Sponsored Ad
Go Back   TTORA Forum > General Tech > Interior/Electrical/Electronics
Thread Tools Display Modes
Old 11-01-2005, 09:33 AM   #1
Vinman
Default wiring lighted rocker switch/ fog light relay wiring
OK so I have been searhing this and other forums in search of specific details on how to wire up a lighted rocker switch for my 7th gen/2004 tacoma.
I have the fogs wired directly to the battery for power and I have a Toyota OEM three prong lighted fog light rocker switch. The switch works fine, n problem there. But I'm having trouble getting the LED light to work. I can tap into a fuse in the uder dash fuse box to get it power but it stays on all the time and I don't want that. I only want it to light up when the fogs are on.
The second thing I want to do is wire the fogs to a relay so that they are only on with the low beams. I have a 30amp relay with 4 prongs and I think I know how to do this. I found several drawing on this site that show how.
So the question I have for this is, how do I tap into the low beam headlight circuit so that the fogs are synced with the low beams?
Thanks for helping a newbie out.
Vinman is offline   Reply With Quote
Old 11-01-2005, 01:03 PM   #2
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
Here's how the Hellas wire up..
http://www.hella.com/produktion/Hell..._aux_lamps.pdf
I didn't run mine to the low beams as I didn't want to cut into the stock headlight wires. Instead I plugged into the headlight relay in the fuse box under the hood... So my lights come on and go off when you turn the headlights on. Then I can control either the long range or fog lights with the rocker switches. If I turn off my stock headlights they all go off.
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Factory Toyota Fog Light switch 135boom Parts/Electronics/Wheels & Tires For Sale 31 04-06-2009 07:03 PM
Fog lamp switch - how do I light it? TBob Interior/Electrical/Electronics 10 10-18-2005 09:03 AM
Fog Light Switch Part #? kodiak Interior/Electrical/Electronics 15 06-19-2005 02:01 PM
turn signal light problems - relay switch??! adam246 Interior/Electrical/Electronics 2 03-27-2005 08:07 PM
Fog light switch Gargoyle Early Tacoma Tech 5 02-18-2005 07:30 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
