Home | Chapter Members | Events | Trail Reports | Join
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Georgia Chapter > Tech
User Name
Thread Tools Display Modes
Old 01-16-2006, 04:37 PM   #1
sloppytaco
Part-timer
sloppytaco's Avatar
Default Steering wheel adjustment
The steering wheel has been off center for a while now and I want to correct if from inside the cab any suggestions?
1991 Acura NSX
2006 Toyota 4Runner Sport 4x4
2010 Toyota Sequoia Platinum
sloppytaco is offline   Reply With Quote
Old 01-16-2006, 04:51 PM   #2
GOT COPE?
Big tars, little bed.
GOT COPE?'s Avatar
My Rig: 2000 Taco
Send a message via AIM to GOT COPE?
Default
When you get an alignment the shop that does the alignment should also center the steering wheel at the same time.
My Truck and Specs
Originally Posted by crawlrunner View Post
Blatent abuse of power ... but funny ... carry on ...
BRC since 2006www.sharetrails.org
TLCA #15854 www.tlca.org
SFWDA since 2005 www.sfwda.org
GOT COPE? is offline   Reply With Quote
Old 01-16-2006, 05:35 PM   #3
sloppytaco
Part-timer
sloppytaco's Avatar
Default
I don't have the cash for an alignment I blew it all on trying to fix my noise problem. This I should be able to do with a little guidance
1991 Acura NSX
Old 01-16-2006, 05:38 PM   #4
GOT COPE?
GOT COPE?'s Avatar
My Rig: 2000 Taco
Default
$38. Stone Mtn. Tire straight across from Patrick's. I cant tell ya how to do it yourself sorry. I probably could figure it out but I havent tried yet
My Truck and Specs
Old 01-16-2006, 06:00 PM   #5
sloppytaco
Part-timer
sloppytaco's Avatar
Default
That is a great price! Some shops want around $100 for the alignment I can handle $38. Thanks for the info
1991 Acura NSX
Old 01-16-2006, 06:16 PM   #6
link817
link817's Avatar
Send a message via AIM to link817
Default
WOW, $100 for an alignment. I wouldn't go over 50, i've had 4-6 alignments w/ in the last year and have found someone who does it for 45. I have had the problem you had w/ the steering wheel not centered but the truck went straight. Easiest would be to get someone to hold the steering wheel straight and then work on the steering rack. You would counter the off-center steering wheel with adjusting the rack. I can't explain it to well typing, i've seen Jack do it to my rack.
2001 Extra Cab TRD
2.7L 5spd
link817 is offline   Reply With Quote
Old 01-16-2006, 11:46 PM   #7
GOT COPE?
GOT COPE?'s Avatar
My Rig: 2000 Taco
Default
Cool cool. Ive never paid more than $40 for an alignment. But yes I have gotten quoted some ridiculous prices.
My Truck and Specs
Old 01-17-2006, 12:54 AM   #8
tweeder3410
still around, somewhere
tweeder3410's Avatar
Send a message via AIM to tweeder3410
Default
With the size tires your running you shouldn't have a problem with alighnment, but remember you get what you pay for. If you won't pay over 50 bucks for one thats why you get it done 4-5 times a year. I just say screw it, alighnments are overrated! LOL
2008 Toyota Tundra
4X4
5.7L
Fat Bob's Garage 3-1 leveling kit
295/70/18 Nitto Terra Grappler A/T (35X11.5)
Pioneer AVIC HU w/ NAV
JLw3 8" enclosed w/ Alpine 450 amp
Thule rapid areo rack w/ basket, 2 Hull-a-ports, 2 uprite cycle racks.
Chrome wheel skins
can crawl average parking lot obsticals.
Lots-o-Gas
Dead Sexy bit*&es!!!
tweeder3410 is offline   Reply With Quote
Old 01-17-2006, 01:05 AM   #9
tweeder3410
Default
I got ya homie, I forgot to show ya when we were dealing with the alleged wheel bearing. It's simple, just pop out the little caps on the back side of the steering wheel cover, then use a small hex head to unscrew the bolts that hold the horn/airbag assembly,NOTE: they won't come out they just loosen up the little thinga ma jig that the airbag is fastened to. Once loosened pop off the horn/airbag, you may or may not need to unplug some of the wires to get it off but I would unplug the airbag and set it down gently so it's not in your way, there will be like a 1/2" nut that holds the steering wheel on, just take that off and your steering wheel will come off and you can just spin it to where it's straight.
NOTE: Before you start your mission be sure to disconnect the battery, so the airbag doesn't blow your face off on accident, and make sure your wheels are straight.
Once you get the horn/airbag off it's preety much common sence after that, you'll see what I mean, it's simple. Call me if you need a hand.
2008 Toyota Tundra
4X4
5.7L
Chrome wheel skins
Lots-o-Gas
Old 01-17-2006, 09:03 AM   #10
sloppytaco
Part-timer
sloppytaco's Avatar
Default
Thanks, Rick! How is the truck going?
1991 Acura NSX
Old 01-17-2006, 09:23 AM   #11
link817
link817's Avatar
Default
I really don't know whats wrong w/ my steering setup, I know that all my tires are out of alignment and that has a lot to do w/ it. My steering woes all started when i put poly bushing in the rack, worst desicion i have ever made. I wouldn't think that tire size has anything to do w/ price, its the rim size that becomes a problem. The alignment machines can only clamp onto certain sized rims. I don't know what the exact limit to the machines are now, but i bet anything over a 18 or 20 will encounter a problem. Shops that have ppl w/ bigger rims just use the stock sized rims and set the alignment and then put on the big "rims". People at goodyear said they could align a 37mtr as long the machine was capable to attach the rim.
