Sponsored Ad
Go Back   TTORA Forum > General Tech > Performance/Engine/Exhaust
Thread Tools Display Modes
Old 04-13-2012, 03:12 AM   #1
SilverLux
Default 22RE Egr Valve
Just need some help.
I Currently are busy with a Efi Mod on a 22 R motor. Now all is going well but I need to know.
1. Is the Egr valve needed?
2. Can one bypass the Egr Valve?
What I see if you look at the Egr vavle to head it goes with a short port through the back of the head, then throught the backplate on the rear of the head into the head again all the way to the manifold. Now here is the problem; this engine has a branch on it, it means the EGR valve will never actually work correct?
Also, the BVSV, VSV valves will not then send the correct signal to the OE Ecu?
Regards,
Louis
Name:	EGR valve1.jpg
ID:	27510   Click image for larger version
Name:	Lower Manifold test.jpg
SilverLux is offline   Reply With Quote
Old 04-13-2012, 06:17 AM   #2
jdblatt
jdblatt's Avatar
Default
if you have to have smog where you live. you will need it. but i have heard of people removing the egr and using a block off plate with no issues.
85 4Runner
2006 limited 4Runner
jdblatt is offline   Reply With Quote
Old 04-13-2012, 11:15 AM   #3
SilverLux
Default
Lucky I do not need to have smog, I block it off.
Thanks!!
Old 04-16-2012, 03:02 PM   #4
Stoffregen Motorsports
Stoffregen Motorsports's Avatar
My Rig: 1957 Land Rover SI
Default
The EGR is not a bad thing to have on your motor. They don't really rob power and they are designed to help economy.
I have a 22RE in my 1957 Land Rover and it is completely de-smogged, except for the EGR. All I did was trace the vacuum source back to wherever it came from and deleted any un-needed pieces along the way, like that big vacuum line rail. Now I only have two vacuum lines in the whole engine bay.
530-392-8032
Stoffregen Motorsports is offline   Reply With Quote
Old 04-26-2012, 09:55 PM   #5
TrailBlazin'
TrailBlazin''s Avatar
My Rig: THE HARD TACO
Default
Block that shit off.
1ST GEN V6 SINGLE CAB TACOMA 4X4 RAMPAGE
Originally Posted by TacoDell View Post
Anyone wanting dual exhaust on a Tacoma has already breathed in too much carbon monoxide.
Originally Posted by ecar95 View Post
You will love the maple flavored beaver. Just make sure it's properly aged.
TrailBlazin' is offline   Reply With Quote
Old 04-26-2012, 10:17 PM   #6
Default
22RE's can get a flat spot between on and off throttle without the EGR.
I say leave it.
530-392-8032
Old 04-30-2012, 01:08 PM   #7
TrailBlazin'
Default
I say leave it.
Elaborate.
Old 05-07-2012, 12:01 PM   #8
Default
Originally Posted by TrailBlazin' View Post
Elaborate.
I told my tech guy to get in here and explain. He's going to be able to do a better job explaining it than I can.
But the short version is, the EGR helps cool the combustion gasses. If you plug the EGR, you can get a pinging on part throttle and/or a hesitation on part throttle acceleration. A lot of shops don't diagnose this problem properly and end up retarding the timing, when all they need to do is clear the crap out of the EGR system.
This isn't the case on all engines, but definitely on engines like the 22RE and late 70's/early 80's Chevy small blocks.
530-392-8032
You may not post new threads
You may not post replies
Forum Jump
22re valve adjustment? countryboyAL Pickup/4Runner Tech 7 12-07-2010 07:15 PM
22re valve size ROTAX10 Performance/Engine/Exhaust 0 07-27-2009 10:14 AM
valve clearance for 22re? toyotattb Pickup/4Runner Tech 2 04-07-2008 09:55 PM
22re valve tap joshuapc Pickup/4Runner Tech 9 03-08-2008 09:55 PM
22rte-22re valve thehopping1 Performance/Engine/Exhaust 0 12-02-2006 01:58 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
