Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 03-30-2006, 11:51 AM   #1
remelad
remelad's Avatar
Send a message via AIM to remelad
Default Who Is Running Total Chaos UCA's on '05 !?!
Who is running these arms? Are you having any issues with them?
I know they kick the wheel back some but I want find out how much since it will cause rubbing issues.
I'm running a ToyTec 3" kit with 285/75/16 BFG A/T's on 16x8 wheels.
Chad M. Germer
ASE Master Technician
D & C Auto Center
Spray On Products Bedliner Dealer
remelad is offline   Reply With Quote
Old 03-30-2006, 01:52 PM   #2
SP Jon M3
SP Jon M3's Avatar
Send a message via AIM to SP Jon M3 Send a message via Yahoo to SP Jon M3
Default
I'm running them. I have no clearance issues because I went with 265/75/16s. And yes, they do kick the tires back some.
Jon
'05 Double Cab 4x4 V6 SR5 Auto White
Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders.
'01 Double Cab 4x4 V6 Auto TRD Black, you will be missed.
'89 BMW M3 Alpine White
SP Jon M3 is offline   Reply With Quote
Old 03-30-2006, 01:58 PM   #3
remelad
remelad's Avatar
Default
Any chance you can try to measure center of wheel to a point around the body mount?
Chad M. Germer
D & C Auto Center
Old 03-30-2006, 01:59 PM   #4
SP Jon M3
SP Jon M3's Avatar
Default
Sure can, as soon as I get home I will.
Jon
Old 03-31-2006, 10:09 AM   #5
rogersja63
rogersja63's Avatar
Default
I don't know if this helps but I was running same setup as you but with Camburg UCA's and have no rub at all. I went to SAW's up front after the Toytec but not for any rubbing issues. I think the tire is still closer to rubbing in the front than it is the back of the wheel well.
2007 Tundra 4x4, 5.7L, 6sp, Limited: Stock!
rogersja63 is offline   Reply With Quote
Old 03-31-2006, 10:09 AM   #6
ToyoTaco
ToyoTaco's Avatar
Cool
Been running mine for 7 months now (w/2" front DR coilovers & 1.5" rear spring pkg. lift)....here are couple of pics right after the install:
http://i26.photobucket.com/albums/c1...er/DON_TC_.jpg
http://s26.photobucket.com/albums/c1...t=DON_TC_2.jpg
Haven't put them to any kind of serious testing....but what off roading I've had a chance to do...had some fairly good articulation....by my standards they work very well....the most common thing I've noticed is the DR springs making popping noises....which usually happens with coils when extended and worked hard.
I did change out to after market wheels (OEM's rubbed off road with stock tires on hard articulation):
http://s26.photobucket.com/albums/c1...rrent=Rear.jpg
and went with 275/70/16 BFG's AT (went with this size to give me a more accurate speedo reading too...much more accurate then OEM tires!!!)....the wheels off set I don't remember, but they were fairly standard for my application from American Eagle. They just clear the calipers...and where with the OEM, I couldn't get my fingers between the tires and suspension....with these guys I can easily pass all my fingers between tire and suspension.
I've not experienced any rubbing since going with this combination and am quit happy with the results. I suspect if your going for major off road....that you should consider the TC upper and lower.....which is very trick....but gets expensive to fully utilize.
Fjota
Silver '07 FJ 4X4 w/6 speed, V6
http://groups.msn.com/42TOYS/pictures
http://www.k11og.org/
K11OG#5....Redbrick
ToyoTaco is offline   Reply With Quote
Old 04-01-2006, 06:01 AM   #7
tacosupreme
Veteran
tacosupreme's Avatar
Default
they make a lower? thought that was the long travel only.
"Don't touch the trim!" Earlie Cuyler, Squidbillies
http://www.youtube.com/woodlogan
tacosupreme is offline   Reply With Quote
Old 04-04-2006, 09:04 AM   #8
ToyoTaco
ToyoTaco's Avatar
Talking
Yeah....it's for the long travel set up and part of the reason it's an expensive set up
Fjota
K11OG#5....Redbrick
You may not post new threads
You may not post replies
Forum Jump
Donahoe extended coilovers and Total Chaos UCA installation writeup cryptyk Suspension 8 02-17-2008 09:59 PM
Total Chaos Long Travel Kit with Fox Components PWScottIV Suspension 400 09-20-2007 10:11 PM
2005 total chaos Vosy Long-Travel Suspension Tech 4 08-09-2005 03:22 PM
Unbiased recommendations on Donahoes or Total Chaos Impulsetaco Suspension 77 06-19-2005 02:13 AM
Wanted: Total Chaos Long Travel with Fox Coilovers PWScottIV Wanted 3 05-25-2005 09:01 PM
Privacy Policy
Links monetized by VigLink
