3.4 swap - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Pickup/Early 4Runner Tech
Thread Tools Display Modes
Old 11-18-2005, 07:19 AM   #1
Full_Tilt_Fud
Full_Tilt_Fud's Avatar
My Rig: 1985 Pickup
Default 3.4 swap
Ok so I think I have found a sweet deal on a low mialage 3.4 to swap into my 85 4runner. Cureently I am running a 22re with a swapped in r151f. It is my understanding that the r150 from the tacoma's and ifs pickups is esentialy the same as the r151f only they have a different bellhousing pattern and are set up to take the chain driven t-case. So my question is this. can I just take the bellhousing from the r150 in the tacoma and bolt it onto my r151f and go. It sems way to simple after reading some of the things that people have done in the way of adapters and such to do this swap but heres hoping. I have searched and can not get a straight answer from any body. Do any of you Know?
~ Todd
85 ex. cab 1 tons, coilovers, ect
09 Dodge Ram 2500 w/ a Cummins.....Tow rig
Full_Tilt_Fud is offline   Reply With Quote
Old 11-22-2005, 10:13 PM   #2
BudBuilt
BudBuilt's Avatar
Default
Sorry but no. there is a difference between the 88-95 R150 and the 95+ R150. The input shaft and bell housing on the newer ones is longer by about an inch. You CAN take a 3.0 V6 bellhousing and bolt it to the R151F and to the 3.4. That will get you waht you want.
Bud R
http://www.budbuilt.com
Morganton, NC
Taco getting all the fixin's...
BudBuilt is offline   Reply With Quote
Old 11-23-2005, 05:58 PM   #3
Full_Tilt_Fud
My Rig: 1985 Pickup
Default
Thanks for the help. That sounds easy enough, and is what I kind of suspected but like i said in the original post I could not nail down a solid answer. So as far as a clutch do I just use one for a 3.0?
~ Todd
Old 11-24-2005, 06:00 AM   #4
BudBuilt
BudBuilt's Avatar
Default More info on this thread:
http://www.pirate4x4.com/forum/showthread.php?t=137361
I'm pretty sure you use the 3.0 clutch stuff but I know it says in this thread.
Enjoy!!!
Bud R
Morganton, NC
Old 11-24-2005, 08:08 AM   #5
mt_goat
mt_goat's Avatar
Default
Swapping in a 5VZ-FE in place of a 22RE is a little harder than the 3VZ-E but it can be done. The motor mounts need to moved IIRC. Not sure what else is different. Bill's "Red Chili" was once a 22RE: http://www.4x4wire.com/forums/showfl...fpart=all&vc=1
Dale
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
3.4L Clutch & Pressure Plate Swap for 2.7L Supercharged 2.7L Early Tacoma Tech 37 10-12-2005 10:29 AM
2.7 to 3.4 swap? davidw2337 Performance/Engine/Exhaust 4 09-06-2005 10:51 PM
96 s-cab bench to bucket swap? xakman Interior/Electrical/Electronics 2 07-14-2005 07:07 AM
seat swap in 97 tacoma redtruck Interior/Electrical/Electronics 5 04-27-2005 10:52 AM
3.4 v-6 swap into my tacoma Cowhorn Early Tacoma Tech 20 04-20-2005 04:59 PM
