race was the wrong one (Timken part# Set37). Autozone gave the ones for the small bearing instead of the big bearing. Going back today to get the right ones. Luckily, at around 10pm AngryAndy found a brand new spare inner bearing/race in his garage. Picked it up and finished the install for the driver side. Now, to get the correct bearings and finish the other side tonight.
As a note, I got all Timken bearing/races/seals from Autozone for around $85 total. Outer bearing/race Timken part# Set45, Inner bearing Timken part# LM104949, Inner race Timken part# JLM104910, Wheel hub seal Timken part# 471271. Parts Mike has the complete kit for around $72(plus shipping and tax).
Mike
dyogim.blogspot.com
You may not post new threads
You may not post replies
Forum Jump
How to replace front wheel studs mac1234 Early Tacoma Tech 8 07-09-2011 09:42 PM
Should I replace the clutch and TO bearing at the same time? Stretch Newbie Tech 23 10-15-2010 11:09 AM
rear axle bearing replace at seal change? johnc Early Tacoma Tech 0 12-14-2007 12:10 AM
Should I replace the wheel bearings? Balgie Early Tacoma Tech 6 12-13-2006 02:23 PM
How do I know when to replace the rear wheel bearing? ricomann Early Tacoma Tech 9 12-09-2005 06:58 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
