Sponsored Ad
Go Back   TTORA Forum > General Tech > Tires/Wheels
Thread Tools Display Modes
Old 02-25-2006, 07:49 PM   #1
tacoma0309
tacoma0309's Avatar
Send a message via AIM to tacoma0309
Default balancing wheels
I know the Tacomas stock wheels are lug centric and there are few places that have the adapter to balance them correctly, but how many of you have had your wheels balanced on a regular hub centric machine and can you tell the difference? I am looking to get somes new tires at Sams and I don't think they will have the adapter. Thanks
'04 Taco DC, TRD, 4WD
'08 Honda Odyssey EX (The Sleeper)
tacoma0309 is offline   Reply With Quote
Old 02-25-2006, 09:27 PM   #2
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
Discount Tire hub centric balanced my BFG AT's 265/75/16 when purchased... There was a vibration and shimmy between 55 and 60 mph following their work... I then took it to the Yota dealer as I knew they used the lug centric method... All the vibration and mild shimmy disappeared... So for me the answer would be... absolutely.. I'd think the larger tire you go to... the more important this becomes...
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is offline   Reply With Quote
Old 02-25-2006, 09:35 PM   #3
The Dude
The Dude's Avatar
Send a message via AIM to The Dude
Default
you think thats what could be wrong with my black crawler wheels? or are the 1/4 in spacers doing it?
1997 FZJ80, Factory Lockers, 285s, OME lift.
The Dude is offline   Reply With Quote
Old 02-25-2006, 09:41 PM   #4
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
Could be the spacer... But I'll almost bet it's the balance... 1/4 spacer ain't so bad... Steel wheels make it a little more difficult as well... Mine are alloys... But IMO... It would be a good place to start... Make sure they weight both inner and outer beads... If you wheel hard in the rocks... have them use stickys on the inboard of the rims outer lip... If you don't rockcrawl... use the standard clip ons... They may look ugly... But it's worth the lessened aggravation...
Truck...
Trailer...
Old 02-25-2006, 11:05 PM   #5
NorCalTRD
NorCalTRD's Avatar
My Rig: 2004 Tacoma
Send a message via AIM to NorCalTRD
Default
is there a differance, sure. but if the person who balanced your tires knows what they are doing you would have a hard time felling the difference between them. at the tire shop where i work, we have the ability to "pin-plate" a tire if needed. the pin plate acts as if there are lug nuts, which make the tire act more like it will when it is on the vehicle. i know my shop has this, i would imagine that most other tire shops would have the same thing.
NorCalTRD is offline   Reply With Quote
Old 02-26-2006, 05:45 AM   #6
tacoma0309
tacoma0309's Avatar
Default
What is the name of the adapter that you need? I'll ask them when I go there next.
Old 02-26-2006, 08:17 AM   #7
Full_Tilt_Fud
Full_Tilt_Fud's Avatar
My Rig: 1985 Pickup
Default
I work for a tire store as well. We have the pinplates to center the wheel off the lugnuts but through experimentation with my own truck i have foend that the truck will drive better with less vibrations when the normal old center cone is used. The problem is that when you use the pins you are still suppose to place a center cone behind the wheel to help center it. With the large hubs on the tacoma you have to use a large cone and when you tighten it down the cone contacts the machine before the backside of the wheel so there is no support which is bad.
~ Todd
85 ex. cab with the usual stuff on 38's
01 Dodge Ram 2500 w/ a Cummins.....Tow rig
Full_Tilt_Fud is offline   Reply With Quote
Old 02-26-2006, 08:34 AM   #8
cdub
Default
Full Tild Fud said it right on. I work for Discount and balance my 33's with the normal cone. As long as you get a good person balancing the wheels it really makes no difference. Just ask for one of the top technicians to balance the wheels for you and you should be fine.
cdub is offline   Reply With Quote
Old 02-26-2006, 11:53 AM   #9
tacoma0309
tacoma0309's Avatar
Default
Thanks for all the info !!!
Old 02-26-2006, 10:05 PM   #10
NorCalTRD
NorCalTRD's Avatar
My Rig: 2004 Tacoma
Default
both Full_Tilt_Fud and cdub are correct, just hope that the guy that does the work knows what he is doing and there shouldn't be a problem.
ian
2004 Xtra Cab, V6, 5 Speed.
Donahoe Extended Coilovers, Camburg Upper Control Arms, Donahoe Remote Rear Reservoir Shocks, Deaver 8 leaf pack, 15x8 Black Steelies, 33x12.50R15 BFG All Terrain T/A KOs, TRD Supercharger, URD Fuel Kit, Doug Thorley Headers, Magnaflow Exhaust, Line-X.
DD 2006 Lexus IS350
Originally Posted by PathBlazerTRD
SEARCH BUTTON is your best friend. nobody can answer these questions for you until you figure out what you want your truck to look like and be capable of. we aren't miss cleo....
You may not post new threads
You may not post replies
Forum Jump
List of 15" and 16" Wheels for Tacomas Mikevr007 Tires/Wheels 179 08-10-2012 09:48 AM
2005 Tacoma Donahoes, 265/75/16 Terra Grapplers w/ wheels, 1400 for package! nubreed71 Parts/Electronics/Wheels & Tires For Sale 12 01-29-2006 07:18 PM
1999 4runner/Taco Limited Wheels - Excellent Condition!!!! montypower Parts/Electronics/Wheels & Tires For Sale 5 11-29-2005 10:15 AM
05 trd 17" wheels for sale MaDeuce Parts/Electronics/Wheels & Tires For Sale 2 11-28-2005 03:33 PM
advice needed on my wheels -- keep or buy new? wrooster Tires/Wheels 15 09-27-2005 09:22 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
