#1 |
![]() Join Date: Dec 2004
I was thinking if it can run long enough, and I added an additional 2 gal tank it could work? I would mount it in my toolbox and a tank under the bed.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
On the lookout for a new rig
#2 |
Good For You
Well, if it actually is a 100% duty and actually pushes 3.4 cfm then you should have no problems. The higher end on board air systems run about the same cfm but not all are 100% duty cycle. I'm not sure of the reasoning but most air units like that don't recommend a tank larger than 3 gallon. If it's all legit, that's a good deal, imo.
~Stroke AzTTORA
#3 | |
One beautiful man.
99 Taco V6. 33's, dual ARB's, lift, winch and armour. 77 FJ40. 35's, power steering, rear lockrite. My pics and videos |
#4 |
02 4-Runner |
#5 | |
One beautiful man.
#6 |
No I am looking for one that I dont have to fab and I think the lowrider shops around have them but it would almost be cheaper to fab it up , ive seen propane tanks , thought about using one of my old dive tanks but just too heavy. I love the compressor it is a little slow but it does the job I think I paid $200 ish for it.
02 4-Runner |
#7 | |
One beautiful man.
#8 |
Schedule 40 PVC capped off makes great air tanks, you can make them any length and most any diameter needed to hide in voids under the truck. Its inexpensive to work with. Not sure how well it would hold up in extremely cold weather though.
Tim |
#9 | |
One beautiful man.
#10 |
They hold pressure well, when they let go they normally crack and bleed out, not explode and spray plastic. I forget the blow out pressure on sched 40 but it's higher than 150psi. Alot of industrial sites use 1-2" schedule 40 to route internal air systems for shop tools. The major draw back is it's more susceptible to impact and vibration than a steel or aluminium tank. And again with the cold temps you guys get up north I dont know if the PVC would be affected by freezing.
It's been used on various equipment for years as a low cost and easy custom fit alternative to metal tanks. Look at a main water supply system sometime, a 4" line can push as much as 100psi before a reducer, and their all made of PVC now a days. Even if you limited your system btwn 90 and 100psi and hid a few tanks in voids under the truck you could carry a large volume of air to speed up tire servicing. It's an alternative to metal tanks that has'nt gained popularity due to the "fear factor". I was a little worried the first time I saw it in operation but have since come to trust them. I know one person that has a portable 4 gallon PVC tank for servicing. Tim |
#11 | |
One beautiful man.
#12 |
If I could get tanks inexpensive or free I'd go with metal also, It's prefered, PVC offers a viable solution for a low cost. I'll hafta try calling some compressor repair places to see if theyre disposing of any, I never thought of that. Used tanks could also be modified by shortening or adding notches to fit in odd places then pressure tested fairly cheep.
Tim |
#13 | |
#14 |
shalom biatch
Steve, could you post some pics of your ONBOARD AIR SYSTEM
thanks
1998 std cab taco sold 1/9/08 |
#15 | |
One beautiful man.
#16 |
Numba 2 Ho
I used PVC pipe for behind the rocker panel tanks but I used schedule 80. Schedule 80 is thicker walled so if nothing else is easier to drill and tap for 1/4" pipe fittings. However, I did use schedule 40 end caps because of cost and they are less exposed. So far it had not been any trouble. I could use a bigger compressor, ViAir 450, but space is limited under the hood these days.
I admit to being Crazy but I'm not Stupid |
| Thread Tools | |
| Display Modes | |
