EGR P0401 Code in a 98 Taco 2.7 Ltr - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 06-03-2013, 08:56 PM   #1
TACO300
Default EGR P0401 Code in a 98 Taco 2.7 Ltr
I have a 1998 4wd Taco Ex cab,with a 2.7 motor that has 420K miles on it. The CEL came on and the code was P0401 "insufficient EG flow to EGR system". I tried cleaning the EGR, roto-rooting the tube the connects the EGR to the exhaust manifold and cleaning the EGR solenoid. When none of that worked I even replaced the EGR for $130 bucks and I still get the CEL.
The truck is running fine. I don't want to disconnect the system as some have suggested in other threads. Any ideas?
Is it possible that the temp sensor is shot? Those things run about $120 so I'd really like to know if its the likely culprit based on my description of the problem.
Side bar: When I removed the new EGR during my roto-rooting effort I did notice that the inside of the new valve was getting some fouling for the week that I ran it. It wasn't as bad as the original but it certainly had a coating of fouling indicating exhaust gas flow.
thanks
TACO300 is offline   Reply With Quote
Old 06-04-2013, 07:52 PM   #2
Tomomothy
Default
I'm not familiar with the 2.7L, but is it possible flow out from the EGR valve is obstructed? You mentioned cleaning the line from the EM to the EGR, but if the path from the EGR is blocked it could prevent flow and maybe trigger that CEL? It might have a different code instead, but thought I'd try to get the ball rolling a little
Tomomothy is offline   Reply With Quote
Old 06-04-2013, 08:53 PM   #3
Scuba
Scuba's Avatar
Default
There is a little disc looking filter with 3 vacuum tubes running off of it.
Pop it open. If the filter is dirty then it's bad.
Replace it.
You'll have to replace the disc looking housing/ filter. Can't get the filter separately.
I had the same exact thing happen.
99 Single Cab 2.7. Finally SAS'd and sitting on full width Toyota axles.
Scuba is online now   Reply With Quote
Old 06-05-2013, 12:31 AM   #4
Whitetoy
Whitetoy's Avatar
My Rig: 1999 Tacoma
Default
Had the exact same problem with my 2.7 just after I bought it. Cleaned the valve, replaced the modulator (with used) but did not clear the P0401. Finally, I removed the temp sensor, cleaned the tip real good, and re-installed it. This cleared the P0401. Seven months later, the code returned, and I cleaned it again.
Rick
1999 Tacoma 4WD 2.7 AT
CB, sliders, skids, TruTrac
Whitetoy is offline   Reply With Quote
Old 06-05-2013, 08:17 PM   #5
TACO300
Default
Temp sensor is what I'm thinking since the truck is running fine. I've already cleaned the EGR solenoid filter and inside the base with carb cleaner. I think I'll try cleaning the sensor first before I buy a new one.
Hopefully this will work.
Old 06-29-2013, 09:53 PM   #6
TACO300
Default
UPDATE: I cleaned the temperature sensor and no change. I ended up ordering a new OEM EGR vacuum solenoid since it was the cheaper than the EGR temperature sensor and that did the trick. No more CEL.
Old 07-01-2013, 12:15 AM   #7
Whitetoy
Whitetoy's Avatar
My Rig: 1999 Tacoma
Default
What was the part number on that solenoid?
Rick
You may not post new threads
You may not post replies
Forum Jump
CEL P0401, And a studder under accelleration. HELP PLEASE!! yota fan! Early Tacoma Tech 7 01-28-2013 11:44 PM
p0401 ike Maintenance & Parts 2 02-28-2012 11:18 AM
Tacoma Starting problem. P0401 TacoSupreme00 Early Tacoma Tech 14 12-19-2011 02:27 PM
P0401 code LowellDillon Early Tacoma Tech 3 10-07-2008 10:55 AM
DTC P0401 help HawaiiBuilt Performance/Engine/Exhaust 4 05-20-2008 11:02 AM
