Sponsored Ad
Go Back   TTORA Forum > Desert Tech > Long-Travel Suspension Tech
Thread Tools Display Modes
Old 01-30-2006, 03:29 PM   #1
YoTRacer158
YoTRacer158's Avatar
Send a message via AIM to YoTRacer158 Send a message via Yahoo to YoTRacer158
Default 62" deaver questions...
For those of you running 62" deavers with a camburg ot TC longtravel kit...are you running 9" or 12" shackles? Through or above frame? And how does your truck sit? Level, ass high or ass low? Trying to figure out how the truck will sit if I run them with my donahoes. I figure if I can get the truck to sit level or slightly ass high with donahoes it'll sit a little ass low with the LT and thats fine with me.
2004 V6 5spd 4x4: TRD Charger, URD Fuel Mods/AFR/Unlimiter/2.1" Pulley/Crank Pulley/Short Throw, Supra MAF, TrueFlow Filter, JBA Ti Ceramic Headers, SpinTech Exhaust, SPEC Stage 3+ Clutch, BentUp Front Bumper, Chaos LT/Kings, 62" Deavers/18" Kings/, Glassworks Supercharger Hood/Fenders/Bedsides, 15x8 Black Steelies, 33x12.5 Claws, 4.56's, RR Solid Motor Mounts
youtube.com/YoTRacer158
YoTRacer158 is offline   Reply With Quote
Old 01-30-2006, 03:31 PM   #2
Tweeter
Desert Moderator
Tweeter's Avatar
My Rig: Tacoma Prerunner
Send a message via AIM to Tweeter
Default
Yeah I would like to know how much lift you would get depending on what arch (10.5 12.5 etc) you use with 9" shackles above the frame as well.
Tweeter is offline   Reply With Quote
Old 01-30-2006, 03:51 PM   #3
YoTRacer158
Default
according to deaver, the 10.5" arch gives 1" lift over a stock tacoma...but I'm not sure which shackle configuration that is with. on the website they give the approximate lifts for each arch. I think it's 1", 3" and 5" but not positive. I think the different arches are mainly for different weights though depending on how big your fuel cell is, how many spares youre carrying, etc.; more arch for more weight
Old 01-30-2006, 10:09 PM   #4
egress81
Default
asked this same question on Dezertrangers here is a link
http://dezertrangers.com/cgi-bin/ib/...T;f=12;t=31084
egress81 is offline   Reply With Quote
Old 01-30-2006, 10:54 PM   #5
surfpunk
surfpunk's Avatar
Default
i have the f67 pack with a 9" shackle mounted on the bottom of my frame and my trucks pretty level. infact, sometimes it seems like the rear is a little higher and then sometimes it seems like its a little lower lol. i have a lot of weight back thier though. personally, unless youre planning on not having any spares, the stock gas tank, and a basic shock hoop setup, i would recommend the f67 over the f55. even if youre ass high, it'll perform better. you want a little more up travel than down travel. if you dont have enough up travel you'll be bottoming out a lot more.
surfpunk is offline   Reply With Quote
Old 01-31-2006, 12:29 AM   #6
x0ffr0adtac0x
x0ffr0adtac0x's Avatar
Default
i have the deavers 62" 12.5 arch, with 9" shackles through the frame....heres a pic of it when i got it back from the shop, but it sits just about level now
x0ffr0adtac0x is offline   Reply With Quote
Old 02-01-2006, 01:01 AM   #7
YoTRacer158
Default
Hmm...if I ran a 9" shackle over the frame it might sit close to being level with the donaoes. How much travel are you pulling?
Old 02-01-2006, 09:39 AM   #8
x0ffr0adtac0x
Default
running it above the frame is really close, pm bajarnr12. i know he has a 9" shackle above the frame. right now im pulling a little over 18" but bumped at 17+
Old 02-01-2006, 11:06 AM   #9
YoTRacer158
Default
cool man, thanks for all the info
You may not post new threads
You may not post replies
Forum Jump
I Need Deaver Help cvajs Suspension 14 07-15-2008 06:58 PM
Deaver 5 leaf + Deaver 3 leaf AAL Cdshot10 Newbie Tech 19 08-11-2007 05:42 PM
Deaver 8 leaf pack, OK to tow with?? Krscott80 Suspension 13 07-14-2006 03:29 PM
Final Suspension Questions (Hopefully) ShadyRevelation Suspension 7 10-21-2005 02:23 PM
Deaver AALs on a 94 Spring Pack - adding lift for cheap GodwinAustin Suspension 3 02-18-2005 05:43 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
