super swamper ? on a tacoma - TTORA Forum
Go Back   TTORA Forum > General Tech > Tires/Wheels
Thread Tools Display Modes
Old 01-22-2005, 06:42 PM   #1
backyard_motorsports
backyard_motorsports's Avatar
Default super swamper ? on a tacoma
just bought some super swamper ltb's the size are 33x13.5x15 . i am running a 99 taco with 3" susp and 2" of body, and 15x10 rims, do you guys think a will have any problems??
backyard_motorsports is offline   Reply With Quote
Old 01-23-2005, 07:33 PM   #2
YoTRacer158
YoTRacer158's Avatar
Send a message via AIM to YoTRacer158 Send a message via Yahoo to YoTRacer158
Default
you're probably gonna rub bad with that setup. my buddy runs 33x12.5's on 15x8's w/ 3" suspension and 2" body and he rubs pretty bad. with the extra inch of width on the tires and the wider rims, you're gonna rub like crazy
2004 V6 5spd 4x4: TRD Charger, URD Fuel Mods/AFR/Unlimiter/2.1" Pulley/Crank Pulley/Short Throw, Supra MAF, TrueFlow Filter, JBA Ti Ceramic Headers, SpinTech Exhaust, SPEC Stage 3+ Clutch, BentUp Front Bumper, Chaos LT/Kings, 62" Deavers/18" Kings/, Glassworks Supercharger Hood/Fenders/Bedsides, 15x8 Black Steelies, 33x12.5 Claws, 4.56's, RR Solid Motor Mounts
youtube.com/YoTRacer158
YoTRacer158 is offline   Reply With Quote
Old 01-23-2005, 08:38 PM   #3
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
LOL, uh, yea, you'll have major rubbing with those w/o about 8" of lift. Even pounding the pinchweld won't keep them off the fenders and in the rear you'll start ripping off your fender flairs.
And, unless you have rims with around 2.75-3" of backspacing, maybe less, you won't clear the spindle towers much less the frame rails on full-lock turns.
good luck.
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 01-25-2005, 12:15 PM   #4
cwaters1184
Default
friend of mine ran 33x13.50 tsl's on 10in rims with just a 3 in body lift on his 03 4x4. yea it rubbed. but not THAT bad. mudding in straight line= no rubbing depends on what you do.
cwaters1184 is offline   Reply With Quote
Old 01-25-2005, 08:53 PM   #5
Boheefus
BMFWIC
Boheefus's Avatar
Default
don't let these guys scare you....just don't turn and there will be no problems
Boheefus
It's getting better all the time...
Boheefus is offline   Reply With Quote
Old 01-25-2005, 09:23 PM   #6
aloe
aloe's Avatar
Default
I have a 3.5" Fabtech Perf... Downey 3" leaf packs(really 4"). & a TM 3" body lift. I have 33x14.50x15 SSR's on 15x10's, they rubbed the pinch welds at full turn when in reverse. The front was a forced modification...I hit a deer, it jumped into the side of the fender & got caught in the wheel well and wound up ripping off the valence. I've downgraded to 33x12.50x15 BFG AT/KO's on 15x8's
But, I never got stuck, looked good, and got the worst gas mileage (10-12 MPG).
BTW...check the MFG's website for the ACTUAL diameter! Mine were 33.4"
aloe is offline   Reply With Quote
Old 01-26-2005, 12:10 AM   #7
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Boheefus
LOL, yea, that and don't hit any bumps or dips
and dang, I got my first post yanked
I still say bs on that one post with the 3" bl.
Old 01-26-2005, 01:09 PM   #8
drice82
Default
it depends on the backspacing on your wheels. the less backspacing = less rubbing for you. stock bs is around 3.75 i think most ppl with aftermarket wheels have about 3.5 -3.25 inch of bs. with the 13.5 i would hope you have at most 3" of bs for minor rubbing...
drice82 is offline   Reply With Quote
Old 01-26-2005, 02:05 PM   #9
4x4Dragon
4x4Dragon's Avatar
Default
only in the south............
yes, you may have the problem of your truck looking like a frog/toad.
1996 Toyota Tacoma Reg. Cab-5spd.
2" PA Body Lift
3" Cornfed Spacers/2" rear lift blocks-1" Cornfed Lift shackles
Rancho rear shocks/Heckethorn-Rough Country struts
"Disappearing Sway Bar" Mod
Deck Plate mod
33x12.5x15 Sport King A/T's
4.30's & Lock-Right rear locker
15x8 Chrome/Black Modular steel wheels
4x4Dragon is offline   Reply With Quote
Old 01-26-2005, 03:19 PM   #10
grillmasterp
Deal Master
grillmasterp's Avatar
Default
Try to pull a u turn or 3 pt turn in the street and you should find out
grillmasterp is offline   Reply With Quote
Old 01-26-2005, 05:44 PM   #11
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
stock bs on all Tacomas is 4.5"
the less backspacing you go with the more lift is required to keep the tires out of the fender edges.
