Pressing wheel bearings at home update - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 08-21-2012, 07:42 AM   #1
yotaboy04
My Rig: 2000 single cab 4x4
Default Pressing wheel bearings at home update/how to
Well took a few days had issue with the parts from the dealer. Sorry don't have any pics but figured I would describe how we pressed the wheel bearings at home without any SST or home made SST. Just need a press, then we used 2 1/2" steel plates long enough to reach across your press.
Tried to press the first one cold but wouldn't budge so had to do a little heating with the torch (didn't even try and press 2nd without heating). you can then take and set the backing plat the solid metal piece with the studs up on the metal plates (outside the studs so they the studs and axle are sitting between the plates), that way all the pressure is on that solid piece....press the axle and with a little umpth she'll pop right out. To press in the new ones, you flip it all set your plates up vertical, plates are just big enough to catch the retainer (so you have slid the plates in between the studs and the retainer will sit right on the plates and you can press it right in.
Maybe that makes sense if not let me know maybe I can clarify
yotaboy04 is offline   Reply With Quote
Old 08-21-2012, 02:24 PM   #2
FrostTaco
FrostTaco's Avatar
Send a message via MSN to FrostTaco
Default
Try adding some pics and a step by step. other wise your just trying to lead the blind.
-FrostTaco
Rebuild in progress:1996 Tacoma 4X4, 3in lift, 97 front swap, 250k, 3.4L replacement, and a sunroof
1985 Hilux 4X4 build in progress. Build
FrostTaco is offline   Reply With Quote
Old 08-21-2012, 02:54 PM   #3
yotaboy04
Default
Sounds good I'll see what I can put together.
You may not post new threads
You may not post replies
Forum Jump
Pressing out front spindles/wheel bearings shawkins Early Tacoma Tech 19 01-28-2012 03:04 PM
Wheel Bearings 05DoubleTaco Late Tacoma Tech 19 09-14-2008 09:59 AM
pressing wheel hub out? Gearheadesw Newbie Tech 6 04-07-2007 10:12 PM
pressing out wheel bearings guitarman4325 Newbie Tech 8 02-20-2007 05:18 PM
Update Home? hawaiianbro News/Error Reporting/Suggestions/Help 7 09-24-2005 02:37 PM