2001 Extra Cab TRD
2.7L 5spd
Old 01-17-2006, 09:29 AM   #12
sloppytaco
Part-timer
sloppytaco's Avatar
Default
That's weird that you have had problems since you put the poly bushings on. I have not had a single problem with the poly bushings. They have actually helped stiffen the steering producing a quicker response.
1991 Acura NSX
Old 01-17-2006, 09:39 AM   #13
ATLRoach
Winder licker
ATLRoach's Avatar
Send a message via AIM to ATLRoach
Default
No problem with my polys either.. C, I think you are a hypocondreact for your truck. As the saying goes; "if it's not broke don't fix it".
Kyle
03 Tundra - SAWs, Wheelers AAL, BILs, 295s on FJ80 wheels
ATLRoach is offline   Reply With Quote
Old 01-17-2006, 10:08 AM   #14
link817
link817's Avatar
Default
Man the day i got the poly's put onto my truck, i went to drive it home and the steering wheel was off centered, who the hell knows how or why? The shaft going into the rack is keyed so it should of not happened. I only say this b/c I had the entire rack taken off the truck instead of grinding on the front diff. like peter parks did.
2001 Extra Cab TRD
2.7L 5spd
Old 01-17-2006, 10:27 AM   #15
link817
link817's Avatar
Default
alright your spelling wizard, hypochondria does not apply to my steering rack issue. i was told by a mechanic that everyone said was the stuff that my bushing were going out and that i need to replace them. So when i go to get my poly's installed w/ a different mechanic i find out that the first guy had turned into a bad business man.
2001 Extra Cab TRD
2.7L 5spd
Old 01-17-2006, 02:41 PM   #16
tweeder3410
Default
Finaly got the bearing pressed in about an hour ago but I still haven't been to sleep from workin all night last night and it is raining and I got my skids in and I want do do do but I can't and I am very unhappy And to top it off I have to leave for work tonight in an hour..... I'll have her up and ready tomarrow! HAHA!
How did the write up work out for ya?
2008 Toyota Tundra
4X4
5.7L
Chrome wheel skins
Lots-o-Gas
Old 01-17-2006, 02:55 PM   #17
sloppytaco
Part-timer
sloppytaco's Avatar
Default
I haven't had a chance to do it yet. I plan on doing it tonight after work. What all skids did you get? Glad to hear that your bearing is pressed in and ready to install on the truck. At least you can get a few sitting on the side of the road in the patrol car.
Do you need a cb for next weekends run? If you do I will bring up my spare. We will hook this one up without burning it up
1991 Acura NSX
Old 01-17-2006, 03:02 PM   #18
ATLRoach
Winder licker
ATLRoach's Avatar
Default
Richard, I have a CB you can have if you come and get it. Needs a power cord and mic.
EDIT:
Why you gotta full name me...mom...still disgruntled about the pack of hotdogs joke! LOL
Rick
Kyle
Old 01-17-2006, 04:33 PM   #19
STOMPER
GRUMPY SOB!!
STOMPER's Avatar
Default
Stop right here!!!! Before you eat up the new tires get a stinking alignment. It will fix the wheel and save money on tires. You cant tell me you dont have $50 to spend on an alignment but ya got $700 or $800 to spend on new tires. Also if ya dont get an alignment soon your going to be wanting new tires cause those new one will be riding like crap.
Im not arguing with you. Im just jumping in on something I dont know or care about!!
VSU_4runnin -
"The second looks like it got dragged through a JC Whitney catalog"
STOMPER is offline   Reply With Quote
Old 01-17-2006, 10:51 PM   #20
tweeder3410
Default
Sounds like a winner to me. Thanks man
2008 Toyota Tundra
4X4
5.7L
Chrome wheel skins
Lots-o-Gas
Old 01-17-2006, 10:55 PM   #21
tweeder3410
Default
EDIT:
Rick
2008 Toyota Tundra
4X4
5.7L
Chrome wheel skins
Lots-o-Gas
Old 01-18-2006, 05:10 AM   #22
ATLRoach
Winder licker
ATLRoach's Avatar
Default
Nice edit maybe next time you will learn where reply is.
Kyle
Old 01-18-2006, 12:38 PM   #23
tweeder3410
Default
LOL You know you love me sweetheart.....It was a very long night last night, had to keep busy somehow.
2008 Toyota Tundra
4X4
5.7L
Chrome wheel skins
Lots-o-Gas
You may not post new threads
You may not post replies
Forum Jump
cant find-alignment specs grumpy Solid Axle Swap Tech 85 03-03-2007 07:12 PM
Steering wheel questions??? tacokid1187 Early Tacoma Tech 6 11-21-2005 06:14 PM
Steering wheel clunk JLtaco Early Tacoma Tech 2 02-22-2005 11:00 AM
Steering Wheel spins, wheels don't turn Mpking Suspension 8 02-11-2005 04:02 PM
Grant 2001 Removable steering wheel Oppositeboy Interior/Electrical/Electronics 5 01-10-2005 12:55 PM
Privacy Policy
Links monetized by VigLink
