#1 |
My Rig: 1985 Pickup
I have been shopping for a trailer now for a while, and was getting frustrated. Everything nice I found I could not afford and I did not want any of the junk I could afford. What to do?
Well new years eve I bought this for a song. ![]() It started life as a 1983 Jayco camper. I bought the frame from a guy who scrapped it out. It was 26' long when I bought it, it had dual 4500lb axles both with brakes. I took them apart and repacked the bearings and they were in good shape. All 4 brakes work as well. My first task was to put a lift kit on it. This was neccesary to get it to clear my dodge and ride level. It is also gonna allow me to deck over the tires instead of having fenders. To lift it I simply moved the springs from the bottom side of the axle to the top. Next up I bobbed it to 20'. 26' was not enough for two rigs and it got kinda flimbsy toward the backend so I choped it down for maneuverability purposes. I then dovetailed the last two feet so I got a 18' flat deck and a two foot slant. Next up is wireing, then decking, and new tires and wheels. When its all done I should have about 1100$ in it. I think that is dam cheap considering what I will have. I will snap some more pics this weekend.
~ Todd 85 ex. cab with the usual stuff on 38's 01 Dodge Ram 2500 w/ a Cummins.....Tow rig |
#2 |
My Rig: 1985 Pickup
Worked on it more today doing reenforceing and framing, should finish that up tomorrow then gonna clean it up a little and paint it before we deck it.
![]() ![]() A couple notes: 1. Every bit of steel that was on it at 26' is still gonna be on it in some shape or way at 20'. 2. According to the title it weighed 6180 as a camper. I will miss my guess if it does not weigh less complete with my truck on it. And that weight is dry weight on the camper.
#3 |
Mr. President
Looking good. It's too late now, but you probably should have kept the flat deck at 20' and then the dove tail. Cause I bet the first time someone asks you to move something, you are going to wish you had that extra couple feet. (cough, Eric
)Are you doing a wood or steel deck? I would make sure to use a good chassis paint for the frame. Not necessarily POR-15, but at least something equivalent in rust stopping protection. Cause we all know what Michigan and Ohio winters are like.
~Jed 1984 Pickup Extended Cab - Trail Rig Locked F/R, 4.88's, 35's, Hi-steer, Twin stick, Dual cases, Flatbed 1986 4runner - e-locker, 4.56's, 31's 2004 Chevy 2500HD Duramax 4x4 - Tow Rig 2004 Tacoma Extended Cab SR5 TRD 4X4 - SOLD Blue Ribbon Coalition #51205 PhotoBucket Page OHTTORA |
#4 |
My Rig: 1985 Pickup
I am gonna use treated lumber for the deck, I am not a fan of steel decks. I am prolly just gonna use tractor paint from tsc for it, the stuff is cheap and really quit durable. The thung is rock solid just surface rust.
#5 |
Im with head on leaving longer. I have filled my 18 flat deck and i dont have a gooseneck to deal with. and i heard treated lumber will slowly eat the steel cause of the chemicals so you may want to look into that.
#6 |
Mr. President
With a good coat of paint, and some tar paper between the wood and the frame, I think he will be fine. I like the wood decks more because you can screw stuff down to it and it is alot cheaper to replace
#7 | |
#8 |
My Rig: 1985 Pickup
I had never heard that about treated lumber, I just assumed that that was what new trailers came with. I stoped at Menards tonight and they say that it may have been true in the past that the treated would corrode the steel but that their treated they sell now will not. I am gonna go to an actual lumber yard tommorow and see what they say
On the length, there are a few reasons I cut it to 20' 1. Like I stated earlier....it got a little flimbsy out at 26'...these camper framed are not the strongest, it is more than strong enough to do what I want, but its not like going out abd buying a 26' deckover 5th wheel equipment trailer. Buy hacking it off at 20' and reusing the steel to reenforce the trailer I have 20' of space I dont have to worry about instead of 26' I do have to question. 2. Dodges like mine are tall from the get go, add in the fact mine is on 33's and it is up there. Even with the springs fliped I think the trailer is gonna sit uphill a little. At 26' there was alot of rear overhang and I think I would have been draging the rear alot even if I had not dovetailed it. At 20' even dovetailed I have minimal overhang and 22" of ground clearance aproximately. That will allow me to take that trailer most anywhere. I think it would easily go accross the tracks in Wellsvile. 3. I have access to much bigger, heavy duty trailers if I need one.
#9 |
My Rig: 1985 Pickup
I asked around a bunch ans searched with google and can get do difinitive answer on the whole treated lumber deal. Most people seem to think that it will be fine but that trying to isolate the treated from the steel wouldn't be a bad idea so thats what i'm going with. I was gonna use tar paper like Jed suggested but that was gonna be a real pain in the ass covering each little thing. What I am gonna do instead is buy a few cans of rubberized undercoating in spray cans and simply spray it anywhere wood could touch metal. This will be way easier and should provide a nice insolater between the two.
A couple more pics 1. Incase you did not believe that I put all the steel I cut off back on, this is proof. That is everything that was not put back on, everything else I cut off is in some way welded back on ![]() 2. Built a rear bumper out of an old I-beam. Will give me a place to hook ramps ![]() Should have it wired tomorrow and then on to paint this weekend. What color do I paint it? Towrig is dark gray, trailrig is cream. Kinda thinking I want something other than normal old black.
#10 |
Mr. President
Black is definately your cheapest option. But if you want it unique, I would match it to the towrig.
