#1 |
I recently installed some fog lights on my 99 prerunner and they worked great except that now my radio, dome light, and powerlocks aren't working. I
initially thought i must have blown a fuse, so i checked every fuse with the fuse indicator tool and none of them were blown. I don't know what else it could be at the moment, being that it was a simple installation that didn't involve messing with any other wire components. Installation went as follows, foglights - wired to battery - then to switch, disconnecting the battery was the only thing involved that would have effected anything electronic. If anyone has any suggestions or solutions they would be much appreciated. thanks
2000 Prerunner 2.7l - deckplate and elbow mods, magnaflow exhaust, helix TBS, 3" Toytec lift w/ alcan AAL, 33X10.50 BFG MT's on stock 15's |
#2 |
Dun DUn DUN!
![]() Join Date: Dec 2004
either pull those fuses and look at them or use a 12v test light. those little testers aren't the greatest things in the world....
#3 |
Probably your dome light fuse.
When mine blew, it killed power to the radio too. I replaced the dome fuse, and all was good again. Check ALL your fuses by manually pulling them.
SEARCH and you shall succeed 1996, 2.7 l, 5-speed, Downey 3.5" lift, NWOR Try-y header, K&N FIPK, B F Goodrich 31x10.5 All Terrain KO's, custom rear bumper, Diamond headlights, NWOR cross-drilled rotors Whiteface glo gauges, and Firestone on-board air compressor with a 1 gallon tank.
#4 | |
The fuse may not be fully blown, it could be partially broken and allowing enough electricity through to show it's working on your tester, but not enough to power those components. On my old truck, I had a fuse like this. It tested fine, but I pulled it, and it was partially blown. Still whole enough to power the instrument cluster that was on the same fuse, but not to let the dome light work. Replaced the fuse, and everything was right again. |
#5 |
I'm not sure but I'd look closely at the fuse labled "AM1" under the hood. I had something similar happen on my 2003 taco. It's 40 amps in my rig.
#6 |
I've checked all of the fuses and replaced all of the ones that had anything to do with the problem i'm having and so far nothing has worked. I was told to check the relays also, but i'm not sure how to do that, any suggestions?
#7 |
Dun DUn DUN!
if youre not sure how to do it you might consider buying new relays.... you need an ohm meter to check them. the resistance of the coil depends on the relay and its spec.... and then if you hook up the coil to 12v power you should read continuity between the contacts
#8 |
thanks all for the input, i guess my next step is to take it to a dealership, it seems that it must be a short or something, it just doesn't make sense though
#9 |
Dun DUn DUN!
i would still get a 12v test light...... see where you aren't getting voltage at..
#10 | |
River Rat
05 Taco - SAC'd HPD44 - F.O.A. Coilovers - Armored and Locked. 99 Cummins - Workin towards 1,000lbs Torque 05 GSXR 750 - 20th Anniversary - My Coffin I'm Brown And I will Rule The World One Day. |
#11 |
Dun DUn DUN!
true but it is probably a short somewhere so its going to be an all or nothing type of thing..... lol come on kaleo catch up!
#12 |
Disconnect the fog lights, see if your problem goes away?
#13 |
Fix it? What was it?
#14 |
no it didn't but thanks vanguard, i haven't fixed it yet, i have to work tonight but when i get off i'm going to try the 12v test light before i have to bring it to the dealership
#15 |
After finally breaking down and bringing my truck to the dealership and $859.00 later, it turns out I had a short in the wire harness coming off of the fuse box, or so they tell me, and they replaced it with a new wire harness and it worked, well worth the $859.00, right. Thanks for all the input, I wish it would have helped, but unfortunately I had to suck it up and spread'em for the dealership, ouch. $479.00 for labor, what a crime.
#16 | |
![]() My Rig: 2000 sr5
![]() ![]() ![]() ![]() I know this is old but..........call valkrie or barb at toy of dallas/trdparts4u for any factory item then post on your local ttora chapter and buy the pizza and beer for some help.
2000 2.7l x-cab 4wd. mods .........yes
| Thread Tools | |
| Display Modes | |
| ham radio 101 | wrooster | Interior/Electrical/Electronics | 184 | 04-19-2011 10:00 AM |
| Scion Radio Install??? | ttman | Interior/Electrical/Electronics | 26 | 10-27-2007 08:44 AM |
| Dome light trouble | mgyver1 | Interior/Electrical/Electronics | 2 | 01-15-2007 03:44 PM |
| Radio removal, Sirius install '05 Tacoma | blanz | Interior/Electrical/Electronics | 10 | 11-24-2005 07:16 PM |
| crap radio reception | absolut taco | Interior/Electrical/Electronics | 6 | 08-15-2005 09:26 PM |
