#1 |
My Rig: 1985 Pickup
My truck currently has a long single piece rear driveshaft, it is bent all to shit. Do I just retube it or go get a stock two piece rear driveshaft?
~ Todd 85 ex. cab with the usual stuff on 38's 01 Dodge Ram 2500 w/ a Cummins.....Tow rig |
#2 |
Mr. President
Do you have a doubler? I like my two piece, except it is hell on carrier bearings. The cheapest and easiest would be to retube
~Jed 1984 Pickup Extended Cab - Trail Rig Locked F/R, 4.88's, 35's, Hi-steer, Twin stick, Dual cases, Flatbed 1986 4runner - e-locker, 4.56's, 31's 2004 Chevy 2500HD Duramax 4x4 - Tow Rig 2004 Tacoma Extended Cab SR5 TRD 4X4 - SOLD Blue Ribbon Coalition #51205 PhotoBucket Page OHTTORA |
#3 |
My Rig: 1985 Pickup
No its got a single 4.7 case, in the future I want duals though.
If I go two piece I should be able to just go to the pull a part and get a complete unit and bolt it in. Th single piece is a little long and low hanging now, but it will get bettet with duals.
#4 |
Mr. President
Being an extra cab, it should have had a two piece from the factory. I can tell you though, the two piece ones are hard to come by. I've been looking for a spare section for about 6 months now.
#5 |
My Rig: 1985 Pickup
There are two at my local u pull junkyard. Problem is they close for winter so I couldn't retrieve one till spring.
Does yours have a cv in it jed? I cant remember if they do or not. My current shaft does not and I think it would be better if it did.
#6 |
Mr. President
I assume you are refering to the double cardon joint? No, the rear shaft doesn't have one, just the front shaft.
#7 |
My Rig: 1985 Pickup
Local drive shaft will retube it cheap so thats what i'm gonna do. What should I use? Sch. 40 pipe maybe?
I actually would like to get another and keep my current one as a spare. It works, just wobbles a little
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| one piece driveshaft | RAB89 | Early Tacoma Tech | 8 | 12-04-2008 08:33 AM |
| 1 piece driveshaft | Fonz | Late Tacoma Tech | 11 | 10-20-2008 01:49 PM |
| One-piece Driveshaft | HoeRunner | Long-Travel Suspension Tech | 35 | 01-09-2008 08:24 PM |
| To those with a One-Piece Driveshaft | garycoleman | Late Tacoma Tech | 3 | 02-07-2007 10:34 AM |
| Anyone done a 1 piece driveshaft? | badcop621 | Late Tacoma Tech | 1 | 10-06-2006 07:21 PM |
