#1 |
I'm ordering my '06 Taco 4x4 with the SnugStop shell. I found a SnugTop dealer who can install the roof rack tracks on the shell for me for a pretty reasonable price. Is there anything special I should know about having this done? Has anyone experienced any cracking or other problems when wheeling with a heavy load in the rack? Any idea how much one can safely carry in a shell-mounted roof rack?
-Adam |
#2 |
Retired
![]() Join Date: Dec 2004
The canopy dealer I got my setup from advised against carrying heavy loads on the rail system, as the load is not distributed as well as it would be on the wide setup.
I would recommend the wide load setup, as it not only helps the canopy fair better against loads, but it also keeps the center of gravity lower. |
#3 |
Well I would say that the quality of topper construction i.e. the laminate is what is most important. I have had good luck installing racks for toppers to carry cargo baskets, canoes etc. My advise is to have the dealer install a track that is compatible with either the thule Tracker system or Yakima Control tower. The Thule rack I feel is a bit stronger the the yakima on this rack system. If you are planing a basket you should run a minimum of 3 crossbars. 4 if you are carrying heavy loads and or a long basket. For canoes kayaks things like that 2 bars are fine.
I would recomend forgoing the tracks though. They tend to be the weakest link of a roof rack. I would get the Thule Tracker and the mounting bracket that allows you to bolt it right through the topper. This is alot stronger then mounting to a thin aluminum track. Either way you have to drill to mount the rack so I would go the later. The Thule rack will be a quick release set up for easy removal incase you need to take it off. It also has locks so it can't be stolen. If you need help getting these parts let me know I am a dealer.
"96 Taco with to many mods. Currently awaiting a Xcab swap and flat bed. www.canoeescape.com |
#4 | |
I think you need to add any g-force loads to the weight in the rack. So for off-road I wouldn't add much over 100 (or so) lbs. Besides the top-heavy thing makes me keep loads light. Most loads I carry in my rack is two 2.5 gal fuel cans, and a fire pan. Maybe 40 lbs of stuff while I travel. I do find it a geat place to put suff around camp and a good tie-off for tarps. I have the Cab-Hi shell, Yakima rails and cross bars for 4 years. I've not seen any cracks yet or any leaks. |
| Thread Tools | |
| Display Modes | |
| Roof rack on '95.5-'04 X-Cab | LabradorBoy | Early Tacoma Tech | 56 | 10-23-2009 10:12 AM |
| Custom Steel Roof Rack - $400 | Elsensei | Parts/Electronics/Wheels & Tires For Sale | 15 | 12-08-2006 12:49 PM |
| 2005+ "Factory" roof rack | chris31 | Performance/Engine/Exhaust | 8 | 08-12-2005 03:13 PM |
| Bed shell | tacoma0309 | Early Tacoma Tech | 5 | 03-10-2005 08:28 AM |
| camper shell roof rack with surco rack. | nees1212 | Early Tacoma Tech | 5 | 02-23-2005 09:41 AM |
