Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. ATTENTION: In an on-going effort to keep this forum spam free, the Forum Admin approves every new account before giving any posting rights to new users. Accounts are normally approved within 24 hours. Sorry for any inconvenience, but verification of every new account is what will continue to keep this forum spam free. |
Thread Tools | Display Modes |
#1 |
My Rig: toyota
What are the pros and cons of removing the cat? I have removed them off a 3.0v6 and a 3.4v6, mainly because at the time it was the thing to do. Here is SC we dont have to worry about emissions. I now have a 90 4x4 with a 22re 170k miles that runs like a top. I know it gets clogged and all but serves a purpose. Would you cut it or not? why?
03 DC trd 4 DOOR 4X4 |
#2 |
Im currious about the same thing.
My 1992 pickup 3.0 is missing the Cat as well. And throwing a O2 code Doesn't run quite right and thought Maybe the cat being gone might have Something to do with it..... Sent from my DROIDX using Tapatalk 2 |
#3 |
Member Dismemberer
It is against federal law to remove the stock catalytic converter. Leave it on there. The exhaust is tuned with the cat hooked up in-line.
Next Socal TTORA event - Miller Jeep Trail - June 22 www.ttora-socal.com TTORA-Socal on Facebook |
#4 |
From what I have recently learned, the cat is used to do nothing but reduce the amount of pollution your vehicle is putting out by burning te remaining oxygen left in the exhaust. Hence oxygen sensors before and after the cat. The engine makes adjustments to fuel trim based on the inputs from those two sensors. The first sensor tells how much O2 is stl present and the second checks the cats work. The ECU takes the info from those sensors and adjusts accordingly to perform as well as it can while meeting emission limits. If you have bad cat, the engine throws a code. Bad sensors fwd or aft, the engine throws a code. Off roaders and racers use hi-flow cats or no cats at all to get the best performance from their vehicles however, for the engine to Perform at the highest level the ECU must think that it's still doing its job correctly. So an O2 simulator is slapped on in leu (or in URD's case, in conjunction with) the downstream O2 sensor to let the ecu know all is fine and dandy. So, removing the cat can improve overall performance. The only caveat is that the downstream O2 sensor must be tricked into letting the ecu know that it is keeping within hippy- I mean federal emissions standards.
You and I have a rendezvous with destiny. We will preserve for our children this, the last best hope of man on Earth, or we will sentence them to take the last step into a thousand years of darkness. -- Ronald Reagan 98 4runner- Front Toytec adjustable billy coils. Rear OME 891s W/ billies. 285/75/16s. Deckplate mod. Soon to come- Cool stuff |
#5 | |
My Rig: THE HARD TACO
#6 | |
Con's? Check engine light unless you install the O2 SIM, Illegal in "some states" Most 22R's/22RE's I've seen don't throw codes when we yank the cats, certain years will though. The only reason anyone should/would remove a cat is it's restrictive (can be a good OR bad thing), and when they go bad some people (like me) don't wanna throw a benjamin at something that could be replaced with a piece of pipe. |
#7 |
My Rig: toyota
Heres what I know, when I removed mine from my 3.0v6 I loved it. Felt a little more pepy and the sound was great. On my 3.4v6 nothing changed except it through a code, exaust sound was minimal to none. Now debating on the 22re. Just thought cutting it off would help the 90 horses breath.
#8 |
NorCal Chapter Pres
You'll probably do more harm than good because the motor needs backpressure...
Hi, my name is Phill, above are things I say W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today! |
#9 |
My Rig: 1957 Land Rover SI
In general terms, you can gain by removing the cats. You typically gain upper RPM power and throttle response, but you also generally lose low end torque.
In practical terms, depending on how new the vehicle is, you might create a problem with the engine management system. As was mentioned earlier in this thread by TrailBlazin', you need to fool the rear O2 sensor into thinking the cat is in and working properly. If you just remove it and don't do anything else, the EMS could go into some version of limp mode and back the timing down as well as dump fuel into it to keep it from burning down. Here's a case and point for each scenario: My 1957 Rover with 1992 22RE, de-smogged (except EGR) and no cats. This rig doesn't care, but it does run a tad richer. And my 1997 Tacoma with 3RZ, the cat got stolen before I bought the truck, so it had a "test pipe" in it...went into complete limp mode and got about 10 MPG.
Stoffregen Motorsports 530-392-8032 |
#10 |
On my 98' w/5vz fe, I gutted my cat and installed URD O2 simulator.
It seems to have better throttle response high end and low end. It picked up over 3 mpg. If getting it Inspected is not a problem, yank it!
98' tacoma ext.cab limited Lefty toytec bilstein coilovers, Dakar rear leaf springs, w/5125's, e-locker/rear, aussie/front 4xinnovations sliders w/ 32x11.50 buckshots relentless fab front bumper Smittybuilt XRC-8000 Light force 170's |
#11 |
if anybody has a 01-04 2.7 with the oem cat and is thinking about cutting it off let me kno cause ive seemed to having nothing but problems since both of mine were stolen the magnaflows seemed to work for a little while but i belive theyve finally thrown a code i just recently put the 02 simulator on it to combat the code
02 taco 2.7 4x4 addicted offroad front bumper tg sliders saw 2.0 Bili 5125 OME Dakars Open 4.88s Mickey Thompson classic II 16x8 285/75/16 Nitto all-terrains |
#12 | |
![]() JK |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| CS Pulley removal - post bolt removal | jwtacoma | Early Tacoma Tech | 10 | 04-27-2010 10:32 PM |
| Fan Removal Help Please | SCYotaMan | Performance/Engine/Exhaust | 9 | 09-16-2008 12:44 AM |
| ABS removal... | =ACID RAIN= | Tech | 6 | 11-13-2006 04:00 PM |
| S/C removal | SCGeorge | Performance/Engine/Exhaust | 21 | 12-22-2005 06:05 PM |
| Door panel removal/dash removal | HHTACO | Newbie Tech | 2 | 09-18-2005 09:55 AM |