Old 01-26-2005, 06:01 PM   #12
Live4yotas
Live4yotas's Avatar
Default
Heytenor is right. The width of the tire and the backspacing on the rim makes all the difference in the world. I ran 31x12.50x15 thornbirds on 15x10's stock no lift. It hit the front valance pretty bad but wasn't unbearable. It was ok for normal driving but any sharp turning and I was hitting. But a friend of mine runs 32x10.50x15 tsl radials on stock rims no lift and doesn't hit at all. PULL THAT 2" BODY LIFT OFF AND PUT ON A 3" BODY LIFT. That will give you 6" of lift I think you will be close put alright with that setup.
Live4yotas is offline   Reply With Quote
Old 01-31-2005, 02:34 PM   #13
pportera
pportera's Avatar
Default
No way on a 10 inch rim,Mabye on an 8 inch rim with lots of pinch weld hammering. If u get the B/S just right u might can get away with not to major rub.
pportera is offline   Reply With Quote
Old 02-24-2005, 04:18 PM   #14
StemsCornfedTaco
StemsCornfedTaco's Avatar
Send a message via AIM to StemsCornfedTaco
Default
I have 2.5" Cornfed Spacers and a 2" Body Lift on my tacoma and im running 33 x 12.50 Thornbirds, which measure out to almost 14 inches, on 15x10s and they rub a little bit.
___________________________
98 SR5 Xtra Cab 2.7L 5 Speed
2.5" Cornfed Coil Spacers
2" PA Body lift
AEM Short Ram Intake
Sony Xplod System
StemsCornfedTaco is offline   Reply With Quote
Old 02-25-2005, 10:16 PM   #15
mr.trd
I think I remember where Moab is?
mr.trd's Avatar
Default
Every truck is different man.... I am running 35" MT/R's on 10" wide wheels with only about 2" of suspension and a 2" body lift.... Just takes some clearancing....But that is why we have sawzall's...
Brant Luckow
INACOMA
'06 d-cab TRD Off-Road
Lift Me, Lock Me, Use Me, Abuse Me
mr.trd is offline   Reply With Quote
Old 02-25-2005, 11:00 PM   #16
x0ffr0adtac0x
x0ffr0adtac0x's Avatar
Default
get some gears
x0ffr0adtac0x is offline   Reply With Quote
Old 02-25-2005, 11:35 PM   #17
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
ahhh, such a versatile tool
Old 02-26-2005, 07:13 AM   #18
StemsCornfedTaco
Default
Sawzalls I like the Way you think,
~Robby
GONE: 1998 Xtra Cab 4x4 2.7L 5 Spd. Lifted and on 33's
NEW ARRIVAL: 2006 Ford F-250 SuperDuty, Supercab Longbed 4x4
Im Sorry,...Did I Hurt your Feelings? Let me Call an Ambulance
Too Much Peer Pressure...
MySpace!
Old 02-26-2005, 11:47 PM   #19
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
The Sawzall Mod
Old 02-27-2005, 09:49 AM   #20
StemsCornfedTaco
Default
Gotta do whatcha gotta do
~Robby
MySpace!
Old 02-27-2005, 11:58 AM   #21
AK98Taco
Retired
AK98Taco's Avatar
Default
I'm sitting on 3" of suspension lift with 33x12.50s on 15x10s, 3 5/8" backspace. I occasionally tap the pinch weld under full-stuff turns, but I have not done much to fix that. The biggest issue is the rear where I am hitting the bedside during articulation. If I open up the wheel wells some I will gain back most of flex in back, although the tires are doing a good job of massaging the fenders out of their way.
The only problem I can see you having is between the side of the tire and the upper control arm. Everything else is workable by moving or removing sheet metal.
Post up the results and show everyone what the real situation is. Only a few that posted are actually able to compare to your situation.
Stick with me and Brant, mr. trd, when we tell you to run the biggest tire with the least amount of lift. It works very well, offroad and on.
Good luck!
-Thomas
I love to buy my parts from TRDParts4U.com
AK98Taco is offline   Reply With Quote
Old 02-27-2005, 01:45 PM   #22
mr.trd
mr.trd's Avatar
Default
Thanks for the pat on the back man!!! But it does work.... How many other IFS Tacomas have run the Rusty Nail!!!!
Brant Luckow
INACOMA
Old 02-27-2005, 05:50 PM   #23
AK98Taco
Retired
AK98Taco's Avatar
Default
No problem, buddy. I should be up your way next weekend to get my front bumper built.
I don't know how many Tacomas have run Rusty Nail, but I know that many could, as my truck is nothing special. I'm sure that my truck is one of the few Tacos to go through there, but that's because it's a lesser-known trail.
-Thomas
You may not post new threads
You may not post replies
Forum Jump
