Winch mount help? Warn 8274 = grill cutting? - TTORA Forum
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 04-19-2006, 12:27 PM   #1
SEREvince
un labeled
SEREvince's Avatar
Default Winch mount help? Warn 8274 = grill cutting?
My bumper was originally designed for a winch with a remote solenoid. I found a decent deal on a Warn 8274, and I am hoping to jam it in there somehow.
Measurements according to warn website are 15 inces high by 8.5 inches deep. Which basically covers my entire grill, since my winch tray is only 6 inches deep.
http://www.warn.com/truck/winches/src/M8274-50.shtml
Has anyone done any grill trimming to fit a winch? Pics?
My grill overhangs the area above the bumper by 2-3 inches. Here is my bumper. Sorry about the pics, best I have on hand.
01 Taco Dcab with plenty of expensive crap that never sees the trail.
Blue Ribbon Coalition Member! Join or donate HERE!
Originally Posted by Common Sense
You know how I know you're gay? Your mods list is in your sig and includes half a page of mods that have nothing to do with going off road.
www.gosere.com
SEREvince is offline   Reply With Quote
Old 04-19-2006, 12:31 PM   #2
Bear
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default
Instead of going back toward the truck with your trimming, have you thought about cutting and expanding the area of the bumper?
By this I mean cutting out the winch tray, in the front, enlarging the cavity designed for the winch and re-boxing it making it larger?
I think this would have a greater potiential for looking better than to cut up your grill.
At first I thought it might be easier, but thinking further into the idea, it would probably be a little bit more involved (cutting and welding) but if you have the resources. I still think it would be a better solution.
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 04-19-2006, 01:29 PM   #3
grumpy
________________________
Default
have you remove the grill and placed the winch in to see? I ahd the same prob with the first winch bumper we built. thought we had it taken into acct but once got wnch, would have required cutting up the grill. I decided t ojust make new bumper.
dependong on how the mounts are maybe lower mounts to lower mounting plate t oallow more room. if as low as can be I only see 2 good options-new bumper or cut up or remove grill. other option would be sell that one and pay difference for non-intergeted winch.
grumpy is offline   Reply With Quote
Old 04-19-2006, 02:02 PM   #4
SEREvince
un labeled
SEREvince's Avatar
Default
As pretty as the truck is I am not totally opposed to cutting the grill or the bumper if it comes down to it.
One of my other concerns is cooling. If I block the grill with a winch, will it cause the truck to overheat?
I can't really lower the mounting surface, without a major rework of the bumper, just below the mounting surface it begins to angle back. Besides the fact that i would have to pay someone to cut up a bumper that originally cost $1000
www.gosere.com
Old 04-19-2006, 03:52 PM   #5
grumpy
Default
I didn't know the situation with bumper-cost, if friend helped etc. jsut trying to offer some options.
I to had the concern about cooling. are you an auto or manual? if auto do you have a stack-plate type cooler (not tube and fin)? I don't believe your summers get as hot as here in Phx. those I know that have blocked the grill area some don't have cooling problems. don't forget the fan will pull the air around the winch. you will lose more of the ram air flow at speeds.
If me, think I"d try mounting winch with grill off. maybe even block little more of rad with something (reduce more air flow) drive around both city and hywy. note the temp guage. does it seem normal for the current outside temps? if so, you probably be fine. Also might want to start looking for another grill, if might sell truck in future.
Old 04-20-2006, 09:36 AM   #6
SEREvince
un labeled
SEREvince's Avatar
Default
I think I would save myself a huge headache, by just buying a winch that fits. I saw a good deal on a 8274, and was salivating over the thought of having one on my truck. But it would probably just be a huge PITA to get mounted. Really the only advantages I can see to the 8274 are the length of line and super fast no load retrieval speed. Just trying to talk myself out of buying it anyway
www.gosere.com
Old 04-20-2006, 09:41 AM   #7
98taco4x
Bear's Chauffeur
98taco4x's Avatar
Send a message via AIM to 98taco4x
Default
I have a pick of one but I am at work. I will try to post up the pic tonight when I get home.
98taco4x is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Warn 8274 winch MTNRIDE Lets Talk About Wheelin! 3 02-15-2006 10:41 PM
Warn Winch Mount Combo Kit TacomaJones Good Deals/Freebies 6 12-06-2005 07:40 PM
hidden winch mount on 2003 taco viter Early Tacoma Tech 24 11-23-2005 03:10 AM
winch mount Q wh1te tac0 Early Tacoma Tech 13 09-27-2005 12:23 AM
Warn Trans4mer Winch Mount 01-04 Tacoma TacomaJones Parts/Electronics/Wheels/Tires 8 08-06-2005 07:55 AM
