Sponsored Ad
Go Back   TTORA Forum > General Tech > Toyota Truck & 4Runner Tech
Thread Tools Display Modes
Old 01-03-2006, 02:14 PM   #1
rojo22
Default 22r water in oil
Friend of mines 22r overheated and he thought that he had blown the head gasket. He had the head looked at a machine shop and they did not fine anything cracked. He replaced the gasket, of course but his problem is still there. Any suggestions of what might me causing it??
Roger
rojo22 is offline   Reply With Quote
Old 01-03-2006, 02:56 PM   #2
gimemoore
Default
Did he check the timing chain cover for wear? If there is water in the oil, as your topic title says, I'd bet it's a good possibility the guides broke and the chain was rubbing on the cover, wearing a hole into the water jacket.
gimemoore is offline   Reply With Quote
Old 01-03-2006, 03:15 PM   #3
rojo22
Default
Will check that, thanks
Old 01-04-2006, 04:00 AM   #4
jimbo74
jimbo74's Avatar
Send a message via AIM to jimbo74
Default
it is possbile the block is cracked between a cylinder wall and the coolant passages as well
My Truck Pic Gallery
FedEx
DISCLAIMER: THE TECHNICAL INFORMATION I HAVE PROVIDED MAY NOT BE THE MOST OR 100% ACCURATE, IT IS HOWEVER TO THE BEST OF MY KNOWLEDGE WITH THE PERSONAL AUTOMOTIVE EXPERIENCE THAT I HAVE HAD
jimbo74 is offline   Reply With Quote
Old 01-04-2006, 10:20 AM   #5
rojo22
Default
We checked them, don't think they are since engine runs fine without a miss-fire, i could be wrong
Old 01-04-2006, 12:33 PM   #6
BigMudTruk
The Anti-poser patrol...
BigMudTruk's Avatar
Send a message via AIM to BigMudTruk
Default
I'd bet a 6 pack of a beer of your buddies choice the timing cover has a hole worn right thru it.
2002 4x4 5sp TRD (ohhh...w/leather ), ARB BullBar, DO Hybrid bolt on sliders & Hybrid rear bumper, Black Wagon's w/33x12.50's, Extended hoes, TC UCA's, 4.56's, Lockrite front w/manual hubs, E-Locked rear, AAL, S/C, 7th, TRD Headers & exhaust, Linex'd, Glassworks Hood, bumpin tunes etc...
1987 Xtra Cab, D60 and Corp 14B, 42" Swampers, Propane burning 383 Chevy, swapping in 416" LS3 this winter
BigMudTruk is offline   Reply With Quote
Old 01-04-2006, 02:34 PM   #7
Mr Tode
Default
I'd wager on the timing cover as well, though I'd also check the hot water lines that run through the intake manifold. (The 22R has these for cold starts IIRC). Also, if there is an aftermarket oil cooler that's a possible mixing point as well.
Mr Tode is offline   Reply With Quote
Old 01-11-2006, 09:08 AM   #8
lilgription
lilgription's Avatar
Default
It's pretty hard to blow a Toyota motor, cracked block, head gasket, possible but that's the last place I would check. I would bet my wife its the timing cover. If it's not too bad don't waste money on a new one. JB weld that sucker and grind the excess off. Mines been holding for 4 years now and I run with guys thats been running that for 7 years and we wheel every weekend
91 Toyota 2wd converted to 4wd
lilgription is offline   Reply With Quote
Old 01-11-2006, 10:00 AM   #9
dougtrd
Moderator
dougtrd's Avatar
Default
If you are going to bet, you have to have your chips on the table...What kind of beer are you talking about? and we'll need pics of the wife you are willing to wager with!!! I have $.72 and some pocket lint I will put on the timing chain rub too.
07 Tundra (to drag the short bus around!)
'85 4Runner "The Short Bus"
dougtrd is online now   Reply With Quote
Old 01-11-2006, 10:51 AM   #10
BigMudTruk
BigMudTruk's Avatar
Default
Winner's choice on the beer if I'm right make it a 6 pack of Heffweisen Wheat Beer, its a good winter beer!
Old 01-11-2006, 04:03 PM   #11
hopper
Default
I had the same problem. I re did my head gasket and I still had water in the oil. I found the problem. Something happend and the timing chain wore into the water pump. So when ever it starts to get warm all the water would spray into the hole and into the engine. Try and see if thats it. Hope that helps.
hopper is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
22rte oil pressure Wgasa84 Toyota Truck & 4Runner Tech 12 12-29-2005 04:44 PM
oil pump ISSUES...desperate banshee_scream Early Tacoma Tech 9 11-01-2005 09:54 AM
Heating water in microwave... WARNING Gamblur Off Topic 11 05-21-2005 12:23 AM
Marine Grease? Ripcurlsurfin96 Early Tacoma Tech 4 03-10-2005 05:47 PM
Gear oil recycling, water? ElBandito Off Topic 9 02-08-2005 11:42 AM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