#11 |
My Rig: 1985 Pickup
It would not be an exactmatch since my towrig is metallic, and I don't have the skill or time to do that,nor can I see spending that much money on paint for a trailer. I am gonna go to tsc and see if they have a dark charcoal gray paint of any kind and go from there. I also thought about a dark silver color since my towrig has silver pinstripes and they look really nice against the charcoal gray.
#12 |
My Rig: 1985 Pickup
What do you think about my undercoating idea? Think it will work?
#13 |
Mr. President
I don't see why it wouldn't.
#14 |
My Rig: Shorter Bus
plum
I am General Corrosion Corrosion: - 97 4runner 2.7 (fat and slow) lost but not forgotten Shorter Bus: - 98 taco 2.7 300k miles (fat, old and slow) lost but not forgotten Short Round: - 97 single cab (2' of sheet metal) Too nice: - 99 4runner 3.4 5spd DD |
#15 |
My Rig: 1985 Pickup
Got taillights / turnsignals and brakes all wired, once I get it decked I will need to add some additional marker lights.
For the color I am really leaning toward silver. Gonna work this weekend at preping it for paint / painting it. Only took one pic tonight.....it can fly!!! Lol
#16 |
My Rig: 1985 Pickup
Got the hitch in my dodge today...must say it is super easy to install in a dodge like mine compared to chevys or some others. Hooked the trailer up and adjusted everything to get it riding correctly
![]() It sits on there pretty decent as is and would haul ok. The new tires I am getteing are a couple inches taller which will help. I am also likely going to toss a leveling kit on the dodge to get rid of the forward rake which will also help. The bad news is I have no way to paint it till the weather gets warmer . So for now I am just gonna do the stuff the decj is gonna hide then in the spring I will flip it on its side and fully paint it.
#17 |
Mr. President
Looking good. Is it just me or does it seem like the axles are pretty far back?
#18 |
My Rig: 1985 Pickup
They are a little far back. I didn't feel like going through all the work of moving them, especially since my truck is sprung really heavy. And the extra weight up on the truck is not any issue. Really about 1' forward is all the more you would want them to go and it was gonna be a lot of work for not alot of gain.
#19 |
My Rig: 1985 Pickup
More progress. Should br done with everything except wheeld / tires tommorow.
#20 |
Mr. President
Looking good. What are planning on using for tie-down points?
#21 |
My Rig: 1985 Pickup
![]() Loaded a truck on it today....that truck weighs 6200lbs. Also weighed the trailer....weighs in at 2720....it and my dodge come in at 9100 lbs together. Towed it about 50 miles at speeds up to 70+ and it tows and rides awsome!!! For tiedowns I mounted some loops up front and on back. I will take some pics tommorow.
#22 |
Looks good, nice budget trailer!
#23 |
My Rig: 1985 Pickup
Thanks!!
It will work for now.....in the future I would like to cut it apart up in the front. The vertical piece at the front of the deck that the "tounge" attaches too needs to be about 3-4" taller. Its not a huge deal but it bugs me cause its not square. I have 20' of 3" x 4" heavy duty c-channel in my garage, so phase two will involve lifting / reinforcing the front hitch part.
#24 |
My Rig: 1985 Pickup
So the state of Michigan has decided to be assholes about plateing it. I got some ideas though on how to give them the big
#25 |
My Rig: 1985 Pickup
![]() Sets on there good. I have to do something with it though....i hate the way the trailer sits high in the front and the truck sits high in the back....they need to be more parralell. I am gonna start with the truck I think since I hate how it sits way ass high all the time. From the factory it has a 4" block under the rear springs, so I am either gonna toss it and put a 2" block in its place or toss the block and springs both and run a 2" lift spring with no block. The second option is what I would prefer...just depends on what the springs cost. At that point I will reassess it and change the trailer too if I have to. Droping the truck 2" will actually allow me to drop the hookup point close to 5" since the truck and trailer will be more paralell and I willl be able to adjust the hitch down lower while maintaining clearance at the tail gate. Of course if I was not a broke ass I could have just cought a trailer that worked right in the first place
#26 |
Out of Money
Todd will the trailer tongue hit the bed sides if the cab is a little nose down and turning? Just seems really close in the pic but that is just how pic's can be some times.
#27 |
My Rig: 1985 Pickup
It wont hit but it gets close...in that pic the truck is downhill and the trailer is tipped toward the camera. That is what I am trying to fix by lowering the truck. Problem is the truck does not drop at all when you hook the loaded trailer to it.
#28 |
My Rig: 1985 Pickup
Got it plated today....didn't have to jump through hoops or pay out the ass either.
state of michigan
#29 |
My Rig: 1985 Pickup
Towed my truck with it for the first time saturday. Holy shit does this thing tow nice!! I could not be happier...and I towed it with the old junk tires so it should be better yet now since I got new tires and wheels for it saturday as well.
#30 |
My Rig: 1985 Pickup
towed it 100 or so more miles.....this time with the new tires....works perfect....now just need to paint it
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Crawler Hauler (International Box Truck) | justinh | Classifieds | 5 | 02-22-2008 05:40 AM |
| RC Crawler budget build parts list?? | wmflyfisher | Off Topic | 9 | 08-18-2007 10:53 PM |
| Trade: 2 85 Pickups for one 4-Runner Crawler......hard core 85 crawler+mint 85 Stock | BikeMan | Rigs/Trailers For Sale | 32 | 07-07-2007 11:16 PM |
| Crawler Hauler | Mike | Off Topic | 39 | 05-30-2006 12:37 AM |
