Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 05-09-2006, 12:19 PM   #1
n737nc
Default Cruise control intall??
I did a search, but came up empty handed.
I have a 03 Tacoma TRD, 5 speed, 3.4L. Looking to install cruise control in it. How much of a pain is this to do on your own?
Thanks,
Nick
n737nc is offline   Reply With Quote
Old 05-09-2006, 12:54 PM   #2
faithoffroad
faithoffroad's Avatar
Default
I don't have a write up but all you do is get a bicycle shifter and some cable mount the shifter anywhere you want to(I like it on the transmission shifter like mine). Run the cable and attach it to your throttle and there you go.
To use get up to desired speed and lock into position. Be careful though cause it won't turn itself off when you hit the brakes. If you push in the clutch you could also blow up your engine. When you hit a hill you may or may not have to adjust to keep up speed.
"If it has tit's or tires, you can be pretty sure your going to have problems with it"
faithoffroad is offline   Reply With Quote
Old 05-09-2006, 01:50 PM   #3
Footpounds
Footpounds's Avatar
Default
That is one GHETTO cruise control. But if it works for you, who am I to judge?
Referring to an illegal alien as an "undocumented worker" is like calling a drug dealer an "unlicensed pharmacist."
Footpounds is offline   Reply With Quote
Old 05-09-2006, 01:59 PM   #4
wslytoy
I just got laid... off.
wslytoy's Avatar
Default
Are you buying a kit from Toyota? I put a kit on my 96 2.7 5spd that ran me like $230. Its basically the same kit that Gulf Coast Toyota uses. As soon as I get home from work, I'll post pics of my install. Its DEFINITELY a great mod if you don't have it, if you do lots of highway driving like I do!!
05' TRD 4x4(gas guzzler)
85' 4Runner Build Up Thread
New Forum Rule
When in doubt, bring Wes' name into the argument to turn attention from yourself. Not sure of what to post b/c you're an attention posting whore? Call Wes' intelligence into question... Always good for a little snicker. And if you act fast enough, it's guaranteed to make you feel better about YOU.
wslytoy is online now   Reply With Quote
Old 05-09-2006, 02:49 PM   #5
LAW
Oilfield Trash
LAW's Avatar
Default
check this out before you buy the kit, the cruise may already be there...
http://www.ttora.com/forum/showthrea...cruise+control
-Lindsay
2003 Toyota Tacoma D-Cab 4X4
LAW is offline   Reply With Quote
Old 05-09-2006, 11:48 PM   #6
wslytoy
wslytoy's Avatar
Default
I got my kit off of ebay, but M & R Electronics sold it to me. They've got their own website I think its HERE. They sell ROSTRA accessories, which is a really good aftermarket company for "luxury" type mods, cruise control & seat heaters. Sorry for the shitty quality pics, I took em' w/ a cell phone cam and I was in a hurry. Hopefully this will help you out!
Here's a pic of the tach wire, it hooks to the igniter, as you'll see in a pic below.
I basically mounted the stalk as close to the "stock" location as possible. It turned out pretty good
A pic of the igniter wire hook up
A pic of the wire for the ignition
Its hard to see, but the grey wire hanging from the dash cross bar is connected to a white wire w/ an orange stripe on the wiring harness to the ECM
More random wiring w/ ZIPTIES !
Adjusting the linkage for the cable off of the actuator
Just the fuses for the power wires
Engine bay wiring
Actuator box mounted
Brake switch connection
New Forum Rule
Old 05-10-2006, 05:10 AM   #7
n737nc
Default
Great info guys! I'm gonna do some more digging. Maybe I'll get lucky and everything will already be set up aside from the cruise switch. This truck has every other option BUT cruise, so I may get lucky.
Thanks again!
You may not post new threads
You may not post replies
Forum Jump
2003 cruise control LAW Interior/Electrical/Electronics 7 02-28-2006 12:54 PM
Cruise control on Taco SAS 3TRDMARINE Solid Axle Swap Tech 11 12-27-2005 08:21 AM
cruise control pic wslytoy Interior/Electrical/Electronics 5 09-05-2005 08:41 AM
cruise control issues ryannotbrian Early Tacoma Tech 4 08-19-2005 02:48 PM
cruise control re-location bmw678 Interior/Electrical/Electronics 8 08-05-2005 01:59 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
